DDR初始化异常,导致主板程序没运行起来
1304|1
 楼主| junqin86 发表于 2015-11-29 16:16 | 显示全部楼层 |阅读模式
如题:主板DM6437,DDR为镁光MT47H32M16H
DDR控制初始化程序如下,但程序下载到主板上发现程序不是每次都能跑起来,大虾们,帮我看看吧
DDR_DDRPHYCR = 0                // DDR PHY Control Re gister
        | ( 0x1400190 << 6 )        // Magic number
        | ( 0 << 5 )                // DLL release
        | ( 0 << 4 )                // DLL powered up
        | ( 5 << 0 );               // Read latency ( CAS + RT - 1 )
    DDR_SDBCR = 0                   // DDR Bank Config
        | ( 0 << 23 )               // Boot unlock  = No
        | ( 2 << 19 )               // Reserved     = ( 2 )
        | ( 0 << 18 )               // Drive Strength= Normal
        | ( 3 << 16 )               // Reserved     = ( 3 )
        | ( 1 << 15 )               // Modify SDBCR = Yes
        | ( 0 << 14 )               // Bus width    = 32-bit
        | ( 4 << 9 )                // CAS latency  = 4
        | ( 2 << 4 )                // Bank Setup   = 4 banks
        | ( 2 << 0 );               // Page Size    = 1024-word / 10 column bits
    DDR_SDTIMR = 0                  // DDR Timing Register
        | ( 17 << 25 )              // tRFC = ( 105 ns / 6.17 ns ) - 1
        | ( 2 << 22 )               // tRP  = (  15 ns / 6.17 ns ) - 1
        | ( 2 << 19 )               // tRCD = (  15 ns / 6.17 ns ) - 1
        | ( 2 << 16 )               // tWR  = (  15 ns / 6.17 ns ) - 1
        | ( 6 << 11 )               // tRAS = (  40 ns / 6.17 ns ) - 1
        | ( 8 << 6 )                // tRC  = (  55 ns / 6.17 ns ) - 1
        | ( 1 << 3 )                // tRRD = ( 7.5 ns / 6.17 ns ) - 1
        | ( 1 << 0 );               // tWTR = ( 7.5 ns / 6.17 ns ) - 1
    DDR_SDTIMR2 = 0                 // DDR Timing Register
        | ( 18 << 16 )              // tXSNR= ( 115 ns / 6.17 ns ) - 1
        | ( 199 << 8 )              // tXSRD= ( 200 - 1 ) cycles
        | ( 1 << 5 )                // tRTP = ( 7.5 ns / 6.17 ns ) - 1
        | ( 2 << 0 );               // tCKE = ( 3 - 1 ) cycles
    DDR_SDBCR &= ~0x00008000;       // SDBCR cannot be modified
    refresh_rate = ( freq * 78 ) / 10;
    DDR_SDRCR = 0
        | ( 0 << 31 )               // Exits self-refresh
        | ( 0 << 30 )               // Disable MCLK stopping
        | refresh_rate;             // Refresh Control = 7.8 usec * freq
zhangmangui 发表于 2015-11-29 20:11 | 显示全部楼层
存储这一块    直接出硬件设计    没有操作过   帮忙顶
