[Kinetis] k60 矩阵键盘扫描问题
3307|12
 楼主| 774729254 发表于 2014-8-9 10:45 | 显示全部楼层 |阅读模式
uint8 KBPin[8]= {23,22,21,20,19,18,17,16};
PORTx KB_Port[8]={PORTB,PORTB,PORTB,PORTB,PORTB,PORTB,PORTB,PORTB};
void KBInit(void)
    uint8 i;
    for(i = 0;i < 4;i++)//
            gpio_init (KB_Port[i], KBPin[i], GPI_UP, 0);
     for(i = 4;i < 8;i++)
          gpio_init (KB_Port[i], KBPin[i], GPO_HDS,0);
//函数名称:KBScanN
//函数返回:多次扫描键盘得到的键值
//参数说明:重复扫描键盘的的次数(KB_count)
//功能概要:多次扫描键盘,消除"抖动"。
uint8 KBScanN(uint8 KB_count)
    uint8 i,KB_value_last,KB_value_now;
    // 先扫描一次得到的键值,便于下面比较
    if (0 == KB_count || 1 == KB_count)
        return KBScan1();
    KB_value_now = KB_value_last = KBScan1();
    //以下多次扫描消除误差
    for (i=0; i<KB_count-1; i++)
        KB_value_now = KBScan1();
        if (KB_value_now == KB_value_last)
            return KB_value_now;                       //返回扫描的键值
        else
            KB_value_last = KB_value_now;
    // 返回出错标志
    return 0xFF;
//函数名称:KBDef
//函数返回:无
//参数说明:键值valve
//功能概要:键值转为定义值函数。
//键盘定义表
//键盘定义表
const uint8 KBtable[] =
    0xEE,8,0xDE,9,0xBE,10,0x7E,11,
    0xED,5,0xDD,6,0xBD,7,0x7D,12,
    0xEB,2,0xDB,3,0xBB,4,0x7B,13,
    0xE7,0,0xD7,14,0xB7,1,0x77,15,
    0x00
uint8 KBDef(uint8 valve)
    uint8 KeyPress;                       //键定义值
    uint8 i;
    i = 0;
    KeyPress = 0xff;
    while (KBtable[i] != 0x00)         //在键盘定义表中搜索欲转换的键值,直至表尾
        if(KBtable[i] == valve)        //在表中找到相应的键值
            KeyPress = KBtable[i+1];   //取出对应的键定义值
            break;
        i += 2;                                        //指向下一个键值,继续判断
    return KeyPress;
//函数名称:KBScan1
//函数返回:扫描到的键值
//参数说明:键值valve
//功能概要:扫描1次4*4键盘,返回扫描到的键值,若无按键,返回0xff 。
uint8 KBScan1(void)
    uint8 i,j,tmp=0xFF;
    uint8 k = 0;//
    KBInit();                //键盘初始化
    for (i = 0; i <= 3; i++) //最多将扫描4根行线
        if((GPIO_PDIR_REG(GPIOx[KB_Port[i]]) & (1<<KBPin[i])) == 0)//GPIO_PDIR数据端口输入寄存器
                for(j = 4;j <8;j++)
                        gpio_set(KB_Port[j],KBPin[j],1);
                        for(k = 0;k <100;k++)
                            asm("NOP");
                        if((GPIO_PDIR_REG(GPIOx[KB_Port[i]]) & (1<<KBPin[i])) != 0)
                            if(i == 0)
                                    if(j == 4)
                                            tmp = 0xEE;
                                    else if(j == 5)
                                            tmp = 0xDE;
                                    else if(j == 6)
                                            tmp = 0xBE;
                                    else if(j == 7)
                                            tmp = 0x7E;
                            else if(i == 1)
                                    if(j == 4)
                                            tmp = 0xED;
                                    else if(j == 5)
                                            tmp = 0xDD;
                                    else if(j == 6)
                                            tmp = 0xBD;
                                    else if(j == 7)
                                            tmp = 0x7D;
                            else if(i == 2)
                                    if(j == 4)
                                            tmp = 0xEB;
                                    else if(j == 5)
                                            tmp = 0xDB;
                                    else if(j == 6)
                                            tmp = 0xBB;
                                    else if(j == 7)
                                            tmp = 0x7B;
                            else if(i == 3)
                                    if(j == 4)
                                            tmp = 0xE7;
                                    else if(j == 5)
                                            tmp = 0xD7;
                                    else if(j == 6)
                                            tmp = 0xB7;
                                    else if(j == 7)
                                            tmp = 0x77;
                            else
                                    tmp = 0x00;
                            break;
                        gpio_set(KB_Port[j],KBPin[j],0);
    for(k=0;k<=80;k++)asm("NOP");
    return (tmp);
以上是矩阵键盘扫描程序,现在我的问题是temp=0x7d.0x7b.0x77对应的3个键,当按下时,时而有效,时而无效,而其他所有按键都很灵敏,有人遇到过类似问题吗?请指教
攻城狮 发表于 2014-8-11 09:42 | 显示全部楼层
楼主,
没有人会细心看你的代码的,网友只会针对你的软件设计思想,提出针对性的解决意见的。
所以你可以最好介绍一下你的设计思想,不要把满屏的代码贴出来。
FSL_TICS_Jeremy 发表于 2014-8-11 14:36 | 显示全部楼层
你好,楼主!
请简单介绍一下程序设计的思想,单看代码我不好提供意见,2楼说的很对!
jd972594 发表于 2014-8-12 09:20 | 显示全部楼层
果然这么多代码看的有点摸不着头脑,你这代码看上去好累啊就不能换成switch case形式吗?
试一下这样修改后,temp=0x7d.0x7b.0x77对应的3个键还会那样吗?
                            else if(i == 1)
                                    if(j == 7)
                                            tmp = 0x7D;
                                    else if(j == 5)
                                            tmp = 0xDD;
                                    else if(j == 6)
                                            tmp = 0xBD;
                                    else if(j == 4)
                                            tmp = 0xED;
                            else if(i == 2)
                                    if(j == 7)
                                            tmp = 0x7B;
                                    else if(j == 5)
                                            tmp = 0xDB;
                                    else if(j == 6)
                                            tmp = 0xBB;
                                    else if(j == 4)
                                            tmp = 0xEB;
                            else if(i == 3)
                                    if(j == 7)
                                            tmp = 0x77;
                                    else if(j == 5)
                                            tmp = 0xD7;
                                    else if(j == 6)
                                            tmp = 0xB7;
                                    else if(j == 4)
                                            tmp = 0xE7;
 楼主| 774729254 发表于 2014-8-13 09:31 | 显示全部楼层
楼主,
所以你可以最 ...
你好,程序所用的就是矩阵键盘的思想,设置行为输入,列为输出,只是有一列常常不能被正确识别,有时很灵敏,有时需要按很多次才被识别,问题基本就是这样,再次感谢你
你好,楼主!
请简单介绍一下程序设计的思想,单看代码我不好提供意见,2楼说的很对! ...
 楼主| 774729254 发表于 2014-8-13 09:33 | 显示全部楼层
试一下这样修改后 ...
好的,请问这样改的原理是啥,与扫描顺序有关还是?
FSL_TICS_Jeremy 发表于 2014-8-13 14:12 | 显示全部楼层
你好,程序所用的就是矩阵键盘的思想,设置行为输入,列为输出,只是有一列常常不能被正确识别,有时很灵 ...
想你这样的问题,我估计就不单单是程序代码的问题啊,你有没有用示波器看过按键按下时的波形变化,看看有问题的几个按键与正常的几个波形有什么区别
 楼主| 774729254 发表于 2014-8-14 09:06 | 显示全部楼层
试一下这样修改后 ...
你好,已经按照你的思路进行修改,还是不行啊,问题会出在硬件吗
攻城狮 发表于 2014-8-14 09:44 | 显示全部楼层
既然只有一列有问题,而且不是功能无法实现,而是实现过程有些怪的话,我想你有必要检查下硬件啊。
可以参考8楼斑竹的意见试试。
 楼主| 774729254 发表于 2014-8-14 12:29 | 显示全部楼层
现在问题解决了,谢谢楼上的几位,我的问题不管那一列作为扫描的最后一列输出,结果都有问题,现在我用的是最笨的方法,做成4×5的键盘,输出5列,最后一列空扫不做任何操作,这样的出现的问题就逃避掉了,哈哈
攻城狮 发表于 2014-8-15 09:56 | 显示全部楼层
现在问题解决了,谢谢楼上的几位,我的问题不管那一列作为扫描的最后一列输出,结果都有问题,现在我用的是 ...
恩,看看软件扫描到最后一列是不是有一个共性问题啊,虽然现在不影响应用,但还是可以要找出原因啊
jd972594 发表于 2014-8-26 09:20 | 显示全部楼层
就是怀疑你的程序写的有问题,所以让你这么修改一下的。
因为键盘硬件不复杂,一般不会出现大问题。
