[DemoCode下载] M0518通过看门狗复位系统
1560|13
 楼主| yiyigirl2014 发表于 2017-3-25 14:10 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
  4. * $Revision: 2 $
  5. * $Date: 14/12/25 10:24a $
  6. * @brief
  7. *           Show how to generate time-out reset system event while WDT time-out reset delay period expired.
  8. *
  9. * @note
  10. * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M0518.h"
  14. #define PLL_CLOCK           50000000
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. /* Global Interface Variables Declarations        */
  17. /*---------------------------------------------------------------------------------------------------------*/
  18. volatile uint8_t g_u8IsWDTTimeoutINT = 0;
  19. /**
  20. * [url=home.php?mod=space&uid=247401]@brief[/url]       IRQ Handler for WDT and WWDT Interrupt
  21. *
  22. * @param       None
  23. *
  24. * [url=home.php?mod=space&uid=266161]@return[/url]      None
  25. *
  26. * [url=home.php?mod=space&uid=1543424]@Details[/url]     The WDT_IRQHandler is default IRQ of WDT and WWDT, declared in startup_M0518.s.
  27. */
  28. void WDT_IRQHandler(void)
  29. {
  30.     if(WDT_GET_TIMEOUT_INT_FLAG() == 1)
  31.     {
  32.         /* Clear WDT time-out interrupt flag */
  33.         WDT_CLEAR_TIMEOUT_INT_FLAG();
  34.         g_u8IsWDTTimeoutINT = 1;
  35.     }
  36. }
  37. void SYS_Init(void)
  38. {
  39.     /*---------------------------------------------------------------------------------------------------------*/
  40.     /* Init System Clock        */
  41.     /*---------------------------------------------------------------------------------------------------------*/
  42.     /* Enable HIRC clock */
  43.     CLK_EnableXtalRC(CLK_PWRCON_IRC22M_EN_Msk);
  44.     /* Waiting for HIRC clock ready */
  45.     CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
  46.     /* Switch HCLK clock source to HIRC */
  47.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  48.     /* Enable HXT and LIRC */
  49.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_IRC10K_EN_Msk);
  50.     /* Waiting for clock ready */
  51.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
  52.     /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
  53.     CLK_SetCoreClock(PLL_CLOCK);
  54.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLK_S_HCLK_DIV2);
  55.     /* Enable peripheral clock */
  56.     CLK_EnableModuleClock(UART0_MODULE);
  57.     CLK_EnableModuleClock(WDT_MODULE);
  58.     /* Peripheral clock source */
  59.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
  60.     CLK_SetModuleClock(WDT_MODULE, CLK_CLKSEL1_WDT_S_LIRC, 0);
  61.     /*---------------------------------------------------------------------------------------------------------*/
  62.     /* Init I/O Multi-function        */
  63.     /*---------------------------------------------------------------------------------------------------------*/
  64.     /* Set PB multi-function pins for UART0 RXD, TXD */
  65.     SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
  66. }
  67. void UART0_Init(void)
  68. {
  69.     /*---------------------------------------------------------------------------------------------------------*/
  70.     /* Init UART        */
  71.     /*---------------------------------------------------------------------------------------------------------*/
  72.     /* Reset IP */
  73.     SYS_ResetModule(UART0_RST);
  74.     /* Configure UART0 and set UART0 Baudrate */
  75.     UART_Open(UART0, 115200);
  76. }
  77. /*---------------------------------------------------------------------------------------------------------*/
  78. /*  MAIN function        */
  79. /*---------------------------------------------------------------------------------------------------------*/
  80. int main(void)
  81. {
  82.     /* Unlock protected registers */
  83.     SYS_UnlockReg();
  84.     /* Init System, peripheral clock and multi-function I/O */
  85.     SYS_Init();
  86.     /* Lock protected registers */
  87.     SYS_LockReg();
  88.     /* Init UART0 for printf */
  89.     UART0_Init();
  90.     if(WDT_GET_RESET_FLAG() == 1)
  91.     {
  92.         /* Use PA.0 to check time-out period time */
  93.         GPIO_SetMode(PA, 0, GPIO_PMD_OUTPUT);
  94.         PA0 = 1;
  95.         WDT_CLEAR_RESET_FLAG();
  96.         printf("*** System has been reset by WDT time-out event ***\n\n");
  97.         while(1);
  98.     }
  99.     printf("CPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  100.     printf("+---------------------------------------------+\n");
  101.     printf("|    WDT Time-out Reset System Sample Code    |\n");
  102.     printf("+---------------------------------------------+\n\n");
  103.     printf("# WDT Settings:\n");
  104.     printf("    - Clock source is 10 kHz                \n");
  105.     printf("    - Time-out interval is 2^14 * WDT clock \n");
  106.     printf("      (around 1.6384 second)                \n");
  107.     printf("    - Interrupt enable                      \n");
  108.     printf("    - Reset function enable                 \n");
  109.     printf("    - Reset delay period is 18 * WDT clock  \n");
  110.     printf("# System will generate a WDT time-out interrupt event after around 1.6384 second.\n");
  111.     printf("    (Use PA.0 low period time to check WDT time-out interval)\n");
  112.     printf("# Do not reset WDT counter in WDT_IRQHandler and system will be reset immediately by WDT time-out reset signal.\n\n");
  113.     /* Use PA.0 to check time-out period time */
  114.     GPIO_SetMode(PA, 0, GPIO_PMD_OUTPUT);
  115.     PA0 = 1;
  116.     PA0 = 0;
  117.     /* Because of all bits can be written in WDT Control Register are write-protected;
  118.        To program it needs to disable register protection first. */
  119.     SYS_UnlockReg();
  120.     /* Enable WDT time-out reset function and select time-out interval to 2^14 * WDT clock then start WDT counting */
  121.     g_u8IsWDTTimeoutINT = 0;
  122.     WDT_Open(WDT_TIMEOUT_2POW14, WDT_RESET_DELAY_18CLK, TRUE, FALSE);
  123.     /* Enable WDT interrupt function */
  124.     WDT_EnableInt();
  125.     /* Enable WDT NVIC */
  126.     NVIC_EnableIRQ(WDT_IRQn);
  127.     while(1);
  128. }
  129. /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
iwqt1983 发表于 2017-3-25 14:15 | 显示全部楼层
错看成了MINI58,听说 MINI58的成本更低,性价比很高的。才3元左右一片。
 楼主| yiyigirl2014 发表于 2017-3-25 14:30 | 显示全部楼层
好牛叉,通过这个检测是不是通过看门狗复位的。
 楼主| yiyigirl2014 发表于 2017-3-25 14:32 | 显示全部楼层
mini51吧,确实很便宜,买多的话估计一块钱就OK。
iwqt1983 发表于 2017-3-25 14:52 | 显示全部楼层
是的,估计可以做到1元多点吧,看量的。
稳稳の幸福 发表于 2017-3-25 16:42 | 显示全部楼层
very GOOD。
zhuomuniao110 发表于 2017-3-25 17:10 | 显示全部楼层
配置
huangcunxiake 发表于 2017-3-25 21:11 | 显示全部楼层
虽然单片机一个功能实现很多代码,但是过程中每个细节都是可控的。
天灵灵地灵灵 发表于 2017-3-25 22:57 | 显示全部楼层
这个最好再来个打印消息更嗨皮。
dongnanxibei 发表于 2017-3-27 11:31 | 显示全部楼层
好多复位都有个标识符,用于检测是哪种复位。
稳稳の幸福 发表于 2017-3-27 15:13 | 显示全部楼层
        PA0 = 1;
设置PA0输出高电平,用于显示是否发生了看门狗中断。
dongnanxibei 发表于 2017-3-29 18:45 | 显示全部楼层
时钟的配置如果全部做好一个流程图那就给力了,或者通过预编译的方式自动配置。
dongnanxibei 发表于 2017-3-29 18:46 | 显示全部楼层
只需要传递一个想要的参数,预编译就帮你选好你所能选择的最优方案。
 楼主| yiyigirl2014 发表于 2017-4-6 21:37 | 显示全部楼层
每一种复位都会对应一个标志位。
