最近一直在做把CCS3.3上板子是TMS320F2812的程序移植到CCS5.5板子是F28M35上,我是新建工程,进行移植,我用的CMD文件是:F28M35H52C1_C28..cmd出现的问题是:
<a href="file:/C:/ti/ccsv5/tools/compiler/dmed/HTML/10099.html">#10099-D</a> program will not fit into available memory. placement with alignment/blocking fails for section ".text" size 0xae1d page 0. Available memory ranges: F28M35H52C1_c28.cmd /temp1 line 113 C/C++ Problem
Description Resource Path Location Type
unresolved symbol _const_loadend, first referenced in ./ply_main.obj
