STM32F4双ADC采样ADC2无数据
4865|8
 楼主| baixichi 发表于 2013-8-19 15:07 | 显示全部楼层 |阅读模式
最近在调STM32F439的板子,想用双ADC同时采样,发现ADC1数据正常,ADC2无数据,求大神指点。
下边是程序代码:
uint16_t ADC_Value[8];
#define ADC1_DR_ADDR  0x4001204C      //ADC1_DR 地址
static void Init_ADC_GPIO(void)
    GPIO_InitTypeDef  GPIO_InitStructure;
                ADC1-8个通道  ADC2-8个通道
                   ADC1_IN0~IN7--PA0~PA7
                   ADC2_IN8~IN9--PB0~PB1
                   ADC2_IN10~IN15--PC0~PC5
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
    GPIO_InitStructure.GPIO_Pin = (uint16_t)0x00ff;//PA0~PA7
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = (uint16_t)0x0003;//PB0~PB1
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = (uint16_t)0x003f;//PC0~PC5
    GPIO_Init(GPIOC, &GPIO_InitStructure);
//DMA2
static void Init_DMA2_Channel0_Stream0(void)
    DMA_InitTypeDef DMA_InitStructure;
    int i = 0;
    for(i=0;i<8;i++)   //初始化ADC_Value
        ADC_Value = 0;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
    DMA_DeInit(DMA2_Stream0);
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDR;
    DMA_InitStructure.DMA_Memory0BaseAddr = (unsigned int)ADC_Value;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = 8;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    DMA_Cmd(DMA2_Stream0, ENABLE);
void Init_ADC(void)
    ADC_InitTypeDef ADC_InitStructure;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    Init_ADC_GPIO();
    Init_DMA2_Channel0_Stream0();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
    ADC_DeInit();
    //初始化ADC Common
    ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_3;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
    ADC_CommonInit(&ADC_CommonInitStructure);
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_8b;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    //ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfConversion = 8;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_Init(ADC2, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_8, 1, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_9, 2, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_10, 3, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 4, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 5, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_13, 6, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_14, 7, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, ADC_Channel_15, 8, ADC_SampleTime_15Cycles);
    ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
    ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
    ADC_DMARequestAfterLastTransferCmd(ADC2, ENABLE);
    ADC_DMACmd(ADC1, ENABLE);//使能ADC1_DMA
    ADC_DMACmd(ADC2, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_Cmd(ADC2, ENABLE);
 楼主| baixichi 发表于 2013-8-22 21:55 | 显示全部楼层
0回复。。。
mkmklyuyu 发表于 2013-8-23 10:35 | 显示全部楼层
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |RCC_APB2Periph_AFIO,ENABLE );
 楼主| baixichi 发表于 2013-9-4 21:59 | 显示全部楼层
原来是DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDR;这里出错了
不应该是ADC1_DR的地址,应该是ADC1_CDR的地址
624773416 发表于 2014-4-6 12:23 | 显示全部楼层
不应该是ADC1_DR的地址,应该 ...
你这句话什么意思?
ADC1_CDR是哪儿来的
johngray 发表于 2014-4-6 18:29 | 显示全部楼层
2065558019 发表于 2015-4-26 22:18 | 显示全部楼层
楼主,您好,可以把STM32双ADC采样数据的代码发给我么?
2065558019 发表于 2015-4-26 22:19 | 显示全部楼层
我邮箱2065558019@qq.com  ,谢谢了
春天里打滚儿 发表于 2015-10-13 17:20 | 显示全部楼层
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDR;这句应该写成DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR;如果就用楼主的变量ADC1_DR_ADDR,那就在程序开头定义一个vu32 ADC1_DR_ADDR = ADC1_BASE + 0x4C;其中,ADC1_BASE是指ADC1的外设基地址,0x4C是寄存器DR的偏移地址,两种方式等效。
个人签名:在锦瑟年华里,过鲜衣怒马生活
