MSP430F5529 硬件IIC通信 SCL引脚输出为低电平?
6473|45
 楼主| rui199009 发表于 2015-5-27 15:56 | 显示全部楼层 |阅读模式
用MSP430F5529和adxl345硬件iic通信时,发现msp430iic的SCL引脚不能输出正确的时钟,后来以为代码的问题,所以用了官方的代码,但是还是输出为低电平。求解。
 楼主| rui199009 发表于 2015-5-27 15:58 | 显示全部楼层
官方代码
//  MSP430F552x Demo - USCI_B0 I2C Master RX single bytes from MSP430 Slave
//  Description: This demo connects two MSP430's via the I2C bus. The master
//  reads from the slave. This is the MASTER CODE. The data from the slave
//  transmitter begins at 0 and increments with each transfer. The received
//  data is in R5 and is checked for validity. If the received data is
//  incorrect, the CPU is trapped and the P1.0 LED will stay on. The USCI_B0
//  RX interrupt is used to know when new data has been received.
//  ACLK = n/a, MCLK = SMCLK = BRCLK = default DCO = ~1.045MHz
// ***to be used with "MSP430F55xx_uscib0_i2c_05.c" ***
//               MSP430F5529      10k  10k     MSP430F5529
//                   slave         |    |        master
//           -|XIN  P3.0/UCB0SDA|<-|----+->|P3.0/UCB0SDA  XIN|-
//            |                 |  |       |                 | 32kHz
//           -|XOUT             |  |       |             XOUT|-
//            |     P3.1/UCB0SCL|<-+------>|P3.1/UCB0SCL     |
//            |                 |          |             P1.0|--> LED
//   Bhargavi Nisarga
//   Texas Instruments Inc.
//   April 2009
//   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
#include <msp430.h>
unsigned char RXData;
unsigned char RXCompare;
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1OUT &= ~0x01;                           // P1.0 = 0
  P1DIR |= 0x01;                            // P1.0 output
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x48;                         // Slave Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCRXIE;                         // Enable RX interrupt
  RXCompare = 0x0;                          // Used to check incoming data
  while (1)
    while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
    UCB0CTL1 |= UCTXSTT;                    // I2C start condition
    while(UCB0CTL1 & UCTXSTT);              // Start condition sent?
    UCB0CTL1 |= UCTXSTP;                    // I2C stop condition
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0, enable interrupts
    __no_operation();                       // For debugger
    if (RXData != RXCompare)                // Trap CPU if wrong
      P1OUT |= 0x01;                        // P1.0 = 1
      while(1);
    RXCompare++;                            // Increment correct RX value
// USCI_B0 Data ISR
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#error Compiler not supported!
#endif
  switch(__even_in_range(UCB0IV,12))
  case  0: break;                           // Vector  0: No interrupts
  case  2: break;                           // Vector  2: ALIFG
  case  4: break;                           // Vector  4: NACKIFG
  case  6: break;                           // Vector  6: STTIFG
  case  8: break;                           // Vector  8: STPIFG
  case 10:                                  // Vector 10: RXIFG
    RXData = UCB0RXBUF;                     // Get RX data
    __bic_SR_register_on_exit(LPM0_bits);   // Exit active CPU
    break;
  case 12: break;                           // Vector 12: TXIFG
  default: break;
ayl439 发表于 2015-5-27 17:14 | 显示全部楼层
你这个是接收端程序,注意检查SCL这条线上接没接上拉电阻
 楼主| rui199009 发表于 2015-5-27 20:46 | 显示全部楼层
不好意思,上传错了程序。现在这个是发送程序了。
//  MSP430F552x Demo - USCI_B0 I2C Master TX single bytes to MSP430 Slave
//  transmits to the slave. This is the master code. It continuously
//  transmits 00h, 01h, ..., 0ffh and demonstrates how to implement an I2C
//  master transmitter sending a single byte using the USCI_B0 TX interrupt.
// ***to be used with "MSP430F55xx_uscib0_i2c_07.c" ***
//                   slave         |    |         master
//   Bhargavi Nisarga
//   April 2009
#include <msp430.h>
unsigned char TXData;
unsigned char TXByteCtr;
int main(void)
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR1 = 0;
  UCB0IE |= UCTXIE;                         // Enable TX interrupt
  TXData = 0x01;                            // Holds TX data
  while (1)
    TXByteCtr = 1;                          // Load TX byte counter
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0 w/ interrupts
    __no_operation();                       // Remain in LPM0 until all data
                                            // is TX'd
    TXData++;                               // Increment data byte
// The USCIAB0_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
#else
#endif
  case 10: break;                           // Vector 10: RXIFG
  case 12:                                  // Vector 12: TXIFG
    if (TXByteCtr)                          // Check TX byte counter
      UCB0TXBUF = TXData;                   // Load TX buffer
      TXByteCtr--;                          // Decrement TX byte counter
    else
      UCB0IFG &= ~UCTXIFG;                  // Clear USCI_B0 TX int flag
      __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
    break;
  default: break;
但是这个发送程序也还是不行,我自己给他加了上拉的代码,还是测不到输出的时钟信号。
 楼主| rui199009 发表于 2015-5-27 20:47 | 显示全部楼层
我加了这两句,
P3REN |= BIT2;
  P3OUT |= BIT2;
还是不行。
643757107 发表于 2015-5-27 20:51 | 显示全部楼层
感觉应该插入代码那种才对啊,这样就能看清楚那个图了。
 楼主| rui199009 发表于 2015-5-27 21:09 | 显示全部楼层
插入代码?没理解,请说明一下,谢谢。
yiyigirl2014 发表于 2015-5-27 21:11 | 显示全部楼层
楼上说的插入代码,是说的楼主应该发帖时候以插入代码的方式发那段代码吧,不是说的程序内容吧。
 楼主| rui199009 发表于 2015-5-27 21:13 | 显示全部楼层
楼上说的插入代码,是说的楼主应该发帖时候以插入代码的方式发那段代码吧,不是说的程序内容吧。 ...
懂了,谢谢。
 楼主| rui199009 发表于 2015-5-27 21:15 | 显示全部楼层
  1. //******************************************************************************
  2. //  MSP430F552x Demo - USCI_B0 I2C Master TX single bytes to MSP430 Slave
  3. //
  4. //  Description: This demo connects two MSP430's via the I2C bus. The master
  5. //  transmits to the slave. This is the master code. It continuously
  6. //  transmits 00h, 01h, ..., 0ffh and demonstrates how to implement an I2C
  7. //  master transmitter sending a single byte using the USCI_B0 TX interrupt.
  8. //  ACLK = n/a, MCLK = SMCLK = BRCLK = default DCO = ~1.045MHz
  9. //
  10. // ***to be used with "MSP430F55xx_uscib0_i2c_07.c" ***
  11. //
  12. //                                /|\  /|\
  13. //                MSP430F5529     10k  10k     MSP430F5529
  14. //                   slave         |    |         master
  15. //             -----------------   |    |   -----------------
  16. //           -|XIN  P3.0/UCB0SDA|<-|----+->|P3.0/UCB0SDA  XIN|-
  17. //            |                 |  |       |                 |
  18. //           -|XOUT             |  |       |             XOUT|-
  19. //            |     P3.1/UCB0SCL|<-+------>|P3.1/UCB0SCL     |
  20. //            |                 |          |                 |
  21. //
  22. //   Bhargavi Nisarga
  23. //   Texas Instruments Inc.
  24. //   April 2009
  25. //   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
  26. //******************************************************************************
  27. #include <msp430.h>
  28. unsigned char TXData;
  29. unsigned char TXByteCtr;
  30. int main(void)
  31. {
  32.   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  33.   P3SEL |= BIT0 + BIT1;                            // Assign I2C pins to USCI_B0
  34.   P3DIR |= BIT0 + BIT1;
  35.   P3OUT |= BIT0 + BIT1;
  36.
  37.   UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  38.   UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  39.   UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  40.   UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  41.   UCB0BR1 = 0;
  42.   UCB0I2CSA = 0x48;                         // Slave Address is 048h
  43.   UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  44.   //UCB0IE |= UCTXIE;                         // Enable TX interrupt
  45.   TXData = 0xFF;                            // Holds TX data
  46.   while (1)
  47.   {
  48.     TXByteCtr = 1;                          // Load TX byte counter
  49.     while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
  50.     UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
  51.
  52.     //__bis_SR_register(LPM0_bits + GIE);     // Enter LPM0 w/ interrupts
  53.     //__no_operation();                       // Remain in LPM0 until all data
  54.     UCB0TXBUF = TXData;                                         // is TX'd
  55.   }
  56. }
yiyigirl2014 发表于 2015-5-27 21:16 | 显示全部楼层
嘿嘿,这样看着舒服多了,排版看着清爽,刚才那个看起来费劲,一会儿高手看到就该讲了。
 楼主| rui199009 发表于 2015-5-27 21:17 | 显示全部楼层
嘿嘿,这样看着舒服多了,排版看着清爽,刚才那个看起来费劲,一会儿高手看到就该讲了。 ...
多谢哈,平时基本不怎么用这个的,都是自己看书搞东西。这次这个IIC通信实在是弄不出来。
yiyigirl2014 发表于 2015-5-27 21:20 | 显示全部楼层
如果代码是官方的,你要使用主机模式,不仅需要发送还需要接收,不知道楼主做个FM的单芯片收音机没有,那个就是IIC,你可以百度一下,或者论坛搜一下,那个例子很好的,你搜索430做的FM收音机。
 楼主| rui199009 发表于 2015-5-27 21:23 | 显示全部楼层
如果代码是官方的,你要使用主机模式,不仅需要发送还需要接收,不知道楼主做个FM的单芯片收音机没有,那个 ...
我没有做那个收音机,我现在在做430和adxl的硬件IIC通信。软件的IIC通信我会做,已经做完好久了,就是硬件一直不行,所以最近翻出来做做。另外我现在只测试发送,不接收,但是SCL时钟线上没有信号,不知道为什么?
dirtwillfly 发表于 2015-5-28 08:02 | 显示全部楼层
你用的板子是自己画的,还是官方的demo板子?
 楼主| rui199009 发表于 2015-5-28 09:07 | 显示全部楼层
板子是官方版,程序也是官方的,但是在运行的时候,IIC引脚没有SCL信号。
dirtwillfly 发表于 2015-5-28 09:09 | 显示全部楼层
板子是官方版,程序也是官方的,但是在运行的时候,IIC引脚没有SCL信号。 ...
把adxl345硬件拆掉后,重新试试
luofeng2g 发表于 2015-5-28 09:10 | 显示全部楼层
用示波器测过?
 楼主| rui199009 发表于 2015-5-28 09:17 | 显示全部楼层
恩,是的,示波器测不到信号。
 楼主| rui199009 发表于 2015-5-28 09:18 | 显示全部楼层
把adxl345硬件拆掉后,重新试试
拆掉了,还是没反应。按理说初始化应该是没问题的。
