医疗应用指南 2010 (Rev. E)
1098|0
叶叶叶一|  楼主 | 2013-6-24 14:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ev, AN, TI, AD, IO
This white paper discusses the advantages of using the C6474 over a C6455, and, in addition, the advantages of using the C6474 over three C6455s. The latter comparison is significant since the C6474 effectively implements the processing power of three C6455s on a single chip,potentially replacin g three C6455s. These and other significant advantages of using the C6474 over a C6455 are discussed in detail in the remainder of this white paper. Additional documents discuss application migration from the C6455 to the C6474, and porting and debugging code for a multi-core DSP application.
