[i.MX] 【经验分享】飞思卡尔IMX6处理器的GPIO配置方式
 楼主| FSL_TICS_imx 发表于 2014-2-26 16:34 | 显示全部楼层 |阅读模式
在linux或android系统中,假如我们要配置飞思卡尔IMX6处理器的GPIO管脚,比如是GPIO_19这个管脚,那么要像这样:
#define MX6Q_PAD_GPIO_19__GPIO_4_5                              \
                                (_MX6Q_PAD_GPIO_19__GPIO_4_5| MUX_PAD_CTRL(NO_PAD_CTRL))
其中_MX6Q_PAD_GPIO_19__GPIO_4_5定义为:
  #define _MX6Q_PAD_GPIO_19__GPIO_4_5         \
         IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0)
这个IOMUX_PAD宏是定义GPIO的关键宏,其原型为:
#define IOMUX_PAD(_pad_ctrl_ofs, _mux_ctrl_ofs, _mux_mode, _sel_input_ofs,
       _sel_input, _pad_ctrl)
IOMUX_PAD宏有6个参数,每个参数的意思是:
参数
含义
_pad_ctrl_ofs
控制寄存器的偏移地址(16进制)
_mux_ctrl_ofs
MUX控制寄存器的偏移地址(16进制), 用于选择引脚的功能
_mux_mode
MUX模式,bit0~3,范围0~7
_select_input_ofs
SELECT_INPUT寄存器偏移地址(16进制)
_select_input
Daisy Chain模式, bit0~1,范围0~3
_pad_ctrl
bits to be set in register _pad_ctrl_ofs for  configuration selection
具体的含义要结合IMX6数据手册【Chapter 36 IMOUX Controller(IOMUXC)】的内容。
以下就GPIO_19这个管脚的配置进行说明:
1_pad_ctrl_ofs
找到数据手册:
从上图可知:_pad_ctrl_ofs = 0x624
2_mux_ctrl_ofs_mux_mode
找到数据手册的内容:
如上图,_mux_ctrl_ofs取值为0x254,_mux_mode范围为000~110
只有_mux_mode = 0时,_select_input_ofs和_select_input才有效,其余时候_select_input_ofs和_select_input 都为0。
3_select_input_of_select_input
当_mux_mode = 0时,_select_input_ofs的取值需参考数据手册:
此时_select_input_ofs=0x8e8,_select_input=0x1
4_pad_ctrl
_pad_ctrl一般取值为0
综上所述,GPIO_19的配置宏定义如下:
  #define _MX6Q_PAD_GPIO_19__**_COL_5            \
         IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0)
#define _MX6Q_PAD_GPIO_19__ENET_1588_EVENT0_OUT     \
         IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__SPDIF_OUT1           \
         IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__CCM_CLKO         \
         IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__ECSPI1_RDY           \
         IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__ENET_TX_ER           \
         IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0)
  #define _MX6Q_PAD_GPIO_19__SRC_INT_BOOT         \
         IOMUX_PAD(0x0624, 0x0254, 7, 0x0000, 0, 0)
以上的宏定义来自imx6的linux源码的arm/arch/palt-mxc/include/mach/iomux-mx6q.h
希望对大家有帮助~~
FSL_TICS_A 发表于 2014-2-26 16:52 | 显示全部楼层
很好的分享,必须顶一下!!
FSL_TICS_Rita 发表于 2014-3-5 10:49 | 显示全部楼层
好贴,很实用,顶一下~~
williamhwf2011 发表于 2014-3-8 20:32 | 显示全部楼层
很详细,赞一个
afei8856 发表于 2014-3-10 15:30 | 显示全部楼层
不错,顶一下
FSL_TICS_Rita 发表于 2014-3-11 12:56 | 显示全部楼层
感谢大家对飞思卡尔的关注和支持,同时欢迎大家在论坛总创贴大家一起交流学习~~
a151937404 发表于 2014-4-30 21:07 | 显示全部楼层
这个数据手册哪有的下载 ?
bestray 发表于 2014-6-30 20:23 | 显示全部楼层
。如果把GPIO配置以及相应驱动操作一起示例说明一下的话,那就更好了~~
gaoqian0529 发表于 2014-7-1 13:45 | 显示全部楼层
楼主好,请问把GPIO配置成悬浮输入状态,怎么设置?我查到imx6 管脚配置
谢谢
aeromoon 发表于 2014-7-31 10:23 | 显示全部楼层
顶一下
da_jun 发表于 2014-10-21 23:02 | 显示全部楼层
请教一个问题:
我现在用 IMX_GPIO_NR(4, 15) 配置成GPIO_4_15 模式当作 Volice-的按键,通过看pdf发现这个引脚也是UART5的CTS引脚,我按照pdf将这个引脚配置成了MX6Q_PAD_KEY_ROW4__GPIO_4_15,可是这个引脚一直是低电平,外界按键的点击不能改变电平,导致android系统进入安装模式,哪位大侠指导一下啊?!
还有就是我一直没有发现IMX_GPIO_NR(4, 15)这个配置是怎么和MX6Q_PAD_KEY_ROW4__GPIO_4_15联系到一起的?
望大侠一并指教!!
xlb7679 发表于 2014-12-23 17:35 | 显示全部楼层
请叫一个问题,,imx6在申请中断的时候  request_irq(int  irq_no,……)函数,这里的irq_no可不可以静态的分配,就是比如我要用98号中断,直接给传98给irq_no,可是返回值ret一直是 -22   ,假如要用gpio_to_irq(unsigned gpio)函数来获取,参数怎么填,这个参数unsigned gpio也是在iomux-mx6q.h中找宏定义吗?真心求解答
mini1986 发表于 2015-5-8 11:09 | 显示全部楼层
好贴,收藏了......谢谢分享......
tianhaolan 发表于 2015-8-11 09:04 | 显示全部楼层
很好的分享,必须顶一下!!
wolfkinwolfkin 发表于 2015-12-11 09:04 | 显示全部楼层
必须mark
wolfkinwolfkin 发表于 2015-12-11 16:16 | 显示全部楼层
好帖,强势围观
阿基米东 发表于 2017-4-19 17:56 | 显示全部楼层
怎么配置成可以通过 /sys/ 来操作 GPIO?
yushan210 发表于 2017-9-7 13:05 | 显示全部楼层
imx6ul  有 IMX_GPIO_NR 吗?
梦幻情缘 发表于 2018-3-16 18:10 | 显示全部楼层
你好,正在学imx,刚开始,想请教一下,我在用IOMUX_PAD这个函数,编译时报错这个函数没有定义,但是内核源码里面是有的,这是怎么回事?
个人签名:   Freescale Semiconductor     i.MX Community    i.MX 中文论坛
29
