有用STM32L系列定时器CC2触发AD采样调通的么?
3131|3
 楼主| hackthree 发表于 2012-11-26 09:57 | 显示全部楼层 |阅读模式
有用STM32L系列的朋友么?用TIM2的CC2触发AD采样+DMA,有调通的么?
代码如下:
void ADC1_Sample_Configuration(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  TIM_DeInit(TIM2);
/* ------------------- TIM2 Configuration:Output Compare Timing Mode ---------*/
  TIM_TimeBaseStructure.TIM_Period = 1199;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Output Compare Timing Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 100;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//TIM输出比较极性低
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE); //使能或者失能TIMx在ARR上的自动装载寄存器
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  DMA_DeInit(DMA1_Channel1);//将DMA通道一设置为缺省值
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Sampling[0];//连接Memory中变量地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//设置DMA为单向传输
  DMA_InitStructure.DMA_BufferSize = 100;//设置DMA缓冲区长度
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//设置DMA的外设递增模式
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//设置DMA的传输模式:连续不断的循环模式
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel1, ENABLE); // Enable DMA channel1
  RCC_HSICmd(ENABLE);
  /* Enable GPIOA clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  /* Configure PA.02 (ADC Channel2) in analog mode */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Check that HSI oscillator is ready */
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  /* Enable ADC1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* ADC1 configuration */
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_RisingFalling;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2;                 //定时器2的CC2触发
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel2 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_4Cycles);
  /* Enable ADC1 */
  ADC_DMACmd(ADC1, ENABLE);// Enable ADC1 DMA
  ADC_Cmd(ADC1, ENABLE);// Enable ADC1
  /* Wait until the ADC1 is ready */
  while(ADC_GetFlagStatus(ADC1, ADC_FLAG_ADONS) == RESET)
          /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConv(ADC1);
AD_Sampling[100]的数组中始终都是0。
求指点。。
 楼主| hackthree 发表于 2012-11-26 10:19 | 显示全部楼层
有没有人呢 ?
 楼主| hackthree 发表于 2012-11-26 13:44 | 显示全部楼层
香主呢?指点下。
 楼主| hackthree 发表于 2012-11-28 10:02 | 显示全部楼层
顶顶。。。。。
