贴出一段Verilog的程序,请教~
2339|13
 楼主| pangning7085 发表于 2013-5-6 21:43 | 显示全部楼层 |阅读模式
困扰了我很久很久的问题:快哭了。。。。
很简单的程序如下:以一个状态机用于控制进程,第二段用于端口写数据和命令,第三段控制LED灯指示,成功则led亮、led2灭;否则led灭、led2亮。现在为什么下载成功以后两盏led灯不停闪烁呢??
reg[7:0] reg_int=0;
reg[7:0] data_372;
reg a0,wr,rd,cs,led_en,led2_en,t1;
reg[3:0] state;
reg[5:0] i,j,k;
parameter idle=0,wr_cmd_start=1,wr_wait=2,wr_cmd_end=3,delay=4;
parameter wr_cmd_start2=5,wr_wait2=6,wr_cmd_end2=7,wr_data_start=8,data_wait=9,wr_data_end=10,delay2=11,rd_data_start2=12,rd_wait2=13,rd_data_end2=14;
always@(posedge clk_1mhz or posedge rst or posedge sw)
if(sw==1)
                    state<=idle;
      else
   begin
     case(state)
           idle:
                                   begin
                                   cs<=0;i<=0;j<=0;k<=0;
                                   rd<=0;
                                   wr<=0;
                                   a0<=0;t1<=0;
                   if(rst==1) state<=wr_cmd_start;
                   else
                   state<=idle;        end
         wr_cmd_start:  begin
                                         t1<=1;
                                         a0<=1;
                                         rd<=1;
                                         cs<=0;
                                         wr<=0;
                                         state<=wr_wait;end
           wr_wait:
                                         state<=wr_cmd_end;
         wr_cmd_end: begin
                                         a0<=1;
                                         rd<=1;
                                         cs<=0;
                                         wr<=0;
                                         t1<=0;
                                   state<=delay;end
                         delay:
                             if (k>=6'b100000&&i>=6'b011001&&j>=6'b011001)
                                                 begin  k<=6'b000000;i<=6'b000000;j<=6'b000000;state<=wr_cmd_start2;end
                                 else if (j>=5'b011001&&i>=5'b011001)
                                                 begin  i<=6'b000000;j<=6'b000000;k<=k+6'b1;state<=delay;end
                                 else if (j>=5'b011001)
                                                 begin  j<=6'b000000;i<=i+6'b1;state<=delay;end
                                 else
                                                 begin  j<=j+6'b1;state<=delay;end     //delay 40ms
                        wr_cmd_start2: begin                                //xie ming ling
                                         a0<=1;
                                         rd<=1;
                                         cs<=0;
                                         wr<=0;
                                         t1<=0;
                                         state<=wr_wait2;end
                        wr_wait2:            //xie deng dai
                                         state<=wr_cmd_end2;
                        wr_cmd_end2: begin
                                         a0<=1;
                                         rd<=1;
                                         cs<=0;
                                         t1<=0;
                                         wr<=0;state<=wr_data_start;end
                        wr_data_start:                                 //xie ming ling
                        begin         a0<=0;
                                         rd<=1;
                                         cs<=0;
                                         wr<=0;
                                         state<=data_wait;
                                         end
                        data_wait:           //xie deng dai
                                         state<=wr_data_end;
                        wr_data_end: begin
                                         a0<=1;
                                         rd<=1;
                                         cs<=0;
                                         wr<=0;state<=delay2;end
                        rd_data_start2: begin
                                 a0<=0;
                                 rd<=0;
                                 cs<=0;
                                 wr<=1;
                                 state<=delay2;end
                    delay2:
                    if (reg_int==8'h51) state<=rd_data_end2;
                      else  if (k>=6'b110100)
                                                 begin              k<=6'b000000;state<=idle;end
                                 else
                                                 begin  k<=k+6'b1;state<=delay2;end     //delay 20us
                        rd_data_end2:
                 begin a0<=0;rd<=0;cs<=0;wr<=1;
                                 state<=rd_data_end2;        end
      default:state<=idle;
   endcase
end
always@(posedge clk_1mhz)
begin
   if (cs==0&&wr==0&&rd==1&&a0 ==1)
          if (t1==1) data_372<=8'h05;
          else if (t1==0) data_372<=8'h15;
          else  data_372<=8'bzzzzzzzz;
   else if (cs==0&&rd==1&&wr==0&&a0==0) data_372<=8'h02;
   else if (cs==0&&rd==0&&wr==1) reg_int<=data_372;
end
                  if (reg_int==8'h51) begin led_en<=1;led2_en<=0;end
                   else if (reg_int==8'h5f) begin led_en<=0;led2_en<=1;end
                   else begin led_en<=1;led2_en<=1;end
endmodule
Backkom80 发表于 2013-5-7 18:32 | 显示全部楼层
只看到上面这一句,下面没细看,问下你这个程序没报错?
 楼主| pangning7085 发表于 2013-5-7 22:15 | 显示全部楼层
只看到上面这一句,下面没细看,问下你这个程序 ...
没有啊,,,怎么了?
resxpl 发表于 2013-5-7 22:45 | 显示全部楼层
1) rd_data_start2状态没有用到
2) else  data_372<=8'bzzzzzzzz; // 没有用处的代码
3) state逻辑太复杂,
其中i, j, k只是简单的延时, 没有必要放到state输入逻辑中, 可以放到另一个always中.
Backkom80 发表于 2013-5-7 22:58 | 显示全部楼层
没有啊,,,怎么了?
敏感变量列表中有三个沿,用的是哪家芯片,X or A or L?
GoldSunMonkey 发表于 2013-5-7 23:03 | 显示全部楼层
太多条件啦
 楼主| pangning7085 发表于 2013-5-13 10:12 | 显示全部楼层
是ALTERA的芯片,请问有什么问题吗?
2) else  data_372
我会改进的,谢谢您~
 楼主| pangning7085 发表于 2013-5-13 10:13 | 显示全部楼层
太多条件啦
我也觉得,看得头晕,但是我还没有想好怎么修改,因为这只是一部分。。
Backkom80 发表于 2013-5-13 10:42 | 显示全部楼层
Q2能综合三个都是沿的敏感变量,这不太可能,查查code
 楼主| pangning7085 发表于 2013-5-13 11:09 | 显示全部楼层
好的,谢谢您~
zhuyi1234567899 发表于 2013-5-13 18:04 | 显示全部楼层
这个绝对报错啊,我刚开始写的时候也这么写过,屡试屡错
GoldSunMonkey 发表于 2013-5-13 20:52 | 显示全部楼层
嘿嘿,看来大家都是实践啊
好的,谢谢您~
试过了报结果
