[8/16-bit MCU] 调用编译生成的二进制函数代码块
1158|1
 楼主| longlianqing 发表于 2016-12-13 14:02 | 显示全部楼层 |阅读模式
我写了一个
void E2prom_Write_Byte(unsigned inteeaddress, unsigned char eedata)
         unsignedint b=0;
    FCLKDIV=0x03;//FDIVfield is open for writing AND FDIV[5:0]=3;
   if(FSTAT_CCIF == 1)
       FSTAT = 0x30;//cleare ACCERR AND FPVIOL
       FCCOBIX = 0x00;
       FCCOBHI = 0x11;
       FCCOBLO = 0x00;//Program EEPROM Command
       FCCOBIX ++;
       FCCOB = eeaddress;
       FCCOBIX ++;
       FCCOBHI = eedata;
       FCCOBLO = 0xff;//WRITE_BYTE
       FSTAT_CCIF  = 1;
       while(!FSTAT_CCIF&&b<3000)//wait for write byte complete
           b++;
此函数内部没有调用其它函数,全是操作寄存器,作用是操作了E2PROM
上面的函数我测试了没问题,函数作用也实现了。
然后在编译器中编译,查看.map文件:
E2prom_Write_Byte   88013             4E           78                   2               .text
得知是在地址088013地址为函数起始地址,其后的78个字节,是该函数的编译出来的机器码,我把这78字节的机器码提前在.S19文件中提取出来,得到存到了一个数组中
如下:
unsigned char e2prom_driver_code[78] =
   0x1D,0x02,0xFA,0x80,0xCC,0x04,0x13,0x5B,0x34,0x5A,0x36,0x4F,0x37,0x08,0xFC,0x4C,0x39,0x80,0x0A,0x6B,0xAD,0xC7,0x87,0x6C,0x81,0xC6,0x03,0x7B,0x01,0x00,0x1F,0x01,
   0x06,0x80,0x3B,0xC6,0x30,0x7B,0x01,0x06,0x7A,0x01,0x02,0xC6,0x11,0x7B,0x01,0x0A,0x7A,0x01,0x0B,0x72,0x01,0x02,0xEE,0x86,0x7E,0x01,0x0A,0x72,0x01,0x02,0xE6,0x80,
   0x7B,0x01,0x0A,0x43,0x7A,0x01,0x0B,0x1C,0x01,0x06,0x80,0x20,0x05,0xEE
然后按照函数原型定义了一个函数指针类:E2PROM_WRITE_FUN_POINTER
typedef void(*E2PROM_WRITE_FUN_POINTER)(unsigned int,unsigned char);//定义该类型的函数指针类型
E2PROM_WRITE_FUN_POINTER  fun;//然后定义了该类型的一个指针,
然后通过((E2PROM_WRITE_FUN_POINTER)e2prom_driver_code)(0x400,0x28);来调用机器码,
但是好像编译警告如下:
非标准转换
跑起来跑到这个函数调用处,也非法复位了,/(o)/~~。。。求指教啊!
 楼主| longlianqing 发表于 2016-12-14 09:01 | 显示全部楼层
已经找到原因,S12G系列芯片函数跳转添加了页地址,把页地址加进去就好了。
