哎 编译了N遍了,我把步骤列一下:
1.在L3.0.35_4.1.0_130816_source目录下 ./install 选择的目录为/opt/freescale
2.cd /opt/freescale 安装了补丁patch-ltib-ubuntu12.04.sh
3 ./ltib
选择的平台为
然后,出错:
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /opt/freescale/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /opt/freescale/ltib/rpm' --define '_prefix /usr' --define '_tmppath /opt/freescale/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/rpm/RPMS' --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bc --short-circuit /opt/freescale/ltib/tmp/u-boot-v2009.08.spec
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /opt/freescale/ltib/tmp/rpm-tmp.23083
+ umask 022
+ cd /opt/freescale/ltib/rpm/BUILD
+ cd u-boot-2009.08
+ : mx6q_sabresd_config
++ eval echo
+++ echo
+ PKG_U_BOOT_PATH_PRECONFIG=
+ SRC_DIR=/opt/freescale/ltib/rpm/BUILD/u-boot-2009.08
+ BUILD_DIR=/opt/freescale/ltib/rpm/BUILD/u-boot-2009.08
+ '[' /opt/freescale/ltib/rpm/BUILD/u-boot-2009.08 '!=' /opt/freescale/ltib/rpm/BUILD/u-boot-2009.08 ']'
+ cd /opt/freescale/ltib/rpm/BUILD/u-boot-2009.08
+ '[' -n '' ']'
+ make 'HOSTCC=ccache /usr/bin/gcc -B/usr/bin/' CROSS_COMPILE=arm-none-linux-gnueabi- O=/opt/freescale/ltib/rpm/BUILD/u-boot-2009.08 mx6q_sabresd_config
make: *** No rule to make target `mx6q_sabresd_config'. Stop.
error: Bad exit status from /opt/freescale/ltib/tmp/rpm-tmp.23083 (%build)
