[研电赛技术支持] GD32F450之以太网(Lwip2.1.2+FreeRTOS+UDP+TCP)
9307|44
 楼主| 小海师 发表于 2025-3-6 19:59 | 显示全部楼层 |阅读模式
本文简要介绍GD32单片机关于以太网的应用,参照官方应用手册,基于Lwip2.1.2版本对UDP及TCP通信进行测试。使用PHY芯片为LAN8720,实时操作系统FreeRTOS。实现自适应10M/100M以太网通信。
一、基础配置:
引进外设初始化,选择RMII模式,复用单片机引脚(相关引脚为固定脚,直接复用即可),首先使能总线时钟,选择接口模式(RMII),再复用引脚。
//IO总线时钟使能,此处将所有外设时钟使能
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_GPIOC);
    rcu_periph_clock_enable(RCU_GPIOD);
    rcu_periph_clock_enable(RCU_GPIOG);
    rcu_periph_clock_enable(RCU_GPIOH);
    rcu_periph_clock_enable(RCU_GPIOI);
    //使能系统时钟
    rcu_periph_clock_enable(RCU_SYSCFG);
    //选择RMII模式
    syscfg_enet_phy_interface_config(SYSCFG_ENET_PHY_RMII);
    //PA1:REF_CLK 时钟引脚,外部PHY提供50M
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_1);
    //PA2: ETH_MDIO
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_2);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_2);
    //PA7: ETH_RMII_CRS_DV
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_7);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_7);
    //引脚复用
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_1);
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_2);
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_7);
    //PB11: ETH_RMII_TX_EN
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_11);
    //PB12: ETH_RMII_TXD0
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_12);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_12);
    //PB13: ETH_RMII_TXD1
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_13);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_13);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_11);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_12);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_13);
    //PC1: ETH_MDC
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_1);
    //PC4: ETH_RMII_RXD0
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_4);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_4);
    //PC5: ETH_RMII_RXD1
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_5);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_1);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_4);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_5);
2、以太网初始化:使能以太网相关时钟,初始化MAC、DMA相关控制(使用官方默认库函数即可)
ErrStatus reval_state = ERROR;
rcu_periph_clock_enable(RCU_ENET);//使能以太网总线时钟
rcu_periph_clock_enable(RCU_ENETTX);//使能发送时钟
rcu_periph_clock_enable(RCU_ENETRX);//使能接收时钟
enet_deinit();//复位总线时钟AHB
reval_state = enet_software_reset();//等待时钟复位完成
if(ERROR == reval_state){//复位失败
   while(1){
//以太网设备初始化
#ifdef CHECKSUM_BY_HARDWARE//不定义
enet_init_status = enet_init(ENET_AUTO_NEGOTIATION, ENET_AUTOCHECKSUM_DROP_FAILFRAMES, ENET_BROADCAST_FRAMES_PASS);
#else  //PHY自动协商、禁用IP帧校验功能、地址过滤器通过所有接收到的广播帧ENET_100M_FULLDUPLEX/ENET_AUTO_NEGOTIATION
enet_init(ENET_AUTO_NEGOTIATION, ENET_NO_AUTOCHECKSUM, ENET_BROADCAST_FRAMES_PASS);
#endif /* CHECKSUM_BY_HARDWARE */
    /*注:当前使用的LAN8720PHY芯片只能使用自动协商模式,手动模式无法通信*/
3、中断配置,结合实时操作系统,在中断中接收数据:
//以太网正常中断启用
  enet_interrupt_enable(ENET_DMA_INT_NIE);
  //接收中断使能
  enet_interrupt_enable(ENET_DMA_INT_RIE);
//使能以太网中断请求
    nvic_irq_enable(ENET_IRQn, 5, 0);//配置中断优先级
//中断函数
    portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
    if(SET == enet_interrupt_flag_get(ENET_DMA_INT_FLAG_RS)){
        /* 数据中断后释放信号量(在接收任务中处理) */
        xSemaphoreGiveFromISR(g_rx_semaphore, &xHigherPriorityTaskWoken);
    /* 清除相关标志位 */
    enet_interrupt_flag_clear(ENET_DMA_INT_FLAG_RS_CLR);
    enet_interrupt_flag_clear(ENET_DMA_INT_FLAG_NI_CLR);
    if(pdFALSE != xHigherPriorityTaskWoken){
        portEND_SWITCHING_ISR(xHigherPriorityTaskWoken);
4、Lwip协议栈初始化,主要配置IP、MAC等信息,创建数据收发任务。
ip_addr_t fsl_netif0_ipaddr, fsl_netif0_netmask, fsl_netif0_gw;
tcpip_init(NULL, NULL);
    inet_aton((char *)&phy_cfg.ip, &fsl_netif0_ipaddr);
    inet_aton((char *)&phy_cfg.netmask, &fsl_netif0_netmask);
    inet_aton((char *)&phy_cfg.gateway, &fsl_netif0_gw);
    netif_add(&fsl_netif0, &fsl_netif0_ipaddr, &fsl_netif0_netmask, &fsl_netif0_gw, NULL, &ethernetif_init, &ethernet_input);
    netif_set_default(&fsl_netif0);
netif_set_up(&fsl_netif0);
其中ethernetif_init函数需在ethernetif.c文件中修改。此外,需要注意,在官方库中,默认使用的PHY为DP83848,需在“gd32f450xx_enet.h”中修改PHY寄存器地址,当前使用LAN8720。
上述内容大致为以太网的基本配置,此时应该能正常ping设备IP。
二、UDP连接:
UDP连接创建的大致流程为:创建套接字、绑定套接字、数据通信、套接字关闭。
1、创建套接字:socket(),指定协议类型等
int sockfd= socket(AF_INET, SOCK_DGRAM, 0);//UDP,IPV4协议
2、绑定套接字:bind(),将套接字与设备IP端口信息绑定
struct sockaddr_in local_addr;//本地IP、端口
local_addr.sin_family = AF_INET;//IPV4协议
local_addr.sin_port = htons(port);//设备端口
local_addr.sin_addr.s_addr = htons(INADDR_ANY);
bind(sockfd, (struct sockaddr *)& local_addr, sizeof(local_addr));
3、数据通信:
数据接收:
char buff[]={0};
struct sockaddr_in from_addr;//远端IP、端口
socklen_t fromlen;//长度
recvfrom(sockfd, buff, sizeof(buff), 0, (struct sockaddr *)&from_addr, &fromlen); //此函数为阻塞函数,将接收的数据存放于buff中。
数据发送:数据发送需要知道发送的目标信息,可以是接收数据时的IP、端口,也可以自定义。
struct sockaddr_in service_addr;//服务器IP、端口
socklen_t service_len;
void init_service_socket()
  ip_addr_t sip;//服务器IP
  u_int16_t sport;//服务器端口
  //初始化服务端的IP和端口
  service_addr.sin_family = PF_INET;
  service_addr.sin_port = htons(sport);
  service_addr.sin_addr.s_addr = sip.addr;
  service_len = sizeof(mqtt_service_addr);
//通过创建的套接字将数据发送至服务端
sendto(sockfd, send_buff,send_len,0,(struct sockaddr *)&service_addr,service_len);
三、TCP客户端
TCP连接创建的大致流程为:创建套接字、绑定套接字、连接服务器、数据通信、套接字关闭。
int sockfd= socket(AF_INET, SOCK_STREAM, 0);//TCP,IPV4协议
3、连接服务器:TCP通信是面向连接的,连接前先确定服务器的IP、端口信息。
  //初始化服务端的IP和端口
connect(sockfd, (struct sockaddr *)& service_addr, sizeof(service_addr));//与服务器之间建立TCP连接
4、数据通信:
数据接收:套接字只能接收来自建立连接的服务端的数据。
char buff[]={0};
recv(sockfd, buff, sizeof(buff), 0); //此函数为阻塞函数,将接收的数据存放于buff中。
数据发送:通过建立连接的套接字将数据发送至服务端。
//通过创建的套接字将数据发送至服务端
send(sockfd, send_buff,send_len,0);
四、TCP服务器
TCP服务器创建的大致流程为:创建新的TCP协议控制块、绑定IP端口、监听绑定的协议块、初始化接收回调函数。
1、创建TCP协议控制块:
struct tcp_pcb *Tcp_server_pcb=NULL;
Tcp_server_pcb = tcp_new();//创建新的TCP块
if(Tcp_server_pcb == NULL)
    printf("tcp new failed");
2、绑定IP、端口:固定端口(80),允许任意IP连接(同网段)。
if(tcp_bind(Tcp_server_pcb,(const ip_addr_t*)INADDR_ANY,80))//绑定IP与端口
    term_printf("tcp bind failed");
3、监听:
Tcp_server_pcb = tcp_listen(Tcp_server_pcb);//监听
  term_printf("tcp listen failed");
tcp_arg(Tcp_server_pcb,Tcp_server_pcb);//确认监听连接
4、初始化接收回调函数:初始化完成后可通过网页端进行测试,也可以telnet连接。
数据解析与响应:
static err_t tcp_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) {
  if (p != NULL) {
    char *req = (char *)p->payload;//接收的数据
    char client_ip[INET_ADDRSTRLEN];
    inet_ntop(AF_INET, (char *)&pcb->remote_ip, client_ip, INET_ADDRSTRLEN);//将IP放入数组中
printf("Client connected from %s:%d\n", client_ip, ntohs(pcb->remote_port));//打印客户端IP、端口
//通过网页端测试
    if (strstr(req, "GET / ")) {//来自网页端的请求
      const char *html = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n"
        "<html><body>Hello, GD32!</body></html>";
      if(tcp_write(pcb, html, strlen(html), TCP_WRITE_FLAG_COPY))
        printf("数据写入缓冲区失败!");
      if(tcp_output(pcb))
        printf("TCP send data failed");
    }else {
      const char *error = "HTTP/1.1 404 Not Found\r\n\r\n";
      tcp_write(pcb, error, strlen(error), TCP_WRITE_FLAG_MORE);
      if(tcp_output(pcb))
  pbuf_free(p);
  return ERR_OK;
绑定接收回调函数:
static err_t tcp_server_accept(void *arg, struct tcp_pcb *pcb, err_t err)
        /* 配置接收回调函数 */
        tcp_recv(pcb, tcp_recv);
        return ERR_OK;
初始化回调函数:
tcp_accept(Tcp_server_pcb,tcp_server_accept);//初始化接收回调函数
浏览器输入IP显示如下:
原文链接:https://blog.csdn.net/m0_60881302/article/details/145896003
weifeng90 发表于 2025-3-7 08:15 来自手机 | 显示全部楼层
能分享一下源代码吗?谢谢。
pentruman 发表于 2025-3-19 11:14 | 显示全部楼层
实现UDP和TCP通信,是一个复杂的任务
saservice 发表于 2025-3-19 12:13 | 显示全部楼层
将 LwIP 和 FreeRTOS 的源码添加到项目中。
配置 LwIP 的网络接口,绑定到以太网接口。
创建任务来处理 LwIP 的任务调度。
uiint 发表于 2025-3-19 14:20 | 显示全部楼层
应用程序通过LwIP的套接字API发送数据。
LwIP将数据封装成TCP或UDP数据包,并通过以太网MAC控制器发送给PHY芯片。
benjaminka 发表于 2025-3-19 17:27 | 显示全部楼层
调用LwIP的初始化函数,配置网络接口。
515192147 发表于 2025-3-20 09:05 | 显示全部楼层
GD32F427实物图
Web浏览图
详细咨询见:
https://bbs.21ic.com/icview-3335470-1-1.html
louliana 发表于 2025-3-20 10:02 | 显示全部楼层
GD32F450是GigaDevice推出的一款基于ARM Cortex-M4内核的高性能微控制器,它具备丰富的外设接口
maudlu 发表于 2025-3-20 12:39 | 显示全部楼层
合理配置中断优先级,确保网络中断能够及时处理。
geraldbetty 发表于 2025-3-20 15:30 | 显示全部楼层
如何使用LwIP实现UDP广播?
plsbackup 发表于 2025-3-20 17:33 | 显示全部楼层
测试UDP和TCP的基本功能
FranklinUNK 发表于 2025-3-20 21:39 来自手机 | 显示全部楼层
网络这个容易学吗?
lihuami 发表于 2025-3-21 15:21 | 显示全部楼层
FreeRTOS提供了任务调度、同步、通信等机制,有助于实现复杂的网络通信功能。
claretttt 发表于 2025-3-21 17:05 | 显示全部楼层
从简单UDP透传开始验证基础功能,逐步扩展TCP复杂场景
jimmhu 发表于 2025-3-21 20:54 | 显示全部楼层
LwIP 和 FreeRTOS 都需要使用一定的内存资源,要合理分配内存,避免内存溢出。
gygp 发表于 2025-3-22 17:46 | 显示全部楼层
开发基于UDP的应用程序,实现数据包的发送和接收。
10299823 发表于 2025-3-22 18:28 | 显示全部楼层
下载并配置 GD32F4xx 的固件库。
wwppd 发表于 2025-3-22 18:51 | 显示全部楼层
根据GD32F450的内存资源,配置LwIP的内存管理参数,如缓冲区大小、TCP/IP栈大小等。
hilahope 发表于 2025-3-22 19:07 | 显示全部楼层
整合GD32F450的硬件特性、FreeRTOS的实时调度能力及LwIP的轻量级协议栈,可构建高效稳定的网络应用。关键在于正确配置DMA通道、优化内存分配及任务优先级。
yeates333 发表于 2025-3-22 19:40 | 显示全部楼层
要根据实际的网络环境正确配置 IP 地址、子网掩码、网关等参数
