[STM32F4] 外部晶振起振
967|19
 楼主| renyaq 发表于 2020-12-15 22:47 | 显示全部楼层 |阅读模式
STM32F407ZG 外部晶振是要程序启动还是MCU上电即可起振
 楼主| renyaq 发表于 2020-12-15 22:50 | 显示全部楼层
MCU没有写任何程序
zwll 发表于 2020-12-15 22:54 | 显示全部楼层
你当然要配置STM32F407ZG在 外部晶振模式了。
kangzj 发表于 2020-12-15 23:04 | 显示全部楼层
意思是还是要在程序中启动 外部晶振才能起振?
juventus9554 发表于 2020-12-15 23:08 | 显示全部楼层
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
gongche 发表于 2020-12-15 23:11 | 显示全部楼层
默认使用内部晶振,使用程序
bqyj 发表于 2020-12-15 23:14 | 显示全部楼层
程序执行后才转到外部
songqian17 发表于 2020-12-15 23:22 | 显示全部楼层
当然是上电起振了
juventus9554 发表于 2020-12-15 23:26 | 显示全部楼层
当然是上电了
llljh 发表于 2020-12-15 23:30 | 显示全部楼层
一定是上电呀 没有疑问
xxrs 发表于 2020-12-15 23:35 | 显示全部楼层
无论是外部还是内部 都是上电起振啊
 楼主| renyaq 发表于 2020-12-15 23:38 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
yzzly 发表于 2020-12-16 09:28 | 显示全部楼层
上电起振,然后用程序设置成你需要的主频,例如,如果你外接12M晶体振荡器,上电后你会在OSCOUT引脚上看到12M频率的信号,然后你设置内部PLL的倍频系数及个子系统的分频系数得到你需要的主频及各子系统的时钟信号。
自己的灌饼 发表于 2020-12-16 16:37 | 显示全部楼层
你的启动代码需要配置成外部晶振,不然的话,默认的是内部晶振的。
jiangyongabc 发表于 2020-12-16 19:41 来自手机 | 显示全部楼层
肯定需要程序配置启动啊
八层楼 发表于 2021-1-10 19:05 | 显示全部楼层
只要上电 就可以起振了吧
观海 发表于 2021-1-10 19:07 | 显示全部楼层
跟mcu写不写程序没有什么关系
guanjiaer 发表于 2021-1-10 19:09 | 显示全部楼层
外部晶振上电即可起振
heimaojingzhang 发表于 2021-1-10 19:11 | 显示全部楼层
内部晶振跟有没有程序有关系吗
keaibukelian 发表于 2021-1-10 19:12 | 显示全部楼层
难道内部晶振也是上电就起振吗
