TM32F411一共有三个串口,分别是串口一,串口二和串口六。这个串口折腾了好多好多天,说多了都是泪,我一开始就上串口二,没想到串口二是个坑!!!!!使劲调都调不通,最后还是放弃先,之后试了试串口一和串口六,一试就通!
别跟我说是不是硬件问题,或者说是不是串口二的时钟没开之类的!都不是!!!!!我调通串口一和串口六之后,试了试用stn32的专用库来试试,我擦想死的心都有,一下就成了!!!别烦我先,我一个人想静静,别问静静是谁! 为什么标准库不行!!!!请广大网友解决这个问题能发发善心告诉我,这里我奉上我调通的三个串口源码。(串口一和串口六我都写好接收中断了,串口二仅仅写好了发送的没写接收的)
(1)建立工程,新建工程的步骤就不说了!
(2)新建bsp_usart.c和bsp_usart.h
bsp_usart.c
- #include "bsp_usart.h"
- void NVIC_USART1_Config(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
- NVIC_InitStructure.NVIC_IRQChannel=USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x00;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x02;
- NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- void USART1_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA , ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
- //串口1对应引脚复用映射
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
- GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- NVIC_USART1_Config();
- USART_InitStructure.USART_BaudRate=115200;
- USART_InitStructure.USART_WordLength=USART_WordLength_8b;
- USART_InitStructure.USART_StopBits=USART_StopBits_1;
- USART_InitStructure.USART_Parity=USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
- USART_Init(USART1,&USART_InitStructure);
- USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
- USART_Cmd(USART1,ENABLE);
- /// 重定向c库函数printf到USART1
- int fputc(int ch, FILE *f)
- /* 发送一个字节数据到USART1 */
- USART_SendData(USART1, (uint8_t) ch);
- /* 等待发送完毕 */
- while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
- return (ch);
- /// 重定向c库函数scanf到USART1
- int fgetc(FILE *f)
- /* 等待串口1输入数据 */
- while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
- return (int)USART_ReceiveData(USART1);
- /*********************************************END OF FILE**********************/
