FSK信号鉴频的程序
493|0
 楼主| 米尔豪斯 发表于 2016-6-29 21:34 | 显示全部楼层 |阅读模式
/* This program implements the function of finding out the largest */
/* and the second largest values of the sequence of "in_buffer[10]"*/
#include <stdio.h>
#include <math.h>
#include "freq_max_finding.h"
//extern float cosf(float x);
extern int in_buffer[10]={0,0,0,0,0,0,0,0,0,0}; /* in_buffer[]中的值为频谱点 */
//int out_buffer[2];
static void dataIN(void);
void main()
        int                i=0;
//        float         data_max=0;
        int                data_max=0;
//        float         data_max2=0;
        int     data_max2=0;
        int         i_max=0;
        int         i_max2=0;
        float         f_max=0;
        float         f_max2=0;
        int                p=0;
        int                q=0;
//        float a=0, b=3.14159;
//        a=a+0;
//        b=b+0;
//        a=cosf(b);
        /** 几句废话,消除warning:data_max was set but never used **/
        data_max=data_max+0;
        data_max2=data_max2+0;
//        i_max=i_max+0;
//        i_max2=i_max2+0;
        f_max=f_max+0;
        f_max2=f_max2+0;
        dataIN();        /* read data into memory */
/** find out the greatest value of "in_buffer" **/
        for(i=0;i<=POINT_ALL-2;i++)
                 if (in_buffer[i+1]>in_buffer[i])
                           {data_max=in_buffer[i+1]; i_max=i+1;}
                 else {data_max=in_buffer[i]; i_max=i;}
        f_max=FS*i_max/POINT_ALL; /* calculate the value of carrier frequency */
/* find out the second greatest value of "in_buffer" */
                in_buffer[i_max]=0;        /* set 0 to "in_buffer[i_max]"*/
                for(p=1;p<=POINT_ALL/2;p++)
                         for(q=0;q<=POINT_ALL/2-2;q++)
                                    if (in_buffer[q+1]>in_buffer[q])
                                                    {data_max2=in_buffer[q+1]; i_max2=q+1;}
                                    else        {data_max2=in_buffer[q]; i_max2=q;}
                         /* determines the availability of i_max2 through
                            estimating the distance of i_max between i_max2 */
                         if (abs(i_max-i_max2)<=GAP)        in_buffer[i_max2]=0;
                         else        break;
                f_max2=FS*i_max2/POINT_ALL;        /* calculate the value of carrier frequency2 */
        while(1);
static void dataIN()
        /* do read data from host file */
        return;
复制代码
