- static int read_eeprom(struct am335x_baseboard_id *header)
- #if 1
- strcpy(header->name, "TQ335x");
- #else
- /* Check if baseboard eeprom is available */
- if (i2c_probe(CONFIG_SYS_I2C_EEPROM_ADDR)) {
- puts("Could not probe the EEPROM; something fundamentally "
- "wrong on the I2C bus.\n");
- return -ENODEV;
- /* read the eeprom using i2c */
- if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 2, (uchar *)header,
- sizeof(struct am335x_baseboard_id))) {
- puts("Could not read the EEPROM; something fundamentally"
- " wrong on the I2C bus.\n");
- return -EIO;
- if (header->magic != 0xEE3355AA) {
- * read the eeprom using i2c again,
- * but use only a 1 byte address
- if (i2c_read(CONFIG_SYS_I2C_EEPROM_ADDR, 0, 1, (uchar *)header,
- puts("Could not read the EEPROM; something "
- "fundamentally wrong on the I2C bus.\n");
- return -EIO;
- printf("Incorrect magic number (0x[%]x) in EEPROM\n",
- header->magic);
- return -EINVAL;
- #endif
- return 0;
通过上述修改,u-boot不去读取eeprom,而是直接将header的name赋值为"TQ335x",后面可以根据这一配置区分是否为TQ335x开发板。
然后是修改get_dpll_ddr_params(board/ti/am335x/board.c)函数,具体的修改内容如下:
- const struct dpll_params *get_dpll_ddr_params(void)
- struct am335x_baseboard_id header;
- enable_i2c0_pin_mux();
- i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE);
- if (read_eeprom(&header) < 0)
- puts("Could not get board ID.\n");
- if (board_is_tq335x(&header) || board_is_evm_sk(&header))
- return &dpll_ddr_evm_sk;
- else if (board_is_bone_lt(&header))
- return &dpll_ddr_bone_black;
- else if (board_is_evm_15_or_later(&header))
- else
- return &dpll_ddr;
然后是修改sdram_init(board/ti/am335x/board.c)函数,具体的修改内容如下:
- void sdram_init(void)
- __maybe_unused struct am335x_baseboard_id header;
- if (board_is_evm_sk(&header)) {
- * EVM SK 1.2A and later use gpio0_7 to enable DDR3.
- * This is safe enough to do on older revs.
- gpio_request(GPIO_DDR_VTT_EN, "ddr_vtt_en");
- gpio_direction_output(GPIO_DDR_VTT_EN, 1);
- if (board_is_evm_sk(&header) || board_is_tq335x(&header))
- config_ddr(303, &ioregs_evmsk, &ddr3_data,
- &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0);
- config_ddr(400, &ioregs_bonelt,
- &ddr3_beagleblack_data,
- &ddr3_beagleblack_cmd_ctrl_data,
- &ddr3_beagleblack_emif_reg_data, 0);
- config_ddr(303, &ioregs_evm15, &ddr3_evm_data,
- &ddr3_evm_cmd_ctrl_data, &ddr3_evm_emif_reg_data, 0);
- else
- config_ddr(266, &ioregs, &ddr2_data,
- &ddr2_cmd_ctrl_data, &ddr2_emif_reg_data, 0);
然后添加board_is_tq335x函数的具体实现,参考其它类似函数实现即可,由于我们的read_eeprom仅读到了name,其内容是"TQ335x",故可如下实现,在board/ti/am335x/board.h中添加如下内容:
- static inline int board_is_tq335x(struct am335x_baseboard_id *header)
- return !strncmp(header->name, "TQ335x", HDR_NAME_LEN);
- 最后是修改enable_board_pin_mux(board/ti/am335x/mux.c)函数,具体的修改内容如下:
- void enable_board_pin_mux(struct am335x_baseboard_id *header)
- /* Do board-specific muxes. */
- if (board_is_bone(header) || board_is_tq335x(header)) {
- /* Beaglebone pinmux */
- configure_module_pin_mux(i2c1_pin_mux);
- configure_module_pin_mux(mii1_pin_mux);
- configure_module_pin_mux(mmc0_pin_mux);
- #if defined(CONFIG_NAND)
- configure_module_pin_mux(nand_pin_mux);
- #elif defined(CONFIG_NOR)
- configure_module_pin_mux(bone_norcape_pin_mux);
- #else
- configure_module_pin_mux(mmc1_pin_mux);
- #endif
- } else if (board_is_gp_evm(header)) {
- /* General Purpose EVM */
- unsigned short profile = detect_daughter_board_profile();
- configure_module_pin_mux(rgmii1_pin_mux);
- /* In profile #2 i2c1 and spi0 conflict. */
- if (profile & ~PROFILE_2)
- /* Profiles 2 & 3 don't have NAND */
- #ifdef CONFIG_NAND
- if (profile & ~(PROFILE_2 | PROFILE_3))
- #endif
- else if (profile == PROFILE_2) {
- configure_module_pin_mux(spi0_pin_mux);
- } else if (board_is_idk(header)) {
- /* Industrial Motor Control (IDK) */
- configure_module_pin_mux(mmc0_no_cd_pin_mux);
- } else if (board_is_evm_sk(header)) {
- /* Starter Kit EVM */
- configure_module_pin_mux(gpio0_7_pin_mux);
- configure_module_pin_mux(mmc0_pin_mux_sk_evm);
- } else if (board_is_bone_lt(header)) {
- /* Beaglebone LT pinmux */
- #else
- #endif
- } else {
- puts("Unknown board, cannot configure pinmux.");
- hang();
另外,这个版本的u-boot有个bug,需要修改fat_register_device(fs/fat/fat.c)函数:
- int fat_register_device(block_dev_desc_t *dev_desc, int part_no)
- disk_partition_t info;
- /* First close any currently found FAT filesystem */
- cur_dev = NULL;
- /* Read the partition table, if present */
- if (get_partition_info(dev_desc, part_no, &info)) {
- /*if (part_no != 0) {
- printf("** Partition [%]d not valid on device [%]d **\n",
- part_no, dev_desc->dev);
- return -1;
- info.start = 0;
- info.size = dev_desc->lba;
- info.blksz = dev_desc->blksz;
- info.name[0] = 0;
- info.type[0] = 0;
- info.bootable = 0;
- #ifdef CONFIG_PARTITION_UUIDS
- info.uuid[0] = 0;
- #endif
- return fat_set_blk_dev(dev_desc, &info);
至此,u-boot就已经可以启动了,但是有多余的步骤和log,不过可以去掉,修改file_fat_read_at(fs/fat/fat.c)函数:
- long file_fat_read_at(const char *filename, unsigned long pos, void *buffer,
- unsigned long maxsize)
- debug("reading [%]s\n", filename);
- return do_fat_read_at(filename, pos, buffer, maxsize, LS_NO, 0);
最后,TQ335x是MLO启动u-boot,然后u-boot去启动内核,故可以去掉配置项CONFIG_SPL_OS_BOOT,具体的修改文件include/configs/ti_armv7_common.h:
- #if defined CONFIG_SPL_OS_BOOT_ENABLE
- #define CONFIG_SPL_OS_BOOT
- #endif
至此,u-boot的移植工作就完成了,下一步来研究如何启动内核。本文转自物联网博客(www.iotblog.cn),欢迎交流学习!
