按照手册上13.3.5上讲的 The following example shows how to capture the counter value in TIMx_CCR1 when TI1 input rises. To do this, use the following procedure: ● Select the active input: TIMx_CCR1 must be linked to the TI1 input, so write the CC1S bits to 01 in the TIMx_CCMR1 register. As soon as CC1S becomes different from 00, the channel is configured in input and the TIMx_CCR1 register becomes read-only. ● Program the input filter duration you need with respect to the signal you connect to the timer (when the input is one of the TIx (ICxF bits in the TIMx_CCMRx register). Let’s imagine that, when toggling, the input signal is not stable during at must 5 internal clock cycles. We must program a filter duration longer than these 5 clock cycles. We can validate a transition on TI1 when 8 consecutive samples with the new level have been detected (sampled at fDTS frequency). Then write IC1F bits to 0011 in the TIMx_CCMR1 register. ● Select the edge of the active transition on the TI1 channel by writing CC1P bit to 0 in the TIMx_CCER register (rising edge in this case). ● Program the input prescaler. In our example, we wish the capture to be performed at each valid transition, so the prescaler is disabled (write IC1PS bits to 00 in the TIMx_CCMR1 register). ● Enable capture from the counter into the capture register by setting the CC1E bit in the TIMx_CCER register. ● If needed, enable the related interrupt request by setting the CC1IE bit in the TIMx_DIER register, and/or the DMA request by setting the CC1DE bit in the TIMx_DIER register.
得到如下初始化代码(TIM3_Ch4)捕捉
TIM_ICInitTypeDef TIM_ICInitStructure; GPIO_InitTypeDef GPIO_InitStructure; #ifdef DEBUG debug(); #endif /* GPIOB Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE); /* GPIOB Configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
/* TIM3 configuration: Input mode ------------------------ The external signal is connected to TIM3 CH4 pin (PB.01), The Rising edge is used as active edge, ------------------------------------------------------------ */ TIM_ICInitStructure.TIM_Channel = TIM_Channel_4; TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling; TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; TIM_ICInitStructure.TIM_ICFilter = 0x0; TIM_ICInit(TIM3, &TIM_ICInitStructure);
/* TIM enable counter */ TIM_Cmd(TIM3, ENABLE);
/* Enable the CC4 Interrupt Request */ TIM_ITConfig(TIM3, TIM_IT_CC4, ENABLE);
中断 void TIM3_IRQHandler(void) { /* Clear TIM3 Capture compare interrupt pending bit */ CPU_INT16U IC3_Value; CPU_SR cpu_sr; OS_ENTER_CRITICAL(); /* Tell uC/OS-II that we are starting an ISR */ OSIntNesting++; OS_EXIT_CRITICAL(); TIM_ClearITPendingBit(TIM3, TIM_IT_CC4); /* Get the Input Capture value */ IC3_Value = TIM_GetCapture2(TIM3); if(IC3_Value != 0) { IC3_Value = IC3_Value; } else { } OSIntExit(); }
始终进不了
