- int main(void) {
- float temperature; // temperature [°C]
- float humidity; // relative humidity [%RH]
- char val[32]={'\0'};
- etError error; // error code
- system_clock_config();
- at32_board_init();
- uart_print_init(115200);
- printf("Start main ...\r\n");
- // 初始化TFT显示屏
- Lcd_Init();
- // 测试
- Lcd_Clear(BLACK);
- Gui_DrawFont_GBK16(8,10,WHITE, BLACK, (unsigned char *)"Artery & 21IC");
- Gui_DrawFont_GBK16(30,36,WHITE, BLACK, (unsigned char *)"AT32F405");
- // 初始化水位传感器、抽水马达控制口
- at32_led_on(LED2);
- mymac_Init();
- Gui_DrawFont_GBK16(0, 60,WHITE, BLACK, (unsigned char *)"初始化:");
- Gui_DrawFont_GBK16(10, 76,WHITE, BLACK, (unsigned char *)"水位控制接口");
- at32_led_off(LED2);
- at32_led_on(LED3);
- // 初始化温湿度传感器GXHT-30
- Gui_DrawFont_GBK16(10, 92,WHITE, BLACK, (unsigned char *)"传感器接口");
- gxht30_Init(GXHT30_ADDRESS);
- at32_led_off(LED3);
- Gui_DrawFont_GBK16(0, 110, WHITE, BLACK, (unsigned char *)"温度");
- Gui_DrawFont_GBK16(32,110, WHITE, BLACK, (unsigned char *)"=");
- Gui_DrawFont_GBK16(0, 126,WHITE, BLACK, (unsigned char *)"湿度");
- Gui_DrawFont_GBK16(32,126,WHITE, BLACK, (unsigned char *)"=");
- while(1) {
- // Gui_DrawFont_GBK16(58,84, WHITE, BLACK, (unsigned char *)" ");
- // Gui_DrawFont_GBK16(58,100, WHITE, BLACK, (unsigned char *)" ");
- //at32_led_toggle(LED2);
- //delay_ms(200);
- //at32_led_toggle(LED3);
- //delay_ms(200);
- //at32_led_toggle(LED4);
- //delay_ms(200);
- // error = gxht30_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_CLKSTRETCH, 50);
- // sprintf(val, "Result=0x%02x", error);
- // Gui_DrawFont_GBK16(0,142,WHITE, BLACK, (unsigned char *)val);
- SHT30_read_result(GXHT30_ADDRESS, &temperature, &humidity);
- sprintf(val, "%5.1f", temperature);
- Gui_DrawFont_GBK16(48,110,WHITE, BLACK, (unsigned char *)val);
- sprintf(val, "%5.1f", humidity);
- Gui_DrawFont_GBK16(48,126, WHITE, BLACK, (unsigned char *)val);
- delay_ms(1000);
目前的处理结果不对,应该卡在了传感器的读写时序上,正在检查中。
