[verilog] 7系列的封装兼容性呢?
4866|10
 楼主| 星星之火红 发表于 2012-2-19 17:16 | 显示全部楼层 |阅读模式
看了很多,不知道7系列XILINX的封装兼容性如何呢?
GoldSunMonkey 发表于 2012-2-19 17:18 | 显示全部楼层
官方回答:
自己看看吧。
Artix-7 devices are only pin compatible with other Artix-7 devices in the same package.
For example, all Artix-7 devices in the FTG256 will be pin compatible.
Kintex-7 devices are pin compatible with other Kintex-7 devices in the same package.
In addition, FBG and FFG packages of the same pin-count designator
will be pin compatible with a few notes.  It should be noted the FBG and FFG will
have substantially different decoupling capacitor recommendations.  Also note
that FBG packages do not utilize Vccaux_IO pins. In the FFG packages the
vccaux_io_g must be connected in order to drive the predriver for the HR I/Os.
Therefore, if you are planning on migrating to the FFG you must connect
vccaux_io to the appropriate voltage/regulator solution for your final design。
Virtex-7 devices are pin compatible with other Virtex-7 devices in the same
package.  In addition FFG, FHG, and 标志寄存器 packages of the same pin-count
designator will be pin compatible a note.  FH packages will have a larger lid the
FFG or 标志寄存器.
 楼主| 星星之火红 发表于 2012-2-19 17:22 | 显示全部楼层
OK 谢谢啦。
快乐出发 发表于 2012-2-20 15:52 | 显示全部楼层
官网有就的。LZ跟我一样懒。。。
litgb 发表于 2012-3-25 13:05 | 显示全部楼层
学习
O(∩_∩)O~
vivisa 发表于 2012-3-25 17:34 | 显示全部楼层
davines 发表于 2012-3-25 17:43 | 显示全部楼层
学习了。
xlhtracy 发表于 2012-3-26 11:06 | 显示全部楼层
ledaa 发表于 2012-3-26 16:59 | 显示全部楼层
[img][/img]
GoldSunMonkey 发表于 2012-3-26 20:51 | 显示全部楼层
