谁能告诉我下面的VerilogHDL语言每一句都是什么意思,谢谢!
1423|3
terry0501258|  楼主 | 2012-3-18 11:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
module fen(clk, kind, key, seg_bit, seg_dat, ext_sig, out);
input kind;
input [4:0] key;
input clk;
input ext_sig;
output reg [2:0]seg_bit;
output reg [7:0]seg_dat;
output reg out;
reg [7:0] dis_code[10:0];
reg [31:0] timer=0;
reg [3:0] dis_ram2, dis_ram1, dis_ram0;
reg [3:0] dis_bit=0;
reg [3:0] i=0, j=0, k=0;
reg b_but_en=0;
reg [15:0] counter=0;
reg b_f=0, b_ff=0;
reg [3:0]c_ff=0;
initial
begin
  dis_code[0]= 'b00111111;
  dis_code[1]= 'b00000110;
  dis_code[2]= 'b01011011;
  dis_code[3]= 'b01001111;
  dis_code[4]= 'b01100110;
  dis_code[5]= 'b01101101;
  dis_code[6]= 'b01111101;
  dis_code[7]= 'b00000111;
  dis_code[8]= 'b01111111;
  dis_code[9]= 'b01101111;
  dis_code[10]= 'b01000000;
  dis_ram0 = 1;
  dis_ram1 = 0;
  dis_ram2 = 4;
  i=0;
  j=0;
  k=0;
end
always @(posedge timer[20])  // key scan  and deal
begin
  if(key=='h1f) b_but_en = 1;
  else  if(b_but_en)
  begin
    b_but_en=0;
    if(!key[0])  //
    begin dis_ram0=dis_ram0+1; if(dis_ram0>=dis_ram2) dis_ram0=1; end
    else if(!key[1])  //
    begin dis_ram2=dis_ram2+1; if(dis_ram2>=10) dis_ram2=2; end
    else if(!key[2])  //
    begin dis_ram2=dis_ram2-1; if(dis_ram2==1) dis_ram2=9; end
    else if(!key[3])
    begin dis_ram1=dis_ram1+1; if(dis_ram1>=10) dis_ram1=0; end
    else if(!key[4])
    begin dis_ram1=dis_ram1-1; if(dis_ram1==15) dis_ram1=9; end
    if ((dis_ram1!=0)||(dis_ram2==1)) dis_ram0=10;
    else if(dis_ram0==10) dis_ram0=1;
  end
end
always @(posedge timer[15])
begin
  dis_bit = dis_bit+1;
  dis_bit = dis_bit%3;
  seg_bit = (~(1<<(dis_bit)));
  if(dis_bit==0)
  seg_dat = (~dis_code[dis_ram0]);
  else if(dis_bit==1)
  seg_dat = (~dis_code[dis_ram1]);
  else if(dis_bit==2)
  seg_dat = (~dis_code[dis_ram2]);
  if(dis_bit==2) seg_dat[7]=0;
end
always@ (posedge clk)
begin
  timer = timer+1;
end
always@ (posedge ext_sig)
//always@ (posedge b_ff)
//always@ ( posedge ext_sig or negedge ext_sig )
begin
  counter = counter+1;
    ///out = counter[0];
  if(dis_ram1==0)
  begin
     if(counter%(dis_ram2)==0)    out=1;
     else if(counter%(dis_ram2)==dis_ram0)  out=0;
end
  else
  begin
    // N.X?? (10-X)?N???X?(N+1)???
    if(dis_ram2%2==0)
    begin
      if(i>0)
      begin
        if(counter>=(dis_ram2)) begin out=1; i=i-1; counter=0; end
        else if(counter==(dis_ram2/2)) begin out=0; i=i-1; end
      end
      else if(j>0)
      begin
        if(counter>=(dis_ram2+1)) begin out=1; j=j-1; counter=0; end
        else if(counter==(dis_ram2/2)) begin out=0; j=j-1; end
        if(j==0)
        begin
          i=(10-dis_ram1)*2;
          j=dis_ram1*2;
        end
      end
      else
        begin
          i=(10-dis_ram1)*2;
          j=dis_ram1*2;
        end
    end
    else
      begin
      if(i>0)
      begin
        else if(counter==((dis_ram2-1)/2)) begin out=0; i=i-1; end
      end
      else if(j>0)
      begin
        else if(counter==((dis_ram2+1)/2)) begin out=0; j=j-1; end
        if(j==0)
        begin
          i=(10-dis_ram1)*2;
          j=dis_ram1*2;
        end
      end
      else
        begin
          i=(10-dis_ram1)*2;
          j=dis_ram1*2;
        end
    end
    end
end
endmodule
GoldSunMonkey| | 2012-3-18 18:06 | 只看该作者
这个要求。。有点
你自己看书吧。
或者到FPGA版和我一起学习。
