| | | PCA, System Board A7136-69001
screw on SCSI connector 0380-4855 see: http://15.13.122.166/newsletters/mc6/flash_newsletter375.htm
PCI Riser Board A7231-66530 *** PCI Backplane
CPU PA8800 800 MHz 32MB Cache A7138-69002 (without Power Pod, Mako32)
CPU PA8800 1GHz 32MB Cache AB354-69001 (without Power Pod, Mako32)
CPU PA8900 800 MHz 64MB Cache AB534-69001 (without Power Pod, Mako64)
CPU PA8900 1GHz 64MB Cache AB535-69001 (without Power Pod, Mako64)
Processor Toolkit 5069-5441 (order one of these tools if
Processor Toolkit (rx2600) A7231-67046 a CPU has to be replaced
or ask the CE if he has
such a tool)
CPU Power Pod 0950-4294
SCSI Backplane A7231-66520
#Memory 1.7 " Dimms have been replaced with 1.2 " Dimms.
#See WTEC/KMINE 4000076558
256MB DIMM A6967AX (old was A6833-69001)
512MB DIMM A6968AX (old was A6746-69001)
1GB Dimm A6969-69001 (old was A6834-69001)
2GB Dimm A6835-69001
MP Card A7231-66580
SCSI
36GB 15K Ultra 320 SCSI Disk A7836-69001
73GB 15K Ultra 320 SCSI Disk A9897-69001
146GB 15K Ultra 320 SCSI Disk A9898-69001
DVD Slimline A7231-69011
CD-RW/DVD Slimline A6986-69001
CABLES
Fan Cable 80mm A7231-63006
Super Fan Cable 80mm A7231-63005
SCSI Cable Channel A A7231-63017
SCSI Cable Channel B A7231-63018
IDE Cable A7231-63002 for DVD drive
Management Processor Flex Cbl. A7231-63008
Status Panel Cable A7231-63003
Disk Power Cable A7231-63004
POWER
AC Power Supply A6874-69000
Power Suppy Interface Module A7231-04018
cpu power pod 0950-4294
Super Fan 80mm A7231-04015 Fan #2
Thin Fan 80mm A7231-04014 Fan #1A + #1B
Dual Fan Assy A7231-04033 Fan #3
MISC
Display Panel A7231-66550 |
