inout 双向数据口,前仿和门级仿真都通过了,时序仿真就是
3413|16
 楼主| zhpg009 发表于 2012-12-28 21:54 | 显示全部楼层 |阅读模式
如题,错误如下
QuartusII 里面设置已经把Generate netlist for functional simulation only 设置成OFF
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(167): Failed to find INSTANCE '\data_bus[0]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(71): Failed to find INSTANCE '\data_bus[0]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(44): Failed to find INSTANCE '\data_bus[1]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(83): Failed to find INSTANCE '\data_bus[1]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(305): Failed to find INSTANCE '\data_bus[2]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(95): Failed to find INSTANCE '\data_bus[2]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(342): Failed to find INSTANCE '\data_bus[3]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(107): Failed to find INSTANCE '\data_bus[3]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(379): Failed to find INSTANCE '\data_bus[4]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(119): Failed to find INSTANCE '\data_bus[4]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(53): Failed to find INSTANCE '\data_bus[5]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(131): Failed to find INSTANCE '\data_bus[5]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(444): Failed to find INSTANCE '\data_bus[6]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(143): Failed to find INSTANCE '\data_bus[6]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(62): Failed to find INSTANCE '\data_bus[7]~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(155): Failed to find INSTANCE '\data_bus[7]~output '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(240): Failed to find INSTANCE '\data_bus~16 '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(254): Failed to find INSTANCE '\data_bus~16clkctrl '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(194): Failed to find INSTANCE '\en~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(176): Failed to find INSTANCE '\rd~input '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(263): Failed to find INSTANCE '\reg_data[0] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(291): Failed to find INSTANCE '\reg_data[1] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(328): Failed to find INSTANCE '\reg_data[2] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(365): Failed to find INSTANCE '\reg_data[3] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(402): Failed to find INSTANCE '\reg_data[4] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(430): Failed to find INSTANCE '\reg_data[5] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(467): Failed to find INSTANCE '\reg_data[6] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(495): Failed to find INSTANCE '\reg_data[7] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(226): Failed to find INSTANCE '\temp_data[0] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(277): Failed to find INSTANCE '\temp_data[1] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(203): Failed to find INSTANCE '\temp_data[1]~0 '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(217): Failed to find INSTANCE '\temp_data[1]~0clkctrl '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(314): Failed to find INSTANCE '\temp_data[2] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(351): Failed to find INSTANCE '\temp_data[3] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(388): Failed to find INSTANCE '\temp_data[4] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(416): Failed to find INSTANCE '\temp_data[5] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(453): Failed to find INSTANCE '\temp_data[6] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(481): Failed to find INSTANCE '\temp_data[7] '.
# ** Error: (vsim-SDF-3250) E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo(185): Failed to find INSTANCE '\wr~input '.
# ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_v.sdo".
#    Time: 0 ns  Iteration: 0  Instance: /tri_bibuffer_test File: E:/Verilog_ex/exam_5/simulation/modelsim/Timing_sim/tri_bibuffer_test.v
求解释!
 楼主| zhpg009 发表于 2012-12-28 21:58 | 显示全部楼层
testbench文件如下
`timescale 1 ns/ 1 ns
module tri_bibuffer_test();
  //port definition
  reg en_t, wr_t, rd_t;
  reg[7:0] data_in_t;             //input data
  wire[7:0] data_out_t, data_t;   //output data
  //module instantiated
  tri_bibuffer i1
    .data_bus(data_t),
    .en(en_t),
    .wr(wr_t),
    .rd(rd_t)
  //input and output control logic
  assign data_t = ( rd_t & ~wr_t ) ? 8'bz : data_in_t;  //data_t as a input port
  assign data_out_t = ( rd_t & ~wr_t ) ? data_t : 8'bz;  //data_t as a output port
  //initialize the port
  initial
    begin
      en_t = 1'b1;
      wr_t = 1'b0;
      rd_t = 1'b0;
      data_in_t = 8'd0;
      //CS is active
      #100 en_t = 1'b0;
      //data as a input, write datas to temp_data constantly
      #100 wr_t = 1'b1;
      #100 data_in_t = 8'd1;
      #100 data_in_t = 8'd2;
      #100 data_in_t = 8'd3;
      #100 wr_t = 1'b0;
      //data as a output, read datas from temp_data
      #100 rd_t = 1'b1;
      #100 rd_t = 1'b0;
      //data as a input, write datas to temp_data 8'd3
      #100 wr_t = 1'b1;
      #100 wr_t = 1'b0;
      //data as a output, read datas from temp_data 8'd3
      #100 rd_t = 1'b1;
      #100 rd_t = 1'b0;
      //data as a input, write datas to temp_data 8'd2
      #100 wr_t = 1'b1;
      #100 wr_t = 1'b0;
      //data as a output, read datas from temp_data 8'd2
      #100 rd_t = 1'b1;
      #100 rd_t = 1'b0;
      //data as a input, write datas to temp_data 8'd0
      #100 wr_t = 1'b1;
      #100 wr_t = 1'b0;
      //data as a output, read datas from temp_data 8'd0
      #100 rd_t = 1'b1;
      #100 rd_t = 1'b0;
      //CS is not valid
      #100 en_t = 1'b1;
      #100 $stop;
    end
endmodule
源文件如下:
module tri_bibuffer
        data_bus, en, wr, rd
        inout[7:0] data_bus;
        input en, wr, rd;
        reg[7:0] reg_data;                //Image register,waiting for output
        reg[7:0] temp_data;                //Data input register
        assign data_bus = ( ~en & rd & ~wr ) ? reg_data : 8'bz;
        always @ ( en or wr or rd or temp_data or data_bus )
        begin
                if( ~en & rd & ~wr )                                //output rd = 1
                        begin
                                reg_data = temp_data;
                        end
                else if( ~en & ~rd & wr )                //input wr = 1
                        begin
                                temp_data = data_bus;
                        end
        end
endmodule
 楼主| zhpg009 发表于 2012-12-28 22:01 | 显示全部楼层
以下是modelsim里面 文件的添加过程
 楼主| zhpg009 发表于 2012-12-28 22:15 | 显示全部楼层
顶起来!!!!!
GoldSunMonkey 发表于 2012-12-28 22:25 | 显示全部楼层
对于A家的东西,我只能把你移动到FPGA版,我无能为力
 楼主| zhpg009 发表于 2012-12-29 20:07 | 显示全部楼层
没事,猴哥。
 楼主| zhpg009 发表于 2012-12-29 20:09 | 显示全部楼层
问题解决了,将 tri_bibuffer.vo 与 测试文件tri_bibuffer_test.v 一起编译,原来是添加文件的时候搞错了!
GoldSunMonkey 发表于 2013-1-3 23:01 | 显示全部楼层
问题解决了,将 tri_bibuffer.vo 与 测试文件tri_bibuffer_test.v 一起编译,原来是添加文件的时候搞错了! ...
哈哈,你不是用XILINX的么?
哈哈,你不是用XILINX的么?
jakfens 发表于 2013-1-4 09:48 | 显示全部楼层
很奇怪 x家的头像 为啥
 楼主| zhpg009 发表于 2013-1-4 10:38 | 显示全部楼层
哈哈,你不是用XILINX的么?
很想用,但手上是Altera的项目。
GoldSunMonkey 发表于 2013-1-4 23:04 | 显示全部楼层
很想用,但手上是Altera的项目。
哈哈,要积极转换啊
 楼主| zhpg009 发表于 2013-1-5 11:51 | 显示全部楼层
哈哈,要积极转换啊
猴哥,你手上有二手的Nexys3的板子没?
GoldSunMonkey 发表于 2013-1-5 23:14 | 显示全部楼层
这个是大学计划的,没有啊
LongChip 发表于 2013-1-12 22:50 | 显示全部楼层
准备买?
 楼主| zhpg009 发表于 2013-1-13 12:20 | 显示全部楼层
准备买?
是啊,你有二手的??
个人签名:进取
16
