[FPGA] 在仿真Virtex7系列FPGA的TEMAC的IP核时候出现错误
1162|0
 楼主| dingning123 发表于 2014-3-25 15:05 | 显示全部楼层 |阅读模式
你好 我在调用DO文件在modelsim里面对Virtex7系列FPGA的TEMAC的IP核进行例子仿真的时候出现如下的问题:
在仿真到demo_tb_vhd的第1259行时出现中断,
modelsim的脚本文件显示:#    Time:592924680 ps  Iteration: 1  Process: /demo_tb/p_stimulus File:../demo_tb.vhd
# Break in Process p_stimulus at ../demo_tb.vhd line1259
# Simulation Breakpoint: Break in Process p_stimulusat ../demo_tb.vhd line 1259
# MACRO ./simulate_mti.do PAUSED at line 48
对应的demo_tb_vhd的程序为
   -- Wait for 1G monitor process to complete.
    wait until tx_monitor_finished_1G;
    rx_stimulus_finished <= true;
    -- Our work here is done
    assert false
      report "Simulation stopped"
      severity failure;
  end process p_stimulus;
我想知道为什么会中断,中断之后的如下程序是干什么用的,怎么利用如下的程序接着进行仿真。
  -- Monitor process. This process checks the data coming out of the
  -- transmitter to make sure that it matches that inserted into the
  -- receiver.
  p_monitor : process
    -- Procedure to check a transmitted frame at 1Gb/s
    procedure check_frame_1g (current_frame : in natural) is
      variable current_col   : integer := 0;  -- Column counter within frame
      variable fcs           : std_logic_vector(31 downto 0);
      variable frame_type    : string(1 to 4) := (others => ' ');
