实现still image capture & PTP遇到的问题
2804|2
xshtz|  楼主 | 2008-2-4 08:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
要实现的是still image capture & PTP
descriptor 如下:
const u8 SIC_DeviceDescriptor[SIC_SIZ_DEVICE_DESC] ={
    0x12,    /* bLength */
    0x01,    /* bDescriptorType */
    0x00,    /* bcdUSB, version 1.00 */
    0x01,
    0x00,    /* bDeviceClass : See interface */
    0x00,    /* bDeviceSubClass : See interface*/
    0x00,    /* bDeviceProtocol : See interface */
    0x08,   /* bMaxPacketSize0 0x40 = 64 */
    0x83,    /* idVendor    (0483) */
    0x04,
    0xb4,    /* idProduct */
    0x14,
    0x1A,    /* bcdDevice*/
    0x01,
    0x01,   /* iManufacturer : index of string Manufacturer  */
    0x02,    /* iProduct      : index of string descriptor of product */
    0x03,   /* iSerialNumber : index of string serial number */
    0x01    /* bNumConfigurations */
const u8 SIC_ConfigDescriptor[SIC_SIZ_CONFIG_DESC] = {
    0x09,    /* bLength: Configuation Descriptor size */
    0x02,    /* bDescriptorType: Configuration */
    SIC_SIZ_CONFIG_DESC,
            /* wTotalLength: Bytes returned */
    0x00,
    0x01,    /* bNumInterfaces: 1 interface */
    0x01,    /* bConfigurationValue: Configuration value */
    0x00,    /* iConfiguration: Index of string descriptor describing the configuration */
    0x80,    /* bmAttributes: bus powered */
    0x52,    /* MaxPower 100 mA: this current is used for detecting Vbus */
/* 09 */
/*** Descriptor of DFU interface 0 Alternate setting 0 ***/
    0x09,    /* bLength: Interface Descriptor size */
    0x04,    /* bDescriptorType: */
    0x00,    /* bInterfaceNumber: Number of Interface */
    0x00,    /* bAlternateSetting: Alternate setting */
    0x03,    /* bNumEndpoints*/
    0x06,    /* bInterfaceClass: SIC */
    0x01,    /* bInterfaceSubClass */
    0x01,    /* nInterfaceProtocol :PTP*/
    0x04,    /* iInterface: */
/* 18 */
    0x07,    /* bLength: Endpoint Descriptor size */
    0x05,    /* bDescriptorType: */
    0x81,   /* bEndpointAddress: */
    0x02,   /* bmAttributes: bulk transfers */
    0x40,   /* wMaxPacketSize:64 bytes */
    0x00,
    0x00,   /* bInterval:Ignored */
/* 25 */
    0x01,   /* bEndpointAddress: */
    0x00,
/* 32 */
    0x83,   /* bEndpointAddress: */
    0x03,   /* bmAttributes: interrupt transfers */
    0x00,
/* 39 */
}; /* SIC_ConfigDescriptor */
可以把基本的descriptor给传上去,pc识别为digital still camera。
一下为BUS HOUND的监控结果:
*************** monitor start **********************
Bus Hound 5.00 capture. Complements of www.perisoft.net
  Device - Device ID (followed by the endpoint for USB devices)
            (20) Digital Still Camera
  Phase  - Phase Type
            CTL   USB control transfer
            DI    Data in
            RSET  bus reset
            USTS  USB status
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Phase  Data                                                Description       Cmd.Phase.Ofs(rep)
  20.0  CTL    80 06 00 01  00 00 12 00                            GET DESCRIPTOR           1.1.0
  20.0  DI     12 01 00 01  00 00 00 08  83 04 b4 14  1a 01 01 02  ................         1.2.0
               03 01                                               ..                       1.2.16
  20.0  CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR           2.1.0
  20.0  DI     09 02 27 00  01 01 00 80  52                        ..'.....R                2.2.0
  20.0  CTL    80 06 00 02  00 00 27 00                            GET DESCRIPTOR           3.1.0
  20.0  DI     09 02 27 00  01 01 00 80  52 09 04 00  00 03 06 01  ..'.....R.......         3.2.0
               01 04 07 05  81 02 40 00  00 07 05 03  02 40 00 00  ......@......@..         3.2.16
               07 05 83 03  40 00 00                               ....@..                  3.2.32
  20.0  CTL    00 09 01 00  00 00 00 00                            SET CONFIG               4.1.0
  20.0  CTL    a1 67 00 00  00 00 24 00                            GET DEVICE STS           5.1.0
  20.0  DI     18 00 01 20  81 81 81 81  81 81 81 81  81 81 81 81  ... ............         5.2.0
               81 81 81 81  81 81 81 81                            ........                 5.2.16
  20.1  RSET        6.1.0
*************** monitor end ************************
最后一步20.1 RSET,但是我监控的实际是clear feature: 02 01 00 81 00
still image capture的spec上指明如果不支持feature则返回stall,我照做了,但没效果,卡在这边了!!!
从上一步讲:20.0 GET DEVICE STS,这个命令到底要回什么呢?
关于这个命令的回复,spec上写得有点难明白,请参照still image capture的spec1.0的11页。
在线等,急!!!
相关链接:https://bbs.21ic.com/upfiles/img/20082/20082482826899.pdf
xshtz|  楼主 | 2008-2-14 16:02 | 只看该作者
自己顶!!!
   上面关于clear feature的问题暂且不谈,因为在set config后,问题就出现了,一下是正常still image capture在set config后就直接发送PTP命令了! 现在的问题是在set config后,为什么我的结果是“get device sts”,而正常的是直接发ptp命令。
set config后简单的回个“OK”不就行了吗,难道还有什么其它隐藏的吗?
正常监控结果:
  19.0  CTL    00 09 01 00  00 00 00 00                            SET CONFIG               4.1.0
  19.2  DO     10 00 00 00  01 00 02 10  00 00 00 00  01 00 00 00  ................         5.1.0
xshtz|  楼主 | 2008-2-20 13:58 | 只看该作者
问题已解决,谢谢关注!~
