谢谢楼上的指点,现在可以编译C了. Build started 6.6.2008 at 09:12:02 avr-gcc -mmcu=atmega128 -Wall -gdwarf-2 -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wp,-M,-MP,-MT,test0.o,-MF,dep/test0.o.d -c ../test0.c -o test0.o avr-gcc -mmcu=atmega128 test0.o -o test0.elf avr-objcopy -O ihex -R .eeprom test0.elf test0.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O ihex test0.elf test0.eep Build succeeded with 0 Warnings...
楼上的再指点下.
