[其他ST产品] 谁知道如何在71x_init.s中添加remapping代码?
3364|1
 楼主| yangtaojsw 发表于 2007-4-21 09:19 | 显示全部楼层 |阅读模式
已有的代码如下,但这个代码有点问题。
; define remapping
; If you need to remap memory before entring the main program
; uncomment next ligne
            #define   remapping
; Then define which memory to remap to address 0x00000000
;  Uncomment next line if you want to remap RAM
         #define  remap_ram
;  Uncomment next line if you want to remap FLASH
;         #define remap_flash
;  Uncomment next line if you want to remap EXT FLASH
;         #define remap_extflash
#ifdef remapping
    #ifdef remap_flash
        MOV     r0, #FLASH_mask
    #endif
    #ifdef remap_ram
        MOV     r0, #RAM_mask
    #endif
    #ifdef remap_extflash
        MOV     r0, #EXTFLASH_mask
    #endif
        LDR     r1, =CPM_Base_addr
        LDRH    r2, [r1, #BOOTCR_off_addr]; Read BOOTCR Register
        BIC     r2, r2, #0x03             ; Reset the two LSB bits of BOOTCR
        ORR     r2, r2, r0                ; change the two LSB bits of BOOTCR
        STRH    r2, [r1, #BOOTCR_off_addr]; Write BOOTCR Register
#endif
有一段ads1.2的代码,但我不知道如何改为IAR for ARM的:
        IMPORT    |Image$$RO$$Limit|  ; End of ROM code (=start of ROM data)
        IMPORT    |Image$$RW$$Base|   ; Base of RAM to initialise
        IMPORT    |Image$$ZI$$Base|   ; Base and limit of area
        IMPORT    |Image$$ZI$$Limit|  ; to zero initialise
        ;*  Copy and paste RW data/zero initialized data        *
        LDR        r0, =|Image$$RO$$Limit|    ; Get pointer to ROM data
        LDR        r1, =|Image$$RW$$Base|    ; and RAM copy
        LDR        r3, =|Image$$ZI$$Base|
        ;Zero init base => top of initialised data
        CMP        r0, r1        ; Check that they are different
        BEQ        %F1
        CMP        r1, r3        ; Copy init data
        LDRCC   r2, [r0], #4    ;--> LDRCC r2, [r0] + ADD r0, r0, #4
        STRCC   r2, [r1], #4    ;--> STRCC r2, [r1] + ADD r1, r1, #4
        BCC        %B0
        LDR        r1, =|Image$$ZI$$Limit| ; Top of zero init segment
        MOV        r2, #0
        CMP        r3, r1        ; Zero init
        STRCC   r2, [r3], #4
        BCC        %B2
上述代码可以将要remapping的内容写入boot 0x00000000。但是如何改为IAR for ARM的格式哪?有谁知道,先谢了!
