表中RAM data和register data ,IO data ,ROM code
2139|0
 楼主| hxdjb 发表于 2008-11-26 10:55 | 显示全部楼层 |阅读模式
具体是什么东西?
------------- Call Depth ------------
 Depth  Interrupt    Function
    0        N         ProgramStart
    1        Y           _interrupt_l
    1        Y           _interrupt
    0        N         _main
C   1        N           _initalization
C   1        N           _delay02s
Stack Depth: 1
-------------- Data Map -------------
d -- Uninitialized data
D -- Initialized data
b -- Uninitialized bit data
B -- Initialized bit data
C -- C Register
-------------- RAM Data -------------
0x00  - - - - - - - - - - - - - - - -
0x10  - - - - - - - - - - - - - - - -
0x20  d d d d d d d b d d d d d d d -
0x30  - - - - - - - - - - - - - - - -
----------- Register Data -----------
0x00  - d d b d b b - - - - - - - - b
0x10  C - - - - - - - - - - - - - - -
-------------- IO Data --------------
0x00  - - - - - d d - - - - d d d d d
--------------- ROM Code ---------------
000000: 1410  JMP   0x010       [    16]
000001: 1FFF  ADD   A, @0xFF    [   255]
按照上面的提示d表示没有初始化的数据,可是我在程序里对的IO data的 0XO5,OX06都赋了值,他们是单片机的PORT5,PORT6端口。简单的功能都调试好了,可里面的东西都没理解.
