ML51_PWM_SINE-main.zip
(2.42 MB, 下载次数: 2)
- /*_____ I N C L U D E S ____________________________________________________*/
- #include "ML51.h"
- #include <math.h>
- #include "project_config.h"
- /*_____ D E C L A R A T I O N S ____________________________________________*/
- volatile uint8_t u8TH0_Tmp = 0;
- volatile uint8_t u8TL0_Tmp = 0;
- //UART 0
- //bit BIT_TMP;
- //bit BIT_UART;
- //bit uart0_receive_flag=0;
- //unsigned char uart0_receive_data;
- /*_____ D E F I N I T I O N S ______________________________________________*/
- #define SYS_CLOCK (24000000ul)
- #define PWM_FREQ (24000ul)
- #define PWM_CHANNEL (2)
- #define SINE_FREQ (60)
- #define SINE_RESOLUTION (360)
- #define Pi_Value (3.14159)
- volatile uint16_t PWM_Period = 0;
- uint16_t g_u16Sine_Count_u = 0;
- xdata uint16_t g_au16Sine[SINE_RESOLUTION] = {0};
- /*_____ M A C R O S ________________________________________________________*/
- volatile uint32_t BitFlag = 0;
- uint32_t counter_tick = 0;
- /*_____ F U N C T I O N S __________________________________________________*/
- void tick_counter(void)
- counter_tick++;
- uint32_t get_tick(void)
- return (counter_tick);
- void set_tick(uint32_t t)
- counter_tick = t;
- void compare_buffer(uint8_t *src, uint8_t *des, int nBytes)
- uint16_t i = 0;
- for (i = 0; i < nBytes; i++)
- if (src[i] != des[i])
- printf("error idx : %4d : 0x%2X , 0x%2X\r\n", i , src[i],des[i]);
- set_flag(flag_error , Enable);
- if (!is_flag_set(flag_error))
- printf("compare_buffer finish \r\n");
- set_flag(flag_error , Disable);
- void reset_buffer(void *dest, unsigned int val, unsigned int size)
- uint8_t *pu8Dest;
- // unsigned int i;
- pu8Dest = (uint8_t *)dest;
- #if 1
- while (size-- > 0)
- *pu8Dest++ = val;
- #else
- memset(pu8Dest, val, size * (sizeof(pu8Dest[0]) ));
- #endif
- void copy_buffer(void *dest, void *src, unsigned int size)
- uint8_t *pu8Src, *pu8Dest;
- unsigned int i;
- pu8Src = (uint8_t *)src;
- #if 0
- while (size--)
- *pu8Dest++ = *pu8Src++;
- #else
- for (i = 0; i < size; i++)
- pu8Dest[i] = pu8Src[i];
- #endif
- void dump_buffer(uint8_t *pucBuff, int nBytes)
- uint16_t i = 0;
- printf("dump_buffer : %2d\r\n" , nBytes);
- for (i = 0 ; i < nBytes ; i++)
- printf("0x%2X," , pucBuff[i]);
- if ((i+1)%8 ==0)
- printf("\r\n");
- printf("\r\n\r\n");
- void dump_buffer_hex(uint8_t *pucBuff, int nBytes)
- int nIdx, i;
- nIdx = 0;
- while (nBytes > 0)
- printf("0x%04X ", nIdx);
- for (i = 0; i < 16; i++)
- printf("%02X ", pucBuff[nIdx + i]);
- printf(" ");
- if ((pucBuff[nIdx + i] >= 0x20) && (pucBuff[nIdx + i] < 127))
- printf("%c", pucBuff[nIdx + i]);
- else
- printf(".");
- nBytes--;
- nIdx += 16;
- printf("\n");
- printf("\n");
- void delay(uint16_t dly)
- delay(100) : 14.84 us
- delay(200) : 29.37 us
- delay(300) : 43.97 us
- delay(400) : 58.5 us
- delay(500) : 73.13 us
- delay(1500) : 0.218 ms (218 us)
- delay(2000) : 0.291 ms (291 us)
- while( dly--);
- void send_UARTString(uint8_t* Data)
- #if 1
- uint16_t i = 0;
- while (Data[i] != '\0')
- #if 1
- SBUF = Data[i++];
- #else
- UART_Send_Data(UART0,Data[i++]);
- #endif
- #endif
- #if 0
- uint16_t i = 0;
- for(i = 0;i< (strlen(Data)) ;i++ )
- UART_Send_Data(UART0,Data[i]);
- #endif
- #if 0
- while(*Data)
- UART_Send_Data(UART0, (unsigned char) *Data++);
- #endif
- void send_UARTASCII(uint16_t Temp)
- uint8_t print_buf[16];
- uint16_t i = 15, j;
- *(print_buf + i) = '\0';
- j = (uint16_t)Temp >> 31;
- if(j)
- (uint16_t) Temp = ~(uint16_t)Temp + 1;
- do
- i--;
- *(print_buf + i) = '0' + (uint16_t)Temp % 10;
- (uint16_t)Temp = (uint16_t)Temp / 10;
- while((uint16_t)Temp != 0);
- if(j)
- i--;
- *(print_buf + i) = '-';
- send_UARTString(print_buf + i);
- void SineTable_Create(void)
- uint16_t i = 0;
- /* Create sine table for lookup */
- for (i = 0; i < SINE_RESOLUTION; i++)
- /* Add 1.0 to offset sine result from [-1, 1] to [0, 2],
- and divide with 2.0 to compress to [0, 1] */
- g_au16Sine[i] = ((sin((i * Pi_Value) / 180.0) + 1.0) / 2.0) * PWM_Period;
- void PWMx_Init(uint16_t ch , uint16_t uFrequency)
- uint32_t res = 0;
- switch(ch)
- case 2:
- MFP_P03_PWM0_CH2;
- P03_PUSHPULL_MODE;
- break;
- PWM0_IMDEPENDENT_MODE;
- PWM0_CLOCK_DIV_16;
- PWM frequency = Fpwm/((PWMPH,PWMPL)+1) = (24MHz/2)/(PWMPH,PWMPL)+1) = 20KHz
- res = (SYS_CLOCK >> 4); // 2 ^ 4 = 16
- res = res/uFrequency;
- res = res - 1;
- PWM_Period = res;
- SFRS = 1;
- PWM0PH = HIBYTE(res);
- PWM0PL = LOBYTE(res);
- PWM0C2H = HIBYTE(g_au16Sine[g_u16Sine_Count_u]);
- PWM0C2L = LOBYTE(g_au16Sine[g_u16Sine_Count_u]);
- g_u16Sine_Count_u++;
- /* Load PWM new setting and start PWM */
- set_PWM0CON0_LOAD;
- set_PWM0CON0_PWMRUN;
- void GPIO_Init(void)
- // P03_PUSHPULL_MODE;
- // P30_PUSHPULL_MODE;
- void Timer1_IRQHandler(void)
- SFRS = 1;
- /* Reset sine array pointer */
- if (g_u16Sine_Count_u == SINE_RESOLUTION)
- g_u16Sine_Count_u = 0;
- void Timer1_ISR(void) interrupt 3 // Vector [url=home.php?mod=space&uid=72445]@[/url] 0x0B
- clr_TCON_TF1;
- Timer1_IRQHandler();
- void Timer1_Init(void)
- uint16_t res = 0;
- uint16_t TIMER1_VALUE = 0;
- ENABLE_TIMER1_MODE2;
- TIMER1_FSYS_DIV12;
- Time-out period = (0xFF - TIMER1_VALUE) / clock frequency
- = 1 / (sine wave frequency * sine wave resolution)
- TIMER1_VALUE = 0xFF - ((24 MHz / 12) / (60 Hz * resolution)
- TIMER1_VALUE = 0xFF - (2000000ul/(SINE_FREQ*SINE_RESOLUTION));
- TH1 = TIMER1_VALUE;
- TL1 = TIMER1_VALUE;
- ENABLE_TIMER1_INTERRUPT; //enable Timer0 interrupt
- ENABLE_GLOBAL_INTERRUPT; //enable interrupts
- set_TCON_TR1; //Timer0 run
- void Timer0_IRQHandler(void)
- tick_counter();
- if ((get_tick() % 1000) == 0)
- // P03 ^= 1;
- void Timer0_ISR(void) interrupt 1 // Vector @ 0x0B
- TH0 = u8TH0_Tmp;
- TL0 = u8TL0_Tmp;
- clr_TCON_TF0;
- Timer0_IRQHandler();
- void Timer0_Init(void)
- uint16_t res = 0;
- ENABLE_TIMER0_MODE1;
- TIMER0_FSYS_DIV12;
- u8TH0_Tmp = HIBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000);
- u8TL0_Tmp = LOBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000);
- TH0 = u8TH0_Tmp;
- TL0 = u8TL0_Tmp;
- ENABLE_TIMER0_INTERRUPT; //enable Timer0 interrupt
- set_TCON_TR0; //Timer0 run
- //void Serial_ISR (void) interrupt 4
- // _push_(SFRS);
- // if (RI)
- // uart0_receive_flag = 1;
- // uart0_receive_data = SBUF;
- // clr_SCON_RI; // Clear RI (Receive Interrupt).
- // if (TI)
- // if(!BIT_UART)
- // TI = 0;
- // _pop_(SFRS);
- void UART0_Init(void)
- MFP_P31_UART0_TXD; // UART0 TXD use P1.6
- P31_QUASI_MODE; // set P1.6 as Quasi mode for UART0 trasnfer
- UART_Open(SYS_CLOCK,UART0_Timer3,115200); // Open UART0 use timer1 as baudrate generate and baud rate = 115200
- ENABLE_UART0_PRINTF;
- // printf("UART0_Init\r\n");
- void SYS_Init(void)
- FsysSelect(FSYS_HIRC);
- ALL_GPIO_QUASI_MODE;
- // ENABLE_GLOBAL_INTERRUPT; // global enable bit
- void main (void)
- SYS_Init();
- UART0_Init();
- GPIO_Init();
- PWMx_Init(PWM_CHANNEL , PWM_FREQ);
- SineTable_Create();
- Timer0_Init();
- Timer1_Init();
- while(1)
