给个定点的,浮点就LS办法
public sin_cos ;计算正弦/余弦 public int_sin public count_rad public mul_1632 public mul_32 public _sqrt_int ;计算 R0~R3 中四字节的开方, 结果在R4~R7
math_data0 segment data rseg math_data0 root: ds 4 sinx: ds 4 cosx: ds 4 rad_point: ds 6 ;累加 rad_step 后得到的当前计算采样点弧度.(经处理在 0~Pi/4 之间, 配合 octrant 描述在整圆内位置) rad_step: ds 6 ;每个采样点间隔弧度
; xseg at 0x0200 - 32 * 6 ;channela0_addition: ds 32 ;channela1_addition: ds 32 ;channelb0_addition: ds 32 ;channelb1_addition: ds 32 ;channelc0_addition: ds 32 ;channelc1_addition: ds 32 ;0x0140 ~ 0x01ff ;累加结果缓存, +0~3 为简单累加和, +4~9 为平方和, +16~23 为正弦变换和, +24~31 为余弦变换和, +10~15 暂未使用
math_data1 segment data rseg math_data1 mult: ds 11
octrant: ds 1 ;八分之一圆周.范围为 0~7 ;rad_point: ds 6 ;rad_step: ds 6 ;---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- ;octrant, | sin(x) = | cos(x) = | 累积计算方式 | 整圆位置 = 0 ~ 2 x Pi |rad_point 初始值为 0, octrant = 0 ; | | | | | | | | | | ; 0 | sin (rad_point) | cos (rad_point) | rad_point += rad_step | 0 ~ Pi/4 |当 rad_point >= Pi/4 时 rad_point = Pi/2 - rad_point | octrant ++ (= 1) ; 1 | cos (rad_point) | sin (rad_point) | rad_point -= rad_step | Pi/4 ~ Pi/2 |当 rad_point < 0 即减法产生借位时 rad_point = 0 - rad_point | octrant ++ (= 2) ; 2 | cos (rad_point) | - sin (rad_point) | rad_point += rad_step | Pi/2 ~ Pix3/4 |当 rad_point >= Pi/4 时 rad_point = Pi/2 - rad_point | octrant ++ (= 3) ; 3 | sin (rad_point) | - cos (rad_point) | rad_point -= rad_step | Pix3/4 ~ Pi |当 rad_point < 0 即减法产生借位时 rad_point = 0 - rad_point | octrant ++ (= 4) ; 4 | - sin (rad_point) | - cos (rad_point) | rad_point += rad_step | Pi ~ Pix5/4 |当 rad_point >= Pi/4 时 rad_point = Pi/2 - rad_point | octrant ++ (= 5) ; 5 | - cos (rad_point) | - sin (rad_point) | rad_point -= rad_step | Pix5/4 ~ Pix3/2 |当 rad_point < 0 即减法产生借位时 rad_point = 0 - rad_point | octrant ++ (= 6) ; 6 | - cos (rad_point) | sin (rad_point) | rad_point += rad_step | Pix3/2 ~ Pix7/4 |当 rad_point >= Pi/4 时 rad_point = Pi/2 - rad_point | octrant ++ (= 7) ; 7 | - sin (rad_point) | cos (rad_point) | rad_point -= rad_step | Pix7/4 ~ Pix2 |当 rad_point < 0 即减法产生借位时 rad_point = 0 - rad_point | octrant = 0 ;----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
;advance equ 1024 ;sample_clock equ 98 ;sample_clock equ 106 ;sample_clock equ 162
;sample_time equ 1966080 + advance * sample_clock ;sample_time equ 2133334 + advance * sample_clock ;sample_time equ 3276800 + advance * sample_clock
;每98t@11.0592MHz/106t@12MHz/163t@18.432MHz 采样一点, 即使工频为55Hz时仍可以每周期采样1024点 ;共采样 sample ;即使45Hz时仍可以采样16个周期 ;其中 advance * sample_clock 为冗余, 而且可以剔除前若干点避免转换通道时的信号扰动 ;捕捉测得16周期时间为TimeSample, 则每个采样点的弧度增加值 = 32Pi X sample_clock / TimeSample
math_bit segment bit rseg math_bit mathb0: dbit 1 rad_flag: dbit 1
math_code segment code rseg math_code ;pi4: db 0x69, 0x21, 0xa2, 0xda, 0x0f, 0xc9 ;pi/4 = 3.141592653589793.../4 ;pi2: db 0xd2, 0x42, 0x44, 0xb5, 0x1f, 0x92 ;pi/2 = 3.141592653589793.../2, 最高字节为0x01, 不参加运算 pi4_0 equ 0x69 pi4_1 equ 0x21 pi4_2 equ 0xa2 pi4_3 equ 0xda pi4_4 equ 0x0f pi4_5 equ 0xc9
pi2_0 equ 0xd2 pi2_1 equ 0x42 pi2_2 equ 0x44 pi2_3 equ 0xb5 pi2_4 equ 0x1f pi2_5 equ 0x92 pi2_6 equ 0x01
T_data: db 0x26, 0x7c, 0x08, 0xd9, 0x08, 0x65, 0x0d, 0x2c ;11.0592MHz ;T_data: db 0x29, 0xa0, 0x48, 0x43, 0x90, 0xea, 0xb0, 0x35 ;12.000 MHz ;T_data: db 0x3f, 0x9e, 0x04, 0x2d, 0x4c, 0x92, 0x25, 0x73 ;18.432 MHz ;T_data = sample_clock x 16 x 2Pi x 2^48
fact_table: db 0xab, 0xaa, 0xaa, 0x2a ;1/3! = 1/6 db 0x22, 0x22, 0x22, 0x02 ;1/5! = 1/120 db 0xd0, 0x00, 0x0d, 0x00 ;1/7! = 1/5040 db 0x3c, 0x2e, 0x00, 0x00 ;1/9! = 1/362880 db 0x6c, 0x00, 0x00, 0x00 ;1/11! = 1/39916800 ;(pi/4)^11/11! = 0x00000008 db 0x00, 0x00, 0x00, 0x00 ;--------------------------------------------------------------------------------------------------
TCR20 data 0xC8 TIFR2 data 0xE9 TPCR2H data 0xCB TPCR2L data 0xCA CCCRA data 0xEA ICRAH data 0xAB ;捕捉结果寄存器, 本设计使用 A, 使用中必须先读取 ICRAL, 然后读 ICRAH. ICRAL data 0xAA
OCRAL data 0xEE ;输出比较寄存器, 本设计不使用此功能, 将 CCCRA/B/C/D 相应关闭PWM功能后此八字节可做为内部 RAM 使用. OCRAH data 0xEF OCRBL data 0xFA OCRBH data 0xFB OCRCL data 0xFC OCRCH data 0xFD OCRDL data 0xFE OCRDH data 0xFF
TL2 data 0xCC ;捕捉用定时寄存器 TH2 data 0xCD TOR2L data 0xCE ;重装寄存器 = 0x00 TOR2H data 0xCF
Trig_Cnt equ OCRAL ;初值为 -3, 每次发生捕捉加一, 加为零时正式开始, 加到 16 时完成采样. Trig_1 equ OCRCL ;正式开始时捕捉到的计数值 Trig_0 equ OCRAH Trig_High equ OCRCH ;T2 溢出计数 Trig_Last equ OCRDL ;上次捕捉计数值, 两字节, 连 Trig_Last 一起减去 Trig_0 后即为前次捕捉时间. Trig_Data equ OCRBL ;采样次数累计
rseg math_code
_sqrt_int: ;[r4~7] 四字节开方 --> [r4~7], 速度优化版, 256 Bytes, <= 1829T ;已验证, 准确, 结果有效位30位. ;[r4~7] 为无符号小数, 小数点在最高位前一位 ;破坏 [r0~3], root[0~3], Acc, B, PSW mov r0, 4 mov r1, 5 mov r2, 6 mov r3, 7 clr a mov r4, #1 mov r5, a mov r6, a mov r7, a mov root, a mov root + 1, a mov root + 2, a mov root + 3, a ;0 --> [r4~r7], root(0~3) mov b, a mov a, r3 ;r3 = 0 jz sqr_l1
sqr_l0: mov a, r3 rlc a mov r3, a mov a, root rlc a mov root, a inc b jb b.0, sqr_l0 ;r3 >> 2 --> root
subb a, r4 jc sqr1b ;root - r4 >= 0? mov root, a ;Y. inc r4 inc r4 sqr1b: dec r4 mov a, r4 setb c rlc a mov r4, a ;r4 >> 1 jnb b.3, sqr_l0 ;4 times = 1 byte
clr b.3 sqr_l1: mov a, r1 rlc a mov r1, a mov a, r2 rlc a mov r2, a mov a, root rlc a mov root, a mov a, root + 1 rlc a mov root + 1, a inc b jb b.0, sqr_l1 ;[r1r2] >> 2 --> root(0~1)
mov a, root subb a, r4 mov a, root + 1 subb a, r5 jc sqr2b ;root(0~1) - r4r5 >= 0? mov root + 1, a ;Y mov a, root subb a, r4 mov root, a inc r4 inc r4 sqr2b: dec r4 mov a, r4 setb c rlc a mov r4, a mov a, r5 rlc a mov r5, a ;r4r5 >> 1 jnb b.4, sqr_l1 ;8 times
mov b, #(0x10 - 10) * 2 sqr_l2: clr c mov a, r0 rlc a mov r0, a mov a, root rlc a mov root, a mov a, root + 1 rlc a mov root + 1, a mov a, root + 2 rlc a mov root + 2, a inc b jb b.0, sqr_l2
mov a, root subb a, r4 mov a, root + 1 subb a, r5 mov a, root + 2 subb a, r6 jc sqr3b mov root + 2, a clr c mov a, root subb a, r4 mov root, a mov a, root + 1 subb a, r5 mov root + 1, a inc r4 inc r4 sqr3b: dec r4 setb c mov a, r4 rlc a mov r4, a mov a, r5 rlc a mov r5, a mov a, r6 rlc a mov r6, a jnb b.5, sqr_l2 ;10 times
mov b, #0x10 - 2 sqr_l3: clr c mov a, root rlc a mov root, a mov a, root + 1 rlc a mov root + 1, a mov a, root + 2 rlc a mov root + 2, a mov a, root + 3 rlc a mov root + 3, a inc b jb b.0, sqr_l3
clr c mov a, root subb a, r4 mov a, root + 1 subb a, r5 mov a, root + 2 subb a, r6 mov a, root + 3 subb a, r7 jc sqr4b mov root + 3, a mov a, root subb a, r4 mov root, a mov a, root + 1 subb a, r5 mov root + 1, a mov a, root + 2 subb a, r6 mov root + 2, a inc r4 inc r4 sqr4b: dec r4 jb b.5, sqrfinish setb c ;根左移一位, 并加一 mov a, r4 rlc a mov r4, a mov a, r5 rlc a mov r5, a mov a, r6 rlc a mov r6, a mov a, r7 rlc a mov r7, a sjmp sqr_l3 ;9 times sqrfinish: mov a, r4 ;四舍五入 :-P setb acc.1 mov r4, a ret
mul_1632: ;r0r1 X mult[0~3] --> r2~r7; ;101 bytes; <= 108t ;未验证, 冒然使用后果自负! ;破坏 Acc, B, F0, PSW mov a, mult ;a0 X b0 mov b, r0 mul ab mov r2, a mov r3, b mov a, mult + 2 ;a2 X b0 mov b, r0 mul ab mov r4, a mov r5, b mov a, mult + 3 ;a3 X b1 ;a0b0, a2b0, a3b1 --> r2~r7 mov b, r1 mul ab mov r6, a mov r7, b
mov a, mult ;a0 X b1 mov b, r1 mul ab add a, r3 mov r3, a mov a, b addc a, r4 mov r4, a mov f0, c mov a, mult + 2 ;a2 X b1 mov b, r1 mul ab mov c, f0 addc a, r5 mov r5, a mov a, b addc a, r6 mov r6, a jnc $ + 3 inc r7 ;a0b0, a0b1, a2b0, a2b1, a3b1
mov a, mult + 1 ;a1 X b0 mov b, r0 mul ab add a, r3 mov r3, a mov a, b addc a, r4 mov r4, a mov f0, c mov a, mult + 3 ;a3 X b0 mov b, r0 mul ab mov c, f0 addc a, r5 mov r5, a mov a, b addc a, r6 mov r6, a jnc $ + 3 inc r7 ;a0b0, a0b1, a1b0, a2b0, a2b1, a3b0, a3b1
mov a, mult + 1 ;a1 X b1 ;a0b0, a0b1, a1b0, a1b1, a2b0, a2b1, a3b0, a3b1 mov b, r1 mul ab add a, r4 mov r4, a mov a, b mul_160:addc a, r5 mov r5, a jnc $ + 7 inc r6 mov a, r6 jnz $ + 3 inc r7 ret
mul_32: ;mul[t0~3] X mult[4~7] --> r0~7; ;46 bytes, <= 267T ;不需要验证了吧 :-P ;破坏 [mult(4~9)], Acc, B, F0, PSW mov r0, mult + 4 mov r1, mult + 5 lcall mul_1632 mov r0, mult + 6 mov r1, mult + 7 mov mult + 4, r2 mov mult + 5, r3 mov mult + 6, r4 mov mult + 7, r5 mov mult + 8, r6 mov mult + 9, r7 lcall mul_1632 mov r0, mult + 4 mov r1, mult + 5 mov a, mult + 6 add a, r2 mov r2, a mov a, mult + 7 addc a, r3 mov r3, a mov a, mult + 8 addc a, r4 mov r4, a mov a, mult + 9 sjmp mul_160
int_sin: ; sin(x) = x - x^3/3! + x^5/5! - x^7/7! + x^9/9! - x^11/11! ..., x 单位为弧度(rad) ;为加快运算速度及减少代码量, 特经预处理使 x = (0 ~ Pi/4) ;原理是当 x = (Pi/4 ~ Pi/2) 时 sin(x) = cos(Pi/2 - x) 成立 ;其他象限各区间也都有类似等式成立 ;x = [r4~7] ; 205 bytes; <=3006T ;已验证, 准确, 结果有效位31位 mov a, r4 mov mult + 0, a mov mult + 4, a mov sinx + 0, a mov root + 0, a mov a, r5 mov mult + 1, a mov mult + 5, a mov sinx + 1, a mov root + 1, a mov a, r6 mov mult + 2, a mov mult + 6, a mov sinx + 2, a mov root + 2, a mov a, r7 mov mult + 3, a mov mult + 7, a mov sinx + 3, a mov root + 3, a ; 种子 x --> sinx(0~3), mult(0~3), mult(4~7), root(0~3) lcall mul_32 ; x^2 mov cosx + 0, r4 mov cosx + 1, r5 mov cosx + 2, r6 mov cosx + 3, r7 ; x^2 --> cosx(0~3) mov mult + 10, #0
int_sin_loop: mov mult + 0, root + 0 mov mult + 1, root + 1 mov mult + 2, root + 2 mov mult + 3, root + 3 ;x^n mov mult + 4, cosx + 0 mov mult + 5, cosx + 1 mov mult + 6, cosx + 2 mov mult + 7, cosx + 3 ;x^2 lcall mul_32 ; x^n X x^2 mov a, r4 mov mult + 0, a mov root + 0, a mov a, r5 mov mult + 1, a mov root + 1, a mov a, r6 mov mult + 2, a mov root + 2, a mov a, r7 mov mult + 3, a mov root + 3, a ; x^n --> root(0~3), mult(0~3)
mov dptr, #fact_table mov a, mult + 10 mov r0, a movc a, @a + dptr mov mult + 4, a inc r0 mov a, r0 movc a, @a + dptr mov mult + 5, a inc r0 mov a, r0 movc a, @a + dptr mov mult + 6, a inc r0 mov a, r0 movc a, @a + dptr mov mult + 7, a ; 1/n! --> mult(4~7) inc r0 mov a, r0 mov mult + 10, a jnb acc.4, int_sin_xxxx mov r0, mult + 4 mov r1, mult + 5 lcall mul_1632 mov r3, 5 mov r4, 6 mov r5, 7 clr a mov r6, a mov r7, a sjmp $ + 5 int_sin_xxxx: lcall mul_32 ; x^n/n! mov a, r4 orl a, r5 orl a, r6 orl a, r7 jz int_sin_exit
mov a, r3 rlc a mov a, mult + 10 jnb acc.2, add_xn sub_xn: mov a, sinx + 0 subb a, r4 mov sinx + 0, a mov a, sinx + 1 subb a, r5 mov sinx + 1, a mov a, sinx + 2 subb a, r6 mov sinx + 2, a mov a, sinx + 3 subb a, r7 mov sinx + 3, a ; x - x^n/n! ljmp int_sin_loop add_xn: mov a, sinx + 0 addc a, r4 mov sinx + 0, a mov a, sinx + 1 addc a, r5 mov sinx + 1, a mov a, sinx + 2 addc a, r6 mov sinx + 2, a mov a, sinx + 3 addc a, r7 mov sinx + 3, a ; x + x^n/n! ljmp int_sin_loop int_sin_exit: ret
sin_cos: ;|cos (x)| = sqrt [1 - sin (x) ^ 2] ;sin(x)^2 + cos(x)^2 = 1
lcall int_sin
mov a, sinx mov mult, a mov mult + 4, a mov a, sinx + 1 mov mult + 1, a mov mult + 5, a mov a, sinx + 2 mov mult + 2, a mov mult + 6, a mov a, sinx + 3 mov mult + 3, a mov mult + 7, a lcall mul_32 ;sin (x) ^ 2
clr a setb c subb a, r4 mov r4, a clr a subb a, r5 mov r5, a clr a subb a, r6 mov r6, a clr a subb a, r7 mov r7, a ; 1 - sin (x) ^ 2 lcall _sqrt_int
mov cosx, r4 mov cosx + 1, r5 mov cosx + 2, r6 mov cosx + 3, r7 ;|cos (x)| = sqrt [1 - sin (x) ^ 2]
ret
end
/************************************************************************************************** frequency: ;TimeSample = [r4 ~ 6], 计算频率, 结果为浮点数 --> [r4~7]. ;可以直接用C写. mov mult + 1, r4 mov mult + 2, r5 mov mult + 3, r6
mul_32_1: ;mul[t0~3] X mult[4~7] --> r0~7 ; <= 229T, ;太长, 速度未快很多, 淘汰. mov a, mult mov b, mult + 4 mul ab mov r0, a mov r1, b mov a, mult + 1 mov b, mult + 5 mul ab mov r2, a mov r3, b mov a, mult + 2 mov b, mult + 6 mul ab mov r4, a mov r5, a mov a, mult + 3 mov b, mult + 7 mul ab mov r6, a mov r7, b ;IV 36
mov a, mult mov b, mult + 5 mul ab add a, r1 mov r1, a mov a, b addc a, r2 mov r2, a mov f0, c mov a, mult + 1 mov b, mult + 6 mul ab mov c, f0 addc a, r3 mov r3, a mov a, b addc a, r4 mov r4, a mov f0, c mov a, mult + 2 mov b, mult + 7 mul ab mov c, f0 addc a, r5 mov r5, a mov a, b addc a, r6 mov r6, a jnc $ + 3 inc r7 ;III 0 45
mov a, mult + 1 mov b, mult + 4 mul ab add a, r1 mov r1, a mov a, b addc a, r2 mov r2, a mov f0, c mov a, mult + 2 mov b, mult + 5 mul ab mov c, f0 addc a, r3 mov r3, a mov a, b addc a, r4 mov r4, a mov f0, c mov a, mult + 3 mov b, mult + 6 mul ab mov c, f0 addc a, r5 mov r5, a mov a, b addc a, r6 mov r6, a jnc $ + 3 inc r7 ;III 1 45
mov a, mult mov b, mult + 6 mul ab add a, r2 mov r2, a mov a, b addc a, r3 mov r3, a mov f0, c mov a, mult + 1 mov b, mult + 7 mul ab mov c, f0 addc a, r4 mov r4, a mov a, b addc a, r5 mov r5, a mov mathb0, c ;II 0 28
mov a, mult + 2 mov b, mult + 4 mul ab add a, r2 mov r2, a mov a, b addc a, r3 mov r3, a mov f0, c mov a, mult + 3 mov b, mult + 5 mul ab mov c, f0 addc a, r4 mov r4, a mov a, b addc a, r5 mov r5, a clr a rlc a mov c, mathb0 addc a, r6 mov r6, a jnc $ + 3 inc r7 ;II 1 36
mov a, mult mov b, mult + 7 mul ab add a, r3 mov r3, a mov a, b addc a, r4 mov f0, c ;I 0 mov a, mult + 3 mov b, mult + 4 mul ab add a, r3 mov r3, a mov a, b addc a, r4 mov r4, a ;I 1 clr a rlc a mov c, f0 addc a, r5 mov r5, a jnc $ + 7 inc r6 mov a, r6 jnz $ + 3 inc r7 ;I 37 ret
_sqrt_int: ;[r0~3] 四字节开方 --> [r4~7], 代码精简版, 113 Bytes, <= 2994T ;已验证, 准确, 结果有效位30位. 太慢, 淘汰. clr a mov r4, #0x01 mov r5, a mov r6, a mov r7, a mov root, a mov root + 1, a mov root + 2, a mov root + 3, a
mov b, #0x03 sqrdec0:clr c ;原数左移两位至余数 mov a, r0 ;原数 rlc a mov r0, a mov a, r1 rlc a mov&n
