- #ifndef __WS2812_H
- #define __WS2812_H
- #include "stm32f10x.h"
- #define PIXEL_NUM 24
- //硬件spi模拟ws2811时序(用spi的8位数据模拟ws281x的一位数据)
- //要将系统时钟设置为56M,分频数设置为8,则SPI的通信频率为7M,传输一位数据的时间约为143纳秒(ns)
- //3*143 = 429ns 5*143 = 715ns 符合WS281X芯片的通信时序。
- // _____
- // | |___| 11111000 high level
- // ___
- // | |_____| 11100000 low level
- #define WS_HIGH 0XF8
- #define WS_LOW 0XE0
- void ws281x_init(void);
- void ws281x_closeAll(void);
- void ws281x_rainbowCycle(uint8_t wait);
- uint32_t ws281x_color(uint8_t red, uint8_t green, uint8_t blue);
- void ws281x_setPixelColor(uint16_t n ,uint32_t GRBcolor);
- void ws281x_show(void);
- void ws281x_theaterChase(uint32_t c, uint8_t wait);
- void ws281x_colorWipe(uint32_t c, uint8_t wait);
- void ws281x_rainbow(uint8_t wait);
- void ws281x_theaterChaseRainbow(uint8_t wait);
- #endif /* __WS2812_H */
- #include "../BOARD/ws2812/ws2812.h"
- #include "usart.h"
- #include "delay.h"
- uint8_t pixelBuffer[PIXEL_NUM][24] ;
- GPIO_InitTypeDef GPIO_InitStructure;
- SPI_InitTypeDef SPI_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //PORTA时钟使能
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); //SPI1时钟使能
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA传输
- /* PA7 SPI1_MOSI */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //PA7复用推挽输出 SPI
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA
- SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //串行同步时钟的空闲状态为低电平
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第2个跳变沿(上升或下降)数据被采样
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; //定义波特率预分频的值:波特率预分频值为16
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
- SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
- SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
- SPI_Cmd(SPI2, ENABLE); //使能SPI外设
- SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
- DMA_DeInit(DMA1_Channel5); //将DMA的通道1寄存器重设为缺省值
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) &(SPI2 -> DR); //cpar; //DMA外设ADC基地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)pixelBuffer; //cmar; //DMA内存基地址
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //数据传输方向,从内存读取发送到外设
- DMA_InitStructure.DMA_BufferSize = PIXEL_NUM * 24; //cndtr; //DMA通道的DMA缓存的大小
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //数据宽度为8位
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位
- DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //工作在正常缓存模式
- DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
- DMA_Init(DMA1_Channel5, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道USART1_Tx_DMA_Channel所标识的寄存器
- ws281x_closeAll(); //关闭全部的灯
- delay_ms(100); //关闭全部的灯需要一定的时间
- uint16_t i;
- uint8_t j;
- for(i = 0; i < PIXEL_NUM; ++i)
- for(j = 0; j < 24; ++j)
- pixelBuffer[i][j] = WS_LOW;
- ws281x_show();
- return green << 16 | red << 8 | blue;
- uint8_t i;
- if(n < PIXEL_NUM)
- for(i = 0; i < 24; ++i)
- pixelBuffer[n][i] = (((GRBcolor << i) & 0X800000) ? WS_HIGH : WS_LOW);
- void ws281x_setPixelRGB(uint16_t n ,uint8_t red, uint8_t green, uint8_t blue)
- uint8_t i;
- if(n < PIXEL_NUM)
- pixelBuffer[n][i] = (((ws281x_color(red,green,blue) << i) & 0X800000) ? WS_HIGH : WS_LOW);
- DMA_Cmd(DMA1_Channel5, DISABLE ); //关闭USART1 TX DMA1 所指示的通道
- DMA_ClearFlag(DMA1_FLAG_TC5);
- DMA_SetCurrDataCounter(DMA1_Channel5,24 * PIXEL_NUM );//DMA通道的DMA缓存的大小
- DMA_Cmd(DMA1_Channel5, ENABLE); //使能USART1 TX DMA1 所指示的通道
- // Input a value 0 to 255 to get a color value.
- // The colours are a transition r - g - b - back to r.
- uint32_t ws281x_wheel(uint8_t wheelPos) {
- wheelPos = 255 - wheelPos;
- if(wheelPos < 85) {
- return ws281x_color(255 - wheelPos * 3, 0, wheelPos * 3);
- if(wheelPos < 170) {
- wheelPos -= 85;
- return ws281x_color(0, wheelPos * 3, 255 - wheelPos * 3);
- wheelPos -= 170;
- return ws281x_color(wheelPos * 3, 255 - wheelPos * 3, 0);
- // Fill the dots one after the other with a color
- void ws281x_colorWipe(uint32_t c, uint8_t wait) {
- for(uint16_t i=0; i<PIXEL_NUM; i++) {
- ws281x_setPixelColor(i, c);
- ws281x_show();
- delay_ms(wait);
- void ws281x_rainbow(uint8_t wait) {
- uint16_t i, j;
- for(j=0; j<256; j++) {
- for(i=0; i<PIXEL_NUM; i++) {
- ws281x_setPixelColor(i, ws281x_wheel((i+j) & 255));
- ws281x_show();
- delay_ms(wait);
- // Slightly different, this makes the rainbow equally distributed throughout
- void ws281x_rainbowCycle(uint8_t wait) {
- uint16_t i, j;
- for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
- for(i=0; i< PIXEL_NUM; i++) {
- ws281x_setPixelColor(i,ws281x_wheel(((i * 256 / PIXEL_NUM) + j) & 255));
- ws281x_show();
- delay_ms(wait);
- //Theatre-style crawling lights.
- void ws281x_theaterChase(uint32_t c, uint8_t wait) {
- for (int j=0; j<10; j++) { //do 10 cycles of chasing
- for (int q=0; q < 3; q++) {
- for (uint16_t i=0; i < PIXEL_NUM; i=i+3) {
- ws281x_setPixelColor(i+q, c); //turn every third pixel on
- ws281x_show();
- delay_ms(wait);
- ws281x_setPixelColor(i+q, 0); //turn every third pixel off
- //Theatre-style crawling lights with rainbow effect
- void ws281x_theaterChaseRainbow(uint8_t wait) {
- for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
- ws281x_setPixelColor(i+q, ws281x_wheel( (i+j) % 255)); //turn every third pixel on
- ws281x_show();
- delay_ms(wait);
- const char s[5];
- int8_t i;
- int main(void)
- // usart1_init(115200);
- delay_init();
- ws281x_init();
- while(1)
- // Some example procedures showing how to display to the pixels:
- ws281x_colorWipe(ws281x_color(255, 0, 0), 50); // Red
- ws281x_colorWipe(ws281x_color(0, 255, 0), 50); // Green
- ws281x_colorWipe(ws281x_color(0, 0, 255), 50); // Blue
- //colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
- // Send a theater pixel chase in...
- ws281x_theaterChase(ws281x_color(127, 127, 127), 50); // White
- ws281x_theaterChase(ws281x_color(127, 0, 0), 50); // Red
- ws281x_theaterChase(ws281x_color(0, 0, 127), 50); // Blue
- //ws281x_rainbow(20);
- ws281x_rainbowCycle(20);
- ws281x_theaterChaseRainbow(200);
- ws281x_setPixelColor(i, ws281x_color(0,250,0));
- ws281x_show();
- delay_ms(500);
在ws2812.c移植了Adafruit_NeoPixel库的部分函数,用以实现炫酷的显示效果。
都是基础的SPI,不说废话,移植就能用。展示一下效果吧!
