NK-980IOT 启动输出信息
1160|0
 楼主| dirtwillfly 发表于 2022-3-8 18:20 | 显示全部楼层 |阅读模式
  1. NUC980 IBR 20180813
  2. Boot from SPI-NAND
  3. DDR-OK
  4. finish SPI dow�ad
  5. SPL load main U-Boot from SPI NAND Flash! (Feb 20 2019 09:12:29)
  6. U-Boot 2016.11-g8127c47 (Feb 20 2019 - 09:12:26 +0800)
  7. CPU: NUC980
  8. Board: NUC980
  9. DRAM:  64 MiB
  10. SF: Detected W25N01GV with page size 2 KiB, erase size 128 KiB, total 128 MiB
  11. In:    serial
  12. Out:   serial
  13. Err:   serial
  14. Net:   Net Initialization Skipped
  15. No ethernet found.
  16. Hit any key to stop autoboot:  0
  17. SF: Detected W25N01GV with page size 2 KiB, erase size 128 KiB, total 128 MiB
  18. device 0 offset 0x200000, size 0x800000
  19. SF: 8388608 bytes [url=home.php?mod=space&uid=72445]@[/url] 0x200000 Read: OK
  20. ## Booting kernel from Legacy Image at 00007fc0 ...
  21.    Image Name:   Linux-4.4.115+
  22.    Image Type:   ARM Linux Kernel Image (uncompressed)
  23.    Data Size:    6491248 Bytes = 6.2 MiB
  24.    Load Address: 00008000
  25.    Entry Point:  00008000
  26.    Verifying Checksum ... OK
  27.    XIP Kernel Image ... OK
  28. Starting kernel ...
  29. SF: Detected W25N01GV with page size 2 KiB, erase size 128 KiB, total 128 MiB
  30. SF: DeviceBooting Linux on physical CPU 0x0
  31. Linux version 4.4.115+ (andy@YA-T470P) (gcc version 4.8.4 (GCC) ) #215 PREEMPT Wed Mar 6 09:43:03 CST 2019
  32. CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
  33. CPU: VIVT data cache, VIVT instruction cache
  34. Machine: NUC980
  35. Memory policy: Data cache writeback
  36. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
  37. Kernel command line: root=/dev/ram0 console=ttyS0,115200n8 rdinit=/sbin/init mem=64M
  38. PID hash table entries: 256 (order: -2, 1024 bytes)
  39. Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
  40. Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
  41. Memory: 55828K/65536K available (3306K kernel code, 269K rwdata, 1068K rodata, 4200K init, 209K bss, 9708K reserved, 0K cma-reserved)
  42. Virtual kernel memory layout:
  43.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  44.     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
  45.     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
  46.     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
  47.     modules : 0xbf000000 - 0xc0000000   (  16 MB)
  48.       .text : 0xc0008000 - 0xc044df4c   (4376 kB)
  49.       .init : 0xc044e000 - 0xc0868000   (4200 kB)
  50.       .data : 0xc0868000 - 0xc08ab6c0   ( 270 kB)
  51.        .bss : 0xc08ab6c0 - 0xc08dfe84   ( 210 kB)
  52. SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
  53. Preemptible hierarchical RCU implementation.
  54.         Build-time adjustment of leaf fanout to 32.
  55. NR_IRQS:545
  56. clocksource: nuc980-timer5: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 62215505635 ns
  57. sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836475000000ns
  58. Console: colour dummy device 80x30
  59. console [ttyS0] enabled
  60. Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
  61. pid_max: default: 32768 minimum: 301
  62. Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
  63. Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
  64. CPU: Testing write buffer coherency: ok
  65. Setting up static identity map for 0x8400 - 0x843c
  66. devtmpfs: initialized
  67. clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
  68. futex hash table entries: 256 (order: -1, 3072 bytes)
  69. pinctrl core: initialized pinctrl subsystem
  70. NET: Registered protocol family 16
  71. DMA: preallocated 256 KiB pool for atomic coherent allocations
  72. SCSI subsystem initialized
  73. usbcore: registered new interface driver usbfs
  74. usbcore: registered new interface driver hub
  75. usbcore: registered new device driver usb
  76. Advanced Linux Sound Architecture Driver Initialized.
  77. clocksource: Switched to clocksource nuc980-timer5
  78. NET: Registered protocol family 2
  79. TCP established hash table entries: 1024 (order: 0, 4096 bytes)
  80. TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
  81. TCP: Hash tables configured (established 1024 bind 1024)
  82. UDP hash table entries: 256 (order: 0, 4096 bytes)
  83. UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
  84. NET: Registered protocol family 1
  85. NetWinder Floating Point Emulator V0.97 (double precision)
  86. Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
  87. io scheduler noop registered (default)
  88. nuc980_gpio_probe - pdev = nuc980-gpio
  89. nuc980_dma_probe - pdev = nuc980-dma
  90. nuc980-dma nuc980-dma: NUC980 DMA ready
  91. nuc980-uart.0: ttyS0 at I/O 0x0 (irq = 36, base_baud = 750000) is a NUC980
  92. nuc980-uart.1: ttyS1 at I/O 0x0 (irq = 37, base_baud = 9375000) is a NUC980
  93. brd: module loaded
  94. RX nuc980_qspi0_probe: dma0chan0 module removed
  95. TX nuc980_qspi0_probe: dma0chan1 module removed
  96. RX nuc980_spi0_probe: dma0chan2 module removed
  97. TX nuc980_spi0_probe: dma0chan3 module removed
  98. m25p80 spi1.0: unrecognized JEDEC id bytes: ff, ff, ff
  99. m25p80: probe of spi1.0 failed with error -2
  100. libphy: nuc980_rmii0: probed
  101. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  102. nuc980-ehci nuc980-ehci: Nuvoton NUC980 EHCI Host Controller
  103. nuc980-ehci nuc980-ehci: new USB bus registered, assigned bus number 1
  104. nuc980-ehci nuc980-ehci: irq 23, io mem 0xb0015000
  105. nuc980-ehci nuc980-ehci: USB 2.0 started, EHCI 0.95
  106. hub 1-0:1.0: USB hub found
  107. hub 1-0:1.0: 2 ports detected
  108. ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  109. usb_hcd_nuc980_probe, id = 0, name: nuc980-ohci.0
  110. nuc980-ohci nuc980-ohci.0: Nuvoton NUC980 OHCI Host Controller
  111. nuc980-ohci nuc980-ohci.0: new USB bus registered, assigned bus number 2
  112. nuc980-ohci nuc980-ohci.0: irq 24, io mem 0xb0017000
  113. hub 2-0:1.0: USB hub found
  114. hub 2-0:1.0: 8 ports detected
  115. usb_hcd_nuc980_probe, id = 1, name: nuc980-ohci.1
  116. usb_hcd_nuc980_probe, id = 2, name: nuc980-ohci.2
  117. usb_hcd_nuc980_probe, id = 3, name: nuc980-ohci.3
  118. usb_hcd_nuc980_probe, id = 4, name: nuc980-ohci.4
  119. usb_hcd_nuc980_probe, id = 5, name: nuc980-ohci.5
  120. usb_hcd_nuc980_probe, id = 6, name: nuc980-ohci.6
  121. usbcore: registered new interface driver usb-storage
  122. nuc980-i2c0 nuc980-i2c0: i2c-0: nuc980 I2C adapter
  123. nuc980-i2c2 nuc980-i2c2: i2c-2: nuc980 I2C adapter
  124. nuc980_sd_probe - pdev = nuc980-sdh
  125. usbcore: registered new interface driver usbhid
  126. usbhid: USB HID core driver
  127. nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa
  128. nand: Winbond W25N01GV 1G 3.3V
  129. nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
  130. nand: WARNING: spi0.0: the ECC used on your system is too weak compared to the one required by the NAND chip
  131. Scanning device for bad blocks
  132. random: nonblocking pool is initialized
  133. Creating 3 MTD partitions on "spi0.0":
  134. 0x000000000000-0x000000200000 : "u-boot"
  135. 0x000000200000-0x000001600000 : "Kernel"
  136. 0x000001600000-0x000008000000 : "user"
  137. nuc980-nadc: nuc980 Normal ADC adapter
  138. nuc980-audio nuc980-audio: nau8822-hifi <-> nuc980-audio-i2s mapping ok
  139. NET: Registered protocol family 17
  140. ALSA device list:
  141.   #0: nuc980_IIS
  142. Freeing unused kernel memory: 4200K
  143. BusyBox v1.22.1 (2016-02-03 14:11:04 CST) built-in shell (ash)
  144. Enter 'help' for a list of built-in commands.
  145. ~ #
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
