这款开发板上有个OLED显示器,对调试板卡来说非常好用,这里首先把这个显示器驱动起来,显示器为I2C接口,论坛里有人已经成功驱动过了,相信应该不是很难。I2C驱动、OLED驱动,再加字库就OK了。show显示效果,祝大家国庆、中秋双节快乐!
oled
只要之前接触过OLED,相信驱动起来都不是很难,这里不啰嗦了,直接上代码:首先搭建I2C接口配置,可参考例程
- stc_i2c_init_t stcI2cInit;
- stc_clk_freq_t stcClkFreq;
- /* Initialize I2C port*/
- PORT_SetFunc(I2C2_SCL_PORT, I2C2_SCL_PIN, Func_I2c2_Scl, Disable);
- PORT_SetFunc(I2C2_SDA_PORT, I2C2_SDA_PIN, Func_I2c2_Sda, Disable);
- /* Enable I2C Peripheral*/
- PWC_Fcg1PeriphClockCmd(PWC_FCG1_PERIPH_I2C2, Enable);
- I2C_DeInit(I2C_CH);
- /* Get system clock frequency */
- CLK_GetClockFreq(&stcClkFreq);
- MEM_ZERO_STRUCT(stcI2cInit);
- stcI2cInit.enI2cMode = I2cMaster;
- stcI2cInit.u32Pclk3 = stcClkFreq.pclk3Freq;
- stcI2cInit.u32Baudrate = 400000ul;
- stcI2cInit.u32SclTime = 0ul;
- I2C_Init(I2C_CH, &stcI2cInit);
- I2C_Cmd(I2C_CH, Enable);
写数据- uint32_t u32TimeOut = TIMEOUT;
- while(u32Size--)
- /* Wait tx buffer empty */
- u32TimeOut = TIMEOUT;
- while(Reset == I2C_GetStatus(I2C_CH, I2C_SR_TEMPTYF))
- if(0ul == (u32TimeOut--))
- break;
- /* Send one byte data */
- I2C_SendData(I2C_CH, Data);
- /* Wait transfer end*/
- while(Reset == I2C_GetStatus(I2C_CH, I2C_SR_TENDF))
- break;
- /* Check ACK */
- while(Set == I2C_GetStatus(I2C_CH, I2C_SR_NACKDETECTF))
- break;
- break;
- /* Send I2C address */
- I2C_SendData(I2C_CH, u8Adr);
- if(!(u8Adr & 0x01u))
- /* If in master transfer process, Need wait transfer end*/
- break;
- /* Check ACK */
- break;
- en_flag_status_t enFlagBusy = Reset;
- en_flag_status_t enFlagStartf = Reset;
- /* generate start or restart signal */
- if(!u8Start)
- /* Wait I2C bus idle */
- while(Set == I2C_GetStatus(I2C_CH, I2C_SR_BUSY))
- break;
- I2C_GenerateStart(I2C_CH, Enable);
- else
- /* Clear start status flag */
- I2C_ClearStatus(I2C_CH, I2C_CLR_STARTFCLR);
- /* Send restart condition */
- I2C_GenerateReStart(I2C_CH , Enable);
- /* Judge if start success*/
- while(1)
- enFlagBusy = I2C_GetStatus(I2C_CH, I2C_SR_BUSY);
- enFlagStartf = I2C_GetStatus(I2C_CH, I2C_SR_STARTF);
- if(enFlagBusy && enFlagStartf)
- break;
- break;
代码还不少,直接上传文件,最后调用OLED_Process show 效果!
