XPS在生成Bitstream时遇到错误
2156|1
 楼主| shang651 发表于 2012-10-10 18:33 | 显示全部楼层 |阅读模式
按照Xilinx提供的XPS实验做到Lab2时,编译出现了“ LOC constraint L13 on dip_GPIO_in_pin<0> is invalid: No such site on the device. To bypass this error set the environment variable 'XIL_MAP_LOCWARN'.”这个问题。
最终在Google上面搜索到了答案,总结如下:
网址:http://www.fpga-faq.com/archives/84675.html
This basically tells you that there is no pin "dip_GPIO_in_pin<0>" on your FPGA, which is understandable... Haven't seen any FPGAs with 130 rows/columns around lately :) You're trying to route he signal dig_video_out<3> to a pin that does not exist. Same with most of the other signals, your FPGA
can't possibly have pins like that. Check your pin assigments again.
看了看system.ucf发现,实验教材中使用的是spartan-3E的板子,而我使用的是Spartan 3A DSP1800A板子,原来在对管脚分配和定义时,把"dip_GPIO_in_pin<0>" 分配到了实际不存在的引脚,所以出现了这个错误。 改正管脚的名称后,再编译,ERROR没有了:)
GoldSunMonkey 发表于 2012-10-10 21:09 | 显示全部楼层
不错,谢谢啦。
