- #include <reg52.h>
- typedef unsigned char uchar;
- uchar direction = 0; //0为正转,1为反转
- uchar onoff = 0; //关为0,开为1
- uchar n = 0; //每次定时器中断触发时n++,当n==max时电机转动1/4
- uchar max = 10;
- uchar index = 0; //通过index指示电机转动,AB,BC,CD,DA
- sbit LED = P3 ^ 7; //当n==max时LED闪烁提示
- int main()
- /* LED */
- P2 = 0xff;
- /* 初始化中断 */
- EA = 1;
- EX0 = 1; //要用到的中断是两个外部中断和定时器中断0
- IT0 = 1;
- EX1 = 1;
- IT1 = 1;
- ET0 = 1;
- /* 定时器0 */
- TMOD = 0x01; //使用定时器0,方式1
- TH0 = (65536 - 10000) / 256; //12MHz晶振下,定时器为10ms触发中断,更方便观察转动情况
- TL0 = (65536 - 10000) % 256;
- TR0 = 1;
- while(1)
- switch(P0)
- case 0xfe: //11111110
- max = 1;
- P2 = 1;
- break;
- case 0xfd: //11111101
- max = 10;
- P2 = 2;
- break;
- case 0xfb: //11111011
- max = 50;
- P2 = 3;
- break;
- case 0xf7: //11110111
- max = 100;
- P2 = 4;
- break;
- void Stop()interrupt 0
- onoff++;
- if (onoff > 1)
- onoff = 0;
- void int1()interrupt 2
- direction++;
- if (direction > 1)
- direction = 0;
- void delay50ms(void)
- unsigned char a, b;
- for(b = 173; b > 0; b--)
- for(a = 143; a > 0; a--);
- void time()interrupt 1
- if (onoff == 1) //在开状态下
- if (n == max) //设定档位速度,经过了max次中断后,步进电机转1/4圈
- LED = 0; //每次n==max时LED闪烁
- delay50ms();
- LED = 1;
- if (direction == 0)
- switch(index) //正转时以AB,BC,CD,DA顺序
- case 0:P1 = 0x03;break; //00000011 AB高电平
- case 1:P1 = 0x06;break; //00000110 BC高电平
- case 2:P1 = 0x0c;break; //00001100 CD高电平
- case 3:P1 = 0x09;break; //00001001 DA高电平
- index ++;
- if (index == 4) //步进电机转完一圈时index清零
- index = 0;
- n = 0; //到达max,n重置为0
- if (direction == 1)
- switch(index) //反转时以DA,CD,BC,AB顺序
- case 0:P1 = 0x09;break;
- case 1:P1 = 0x0c;break;
- case 2:P1 = 0x06;break;
- case 3:P1 = 0x03;break;
- index ++;
- if (index == 4)
- index = 0;
- n = 0;
- else n = 0;
- n++; //n!=max时,n++
- else n = 0; //在关状态下,n始终为0,无法触发电机转动
