求问F28335中两个ADC采样结果AdcMirrorFile和AdcRegsFile的区别
2192|1
 楼主| canornot 发表于 2018-12-7 09:36 | 显示全部楼层 |阅读模式
F28335中定义了两个ADC采样结果的储存空间:
ADC_MIRROR  : origin = 0x000B00, length = 0x000010     /* ADC Results register mirror */
ADC         : origin = 0x007100, length = 0x000020     /* ADC registers */
这两个对应的结构体里都有ADC采样结果:
struct ADC_REGS {
    union ADCTRL1_REG      ADCTRL1;       // ADC Control 1
    union ADCTRL2_REG      ADCTRL2;       // ADC Control 2
    union ADCMAXCONV_REG   ADCMAXCONV;    // Max conversions
    union ADCCHSELSEQ1_REG ADCCHSELSEQ1;  // Channel select sequencing control 1
    union ADCCHSELSEQ2_REG ADCCHSELSEQ2;  // Channel select sequencing control 2
    union ADCCHSELSEQ3_REG ADCCHSELSEQ3;  // Channel select sequencing control 3
    union ADCCHSELSEQ4_REG ADCCHSELSEQ4;  // Channel select sequencing control 4
    union ADCASEQSR_REG    ADCASEQSR;     // Autosequence status register
    Uint16                 ADCRESULT0;    // Conversion Result Buffer 0
    Uint16                 ADCRESULT1;    // Conversion Result Buffer 1
    Uint16                 ADCRESULT2;    // Conversion Result Buffer 2
    Uint16                 ADCRESULT3;    // Conversion Result Buffer 3
    Uint16                 ADCRESULT4;    // Conversion Result Buffer 4
    Uint16                 ADCRESULT5;    // Conversion Result Buffer 5
    Uint16                 ADCRESULT6;    // Conversion Result Buffer 6
    Uint16                 ADCRESULT7;    // Conversion Result Buffer 7
    Uint16                 ADCRESULT8;    // Conversion Result Buffer 8
    Uint16                 ADCRESULT9;    // Conversion Result Buffer 9
    Uint16                 ADCRESULT10;   // Conversion Result Buffer 10
    Uint16                 ADCRESULT11;   // Conversion Result Buffer 11
    Uint16                 ADCRESULT12;   // Conversion Result Buffer 12
    Uint16                 ADCRESULT13;   // Conversion Result Buffer 13
    Uint16                 ADCRESULT14;   // Conversion Result Buffer 14
    Uint16                 ADCRESULT15;   // Conversion Result Buffer 15
    union ADCTRL3_REG      ADCTRL3;       // ADC Control 3
    union ADCST_REG        ADCST;         // ADC Status Register
    Uint16                                   rsvd1;
    Uint16                 rsvd2;
    union ADCREFSEL_REG    ADCREFSEL;     // Reference Select Register
    union ADCOFFTRIM_REG   ADCOFFTRIM;    // Offset Trim Register
struct ADC_RESULT_MIRROR_REGS
求问高人这两结构体里的AD采样结果一样吗?是不是有个专门给DMA访问的呢?
 楼主| canornot 发表于 2018-12-7 22:41 | 显示全部楼层
突然自己发现官方说明上规定了,前者不支持DMA访问,后者可以
