[讨论] STM32经IIC与OLED通信
4806|9
 楼主| crystal1987 发表于 2014-11-20 10:31 | 显示全部楼层 |阅读模式
请高手帮忙分析一下代码,看看那里有问题,现在代码能够烧写正常,也能运行,指示灯闪烁,就是OLED屏不能点亮?
#define SCL_HIGH  GPIO_ResetBits(GPIOB, GPIO_Pin_8)
#define SCL_LOW   GPIO_SetBits(GPIOB, GPIO_Pin_8)
#define SDA_HIGH  GPIO_ResetBits(GPIOB, GPIO_Pin_9)
#define SDA_LOW   GPIO_SetBits(GPIOB, GPIO_Pin_9)
void IIC_InitFunc(void)
        I2C_InitTypeDef  I2C_InitStructure;
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
        /* PB8,9 SCL and SDA */
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8 | GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
    I2C_DeInit(I2C1);
    I2C_InitStructure.I2C_Mode = I2C_Mode_SMBusDevice;//I2C_Mode_SMBusHost; //I2C_Mode_I2C;
    I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStructure.I2C_OwnAddress1 = 0x30;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_ClockSpeed = 100000;//100K速度
        I2C_Cmd(I2C1, ENABLE);
        I2C_Init(I2C1, &I2C_InitStructure);
        /*允许1字节1应答模式*/
        I2C_AcknowledgeConfig(I2C1, ENABLE);
void OLED_Initial()
        Write_IIC_Command(0xAE);   //display off
        Write_IIC_Command(0x20); //Set Memory Addressing Mode
        Write_IIC_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        Write_IIC_Command(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
        Write_IIC_Command(0xc8); //Set COM Output Scan Direction
        Write_IIC_Command(0x00);//---set low column address
        Write_IIC_Command(0x10);//---set high column address
        Write_IIC_Command(0x40);//--set start line address
        Write_IIC_Command(0x81);//--set contrast control register
        Write_IIC_Command(0x7f);
        Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
        Write_IIC_Command(0xa6);//--set normal display
        Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
        Write_IIC_Command(0x3F);//
        Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        Write_IIC_Command(0xd3);//-set display offset
        Write_IIC_Command(0x00);//-not offset
        Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
        Write_IIC_Command(0xf0);//--set divide ratio
        Write_IIC_Command(0xd9);//--set pre-charge period
        Write_IIC_Command(0x22); //
        Write_IIC_Command(0xda);//--set com pins hardware configuration
        Write_IIC_Command(0x12);
        Write_IIC_Command(0xdb);//--set vcomh
        Write_IIC_Command(0x20);//0x20,0.77xVcc
        Write_IIC_Command(0x8d);//--set DC-DC enable
        Write_IIC_Command(0x14);//
        Write_IIC_Command(0xaf);//--turn on oled panel
//IIC Start
void IIC_Start()
   SCL_HIGH;
   //Delay_us(1);
   SDA_HIGH;
   //Delay_us(1);
   SDA_LOW;
  // Delay_us(1);
   SCL_LOW;
  // Delay_us(1);
//IIC Stop
void IIC_Stop()
   SCL_LOW;
   //Delay_us(1);
   SDA_LOW;
   //Delay_us(1);
    SCL_HIGH;
   //Delay_us(1);
   SDA_HIGH;
   //Delay_us(1);
// IIC Write byte
void Write_IIC_Byte(unsigned char IIC_Byte)
        unsigned char i;
        for(i=0;i<8;i++)
                  if(IIC_Byte & 0x80)  //1?0?
                   SDA_HIGH;
                  else
                   SDA_LOW;
                  //Delay_us(1);
                   SCL_HIGH;
                  //Delay_us(1);
                   SCL_LOW;
                  //Delay_us(1);
                  IIC_Byte<<=1;   //loop
        SDA_HIGH;
        //Delay_us(1);
        SCL_HIGH;
        //Delay_us(1);
        SCL_LOW;
        //Delay_us(1);
// IIC Write Command
void Write_IIC_Command(unsigned char IIC_Command)
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00);   //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
void Write_IIC_Data(unsigned char IIC_Data)
   IIC_Start();
   Write_IIC_Byte(0x40);   //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
// fill_Picture
void fill_picture(unsigned char fill_Data)
unsigned char m,n;
for(m=0;m<8;m++)
  Write_IIC_Command(0xb0+m);  //page0-page1
  Write_IIC_Command(0x00);  //low column start address
  Write_IIC_Command(0x10);  //high column start address
  for(n=0;n<128;n++)
    Write_IIC_Data(fill_Data);
// picture
void Picture_1()
  unsigned char x,y;
// unsigned int i=0;
  for(y=0;y<8;y++)
      Write_IIC_Command(0xb0+y);
      for(x=0;x<128;x++)
          Write_IIC_Data(show1[x++]);
/***********************Delay****************************************/
void Delay_50ms(unsigned int Del_50ms)  //
        unsigned int m;
        for(;Del_50ms>0;Del_50ms--)
                  for(m=6245;m>0;m--);
void Delay_1ms(unsigned int Del_1ms)  //
        unsigned char j;
        while(Del_1ms--)
                  for(j=0;j<123;j++);
int main(void)
    LED_GPIO_Config();
        delay_init(72);             //延时初始化
        IIC_InitFunc();
        OLED_Initial();
        while(1)
                LED4_OFF;
                delay_ms(500); //延时1s
                LED4_ON;
                fill_picture(0xff); delay_ms(1500);
                fill_picture(0xf0); delay_ms(1500);
                Picture_1();  Delay_50ms(1500);
 楼主| crystal1987 发表于 2014-11-20 10:34 | 显示全部楼层
从网上查的资料说,好像是初始化的问题;但是自己还没有找到问题的关键,请各位大侠高手帮忙。
gaochy1126 发表于 2014-11-20 11:34 | 显示全部楼层
楼主好像发错地方了。应该发在st版块的
gaochy1126 发表于 2014-11-20 11:36 | 显示全部楼层
检查一下电路对不对,一般用模拟iic,操作更熟悉一些
 楼主| crystal1987 发表于 2014-11-26 16:21 | 显示全部楼层
模拟的IIC有问题,你应该知道的。
楼主好像发错地方了。应该发在st版块的
不好意思
摩天轮1111 发表于 2015-9-12 21:26 | 显示全部楼层
从网上查的资料说,好像是初始化的问题;但是自己还没有找到问题的关键,请各位大侠高手帮忙。 ...
点不亮屏幕多半我感觉是显示屏操作指令的错误,我还发现显示屏的网上资料怎么就是找不到呢?淘宝卖家都有,可是网上就是找不到,这可真是奇了个怪了,楼主能共享下你的显示屏的说明书资料吗?不然估计没法看你是程序出问题还是控制显示屏指令出问题,,
 楼主| crystal1987 发表于 2015-9-14 15:55 | 显示全部楼层
点不亮屏幕多半我感觉是显示屏操作指令的错误,我还发现显示屏的网上资料怎么就是找不到呢?淘宝卖家都有 ...
谢谢,问题已解决。是IO口的输出频率,我将50MHZ修改成2MHZ之后,屏就点亮啦。
