- #include<stdio.h>
- #include"NUC1xx.h"
- #include"M0Base.h"
- #include"DrvGPIO.h"
- #include"M0Uart.h"
- #include"M0Timer.h"
- #include"lcd1602.h"
- #include"m0rtc.h"
- #include"M0I2c.h"
- int main(void)
- UNLOCKREG(); //解寄存器锁保护
- PLL50M();
- LOCKREG();
- i2c_tr_buf[0]='0';
- i2c_tr_buf[1]='1';
- i2c_tr_buf[2]='2';
- i2c_tr_buf[3]='3';
- i2c_tr_buf[4]='4';
- InitUart0();
- InitTimer0();
- InitLcd1602();
- InitRtc();
- InitI2c_Master();
- Set_I2c_Start(0xa0,I2C_WRITE,10,0x0000);
- Set_I2c_Start(0xa0,I2C_WRITE,0,0x0002); //不写数据,只写存储地址,和读数据一起用
- Set_I2c_Start(0xa0,I2C_READ,5,0x00);//这里地址不起作用
- while(1)
m0i2c.h
- #ifndef _M0I2C_H_
- #define _M0I2C_H_
- #define I2C_READ 1
- #define I2C_WRITE 0
- extern uint8_t i2c_tr_buf[],i2c_re_buf[];
- extern uint8_t i2c_flag;
- void InitI2c_Master(void);
- void Set_I2c_Start(int8_t ssalve,int8_t srw,int8_t snum,int16_t sadd);
- #endif
m0i2c.c
- #include"stdio.h"
- #include"DrvI2C.H"
- #include"DrvGPIO.H"
- #include"DrvSYS.h"
- #include"m0i2c.h"
- uint8_t i2c_tr_buf[10]={0};
- uint8_t i2c_re_buf[10]={0};
- uint8_t i2c_flag=0;
- typedef struct{
- int8_t i2c_salve; //传输从机地址
- int8_t i2c_rw;
- int8_t dat_num; //传输数据个数
- int8_t dat_cnt; //传输数据数据计数
- int16_t dat_add; //传输数据的其实地址
- }I2C_TYPE;
- volatile I2C_TYPE i2c={0,0,0,0};
- //地址对读数据无效
- //读数据只能先写地址,再读数据
- uint16_t cnt=0;
- i2c.i2c_salve=ssalve;
- i2c.i2c_rw=srw;
- i2c.dat_num=snum;
- i2c.dat_cnt=0;
- i2c.dat_add=sadd;
- i2c_flag=0 ;
- DrvI2C_Ctrl(I2C_PORT1, 1, 0, 0, 0);
- while((i2c_flag!=1)&&(cnt!=0xffff))
- cnt++;//判断是否读取或写结束
- DrvSYS_Delay(8000);//延时
- void I2c1CallBack(uint32_t status)
- if(i2c.i2c_rw==I2C_READ) //读状态
- if (status == 0x08) /* START has been transmitted and prepare SLA+W */
- DrvI2C_WriteData(I2C_PORT1, (i2c.i2c_salve|0x01)); //读地址数据
- DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 0);
- else if (status == 0x40) /* SLA+R has been transmitted and ACK has been received */
- DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 1); //have ack
- else if(status==0x50)
- i2c_re_buf[i2c.dat_cnt++] = DrvI2C_ReadData(I2C_PORT1);
- if(i2c.dat_cnt<(i2c.dat_num-1))
- else
- else if (status == 0x58) /* DATA has been received and NACK has been returned */
- DrvI2C_Ctrl(I2C_PORT1, 0, 1, 1, 0);
- i2c_flag=1;
- else
- printf("Status 0x%x is NOT processed\n", status);
- else if(i2c.i2c_rw==I2C_WRITE) //写状态
- if (status == 0x08) /* START has been transmitted */
- DrvI2C_WriteData(I2C_PORT1, (i2c.i2c_salve&0xfe)); //读地址数据
- else if (status == 0x18) /* SLA+W has been transmitted and ACK has been received */
- DrvI2C_WriteData(I2C_PORT1, (int8_t)(i2c.dat_add)); //传输高位地址
- i2c.dat_cnt++;
- else if (status == 0x20) /* SLA+W has been transmitted and NACK has been received */
- DrvI2C_Ctrl(I2C_PORT1, 1, 1, 1, 0);
- else if (status == 0x28) /* DATA has been transmitted and ACK has been received */
- if (i2c.dat_cnt<2)
- DrvI2C_WriteData(I2C_PORT1, (int8_t)(i2c.dat_add>>8));//传输低位地址
- i2c.dat_cnt++;
- else if(i2c.dat_cnt<(i2c.dat_num+2))
- DrvI2C_WriteData(I2C_PORT1, i2c_tr_buf[i2c.dat_cnt-2]);
- i2c.dat_cnt++;
- else
- DrvI2C_Ctrl(I2C_PORT1, 0, 1, 1, 0);//send a stop
- i2c_flag=1;
- else
- void InitI2c_Master()
- DrvGPIO_InitFunction(E_FUNC_I2C1);
- DrvI2C_Open(I2C_PORT1, 50000);
- DrvI2C_EnableInt(I2C_PORT1);
- DrvI2C_InstallCallback(I2C_PORT1, I2CFUNC, I2c1CallBack);
