[C语言]
【菜鸟求助】在keil C51中如何引用外部.A51文件中的汇编宏?
1528|3
imba_sid|  楼主 | 2015-2-5 10:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在keil环境下,C文件需要引用一个外部的汇编宏,请教21朋友们怎么样可以做到?
亦或,在C51文件中如何定义一个嵌入的汇编宏?
为方便我贴下码源:
portSAVE_CONTEXT        MACRO
                /* Push ACC first, as when restoring the context it must be restored
                last (it is used to set the IE register).  */
                PUSH                ACC
                /* Store the IE register then disable interrupts. */
                PUSH                IE
                PUSH                B
                PUSH                DPX
                PUSH                DPH
                PUSH                DPL
                PUSH                PSW
                PUSH                AR0
                PUSH                AR1
                PUSH                AR2
                PUSH                AR3
                PUSH                AR4
                PUSH                AR5
                PUSH                AR6
                PUSH                AR7
        ENDM
imba_sid|  楼主 | 2015-2-5 10:49 | 只看该作者
求助,
imba_sid|  楼主 | 2015-2-5 11:06 | 只看该作者
在SDCC中是如下定义的:
* Macro to push the current execution context onto the stack, before the stack
* is moved to XRAM.
#define portSAVE_CONTEXT()        \
        _asm        \
                /* Push ACC first, as when restoring the context it must be restored                                        \
                last (it is used to set the IE register). */        \
                push        ACC        \
                /* Store the IE register then disable interrupts. */        \
                push        IE        \
                clr                _EA        \
                push        DPL        \
                push        DPH        \
                push        b        \
                push        ar2        \
                push        ar3        \
                push        ar4        \
                push        ar5        \
                push        ar6        \
                push        ar7        \
                push        ar0        \
                push        ar1        \
                push        PSW        \
        _endasm;        \
                PSW = 0;        \
        _asm        \
                push        _bp        \
        _endasm;        \
在keil中我把_asm        替换为#pragma asm 会提示#出错。
ayb_ice| | 2015-2-5 13:31 | 只看该作者
C当然不可以引用外部的宏了
做成子程序,声明好后,就可以调用了
