HC32L110把DEMO的UART1改成UART0 TIMER1改成了TIMER0,无法通讯
2461|3
 楼主| 7456 发表于 2021-6-11 21:35 | 显示全部楼层 |阅读模式
int32_t main(void)
    uint16_t timer=0;
    uint32_t pclk=0;
    volatile uint32_t u32Val = 0;
    stc_clk_config_t stcCfg;
    stc_uart_config_t  stcConfig;
    stc_uart_irq_cb_t stcUartIrqCb;
    stc_uart_multimode_t stcMulti;
    stc_uart_baud_config_t stcBaud;
    stc_bt_config_t stcBtConfig;
    //警告!!!为防止程序进入低功耗无法调试,请勿删除以下两行代码
    SK_SW2_INIT();
//    NextStep();
    Clk_SwitchTo(ClkRCL);
    Clk_SetRCHFreq(ClkFreq22_12Mhz);
    Clk_SwitchTo(ClkRCH);
    u32Val = Clk_GetHClkFreq();
    stcCfg.enClkSrc = ClkRCH;
    stcCfg.enHClkDiv = ClkDiv1;
    stcCfg.enPClkDiv = ClkDiv1;
    Clk_Init(&stcCfg);
    DDL_ZERO_STRUCT(stcUartIrqCb);
    DDL_ZERO_STRUCT(stcMulti);
    DDL_ZERO_STRUCT(stcBaud);
    DDL_ZERO_STRUCT(stcBtConfig);
    Gpio_InitIOExt(3, 4, GpioDirOut, TRUE, FALSE, TRUE, FALSE);
    Gpio_InitIOExt(3, 3, GpioDirOut, TRUE, FALSE, TRUE, FALSE);
    Gpio_InitIOExt(3, 2, GpioDirOut, TRUE, FALSE, TRUE, FALSE);
        Gpio_SetIO(3, 4, TRUE);
        Gpio_SetIO(3, 3, TRUE);
        Gpio_SetIO(3, 2, TRUE);
    Gpio_InitIOExt(3,1,GpioDirOut,TRUE,FALSE,FALSE,FALSE);
    Gpio_InitIOExt(2,7,GpioDirOut,TRUE,FALSE,FALSE,FALSE);
    //通道端口配置
    Gpio_SetFunc_UART0TX_P31();
    Gpio_SetFunc_UART0RX_P27();
    //外设时钟使能
    Clk_SetPeripheralGate(ClkPeripheralBt,TRUE);//模式0/2可以不使能
    Clk_SetPeripheralGate(ClkPeripheralUart0,TRUE);
    stcUartIrqCb.pfnRxIrqCb = RxIntCallback;
    stcUartIrqCb.pfnTxIrqCb = NULL;
    stcUartIrqCb.pfnRxErrIrqCb = ErrIntCallback;
    stcConfig.pstcIrqCb = &stcUartIrqCb;
    stcConfig.bTouchNvic = TRUE;
    stcConfig.enRunMode = UartMode1;//测试项,更改此处来转换4种模式测试
    stcMulti.enMulti_mode = UartNormal;//测试项,更改此处来转换多主机模式,mode2/3才有多主机模式
    stcConfig.pstcMultiMode = &stcMulti;
    stcBaud.bDbaud = 0u;//双倍波特率功能
    stcBaud.u32Baud = 2400u;//更新波特率位置
    stcBaud.u8Mode = UartMode1; //计算波特率需要模式参数
    pclk = Clk_GetPClkFreq();
    timer=Uart_SetBaudRate(UARTCH0,pclk,&stcBaud);
    stcBtConfig.enMD = BtMode2;
    stcBtConfig.enCT = BtTimer;
    Bt_Init(TIM0, &stcBtConfig);//调用basetimer1设置函数产生波特率
    Bt_ARRSet(TIM0,timer);
    Bt_Cnt16Set(TIM0,timer);
    Bt_Run(TIM0);
    Uart_Init(UARTCH0, &stcConfig);
    Uart_EnableIrq(UARTCH0,UartRxIrq);
    Uart_ClrStatus(UARTCH0,UartRxFull);
    Uart_EnableFunc(UARTCH0,UartRx);
//设置GPIO值(翻转)
    while (1)
        //输出高电平,LED3灭
        delay1ms(200);
                        Uart_SendData(UARTCH0,'A');
        //输出低电平,LED3亮
        Gpio_SetIO(3, 4, FALSE);
        delay1ms(200);
xyz549040622 发表于 2021-6-12 07:29 | 显示全部楼层
你到底是串口无法工作呢?还是定时器无法工作呢?还是两者都无法工作呢?
 楼主| 7456 发表于 2021-6-12 08:27 | 显示全部楼层
你到底是串口无法工作呢?还是定时器无法工作呢?还是两者都无法工作呢? ...
串口0能接收无法发送,这个口是用于烧录用的,程序通过串口烧录都正常,所以硬件上应该不存在问题。
 楼主| 7456 发表于 2021-6-12 10:52 来自手机 | 显示全部楼层
很感谢,自己解决了,关闭swd即可
