- h0=figure('toolbar','none',...
- 'position',[198 56 408 468],...
- 'name','实例55');
- h1=axes('parent',h0,...
- 'position',[0.15 0.5 0.7 0.5],...
- 'visible','off');
- huidiao=[...
- 'yearnum=str2num(get(edit1,''string''));,',...
- 'monthnum=str2num(get(edit2,''string''));,',...
- 'daynum=str2num(get(edit3,''string''));,',...
- 'monthday=[0 31 28 31 30 31 30 31 31 30 31 30 31];,',...
- 'dyear=yearnum-2000;,',...
- 'beishu=fix(dyear/4);,',...
- 'yushu=rem(yearnum,4);,',...
- 'if yushu==0,',...
- 'monthday(3)=29;,',...
- 'end,',...
- 'mday=0;,',...
- 'for i=1:monthnum,',...
- 'mday=monthday(i)+mday;,',...
- 'end,',...
- 'yearday=mday+daynum-1;,',...
- 'noweek=fix(yearday/7);,',...
- 'set(edit5,''string'',[''第'',num2str(noweek),''周'']);,',...
- 'if dyear>0,',...
- 'beishu=beishu-1;,',...
- 'end,',...
- 'dday=yearday+365*dyear+beishu+1;,',...
- 'end,',...
- 'if dyear<=0,',...
- 'dday=365*dyear+yearday+beishu;,',...
- 'end,',...
- 'mweek=rem(dday,7)+7;,',...
- 'if mweek==8,',...
- 'set(edit4,''string'',''Sunday'');,',...
- 'end,',...
- 'if mweek==9,',...
- 'set(edit4,''string'',''Monday'');,',...
- 'end,',...
- 'if mweek==10,',...
- 'set(edit4,''string'',''Tuesday'');,',...
- 'end,',...
- 'if mweek==11,',...
- 'set(edit4,''string'',''Wednesday'');,',...
- 'end,',...
- 'if mweek==12,',...
- 'set(edit4,''string'',''Thursday'');,',...
- 'end,',...
- 'if mweek==13,',...
- 'set(edit4,''string'',''Friday'');,',...
- 'end,',...
- 'if mweek==7,',...
- 'set(edit4,''string'',''Saturday'');,',...
- 'end,',...
- 'if mweek==6,',...
- 'end,',...
- 'if mweek==5,',...
- 'end,',...
- 'if mweek==4,',...
- 'end,',...
- 'if mweek==3,',...
- 'end,',...
- 'if mweek==2,',...
- 'end,',...
- 'if mweek==1,',...
- 'end'];
- edit1=uicontrol('parent',h0,...
- 'style','edit',...
- 'horizontalalignment','right',...
- 'position',[40 300 50 20]);
- text1=uicontrol('parent',h0,...
- 'style','text',...
- 'string','年',...
- 'horizontalalignment','left',...
- 'position',[90 300 50 20]);
- edit2=uicontrol('parent',h0,...
- 'position',[160 300 50 20]);
- text2=uicontrol('parent',h0,...
- 'string','月',...
- 'position',[210 300 50 20]);
- edit3=uicontrol('parent',h0,...
- 'position',[280 300 50 20]);
- text3=uicontrol('parent',h0,...
- 'string','日',...
- 'position',[330 300 50 20]);
- edit4=uicontrol('parent',h0,...
- 'position',[210 200 120 20]);
- text4=uicontrol('parent',h0,...
- 'string','查找的日期为',...
- 'position',[110 200 100 20]);
- edit5=uicontrol('parent',h0,...
- 'position',[210 100 120 20]);
- 'string','该日处于',...
- 'position',[160 100 50 20]);
- button1=uicontrol('parent',h0,...
- 'style','pushbutton',...
- 'position',[80 40 80 30],...
- 'string','开始',...
- 'callback',huidiao);
- button2=uicontrol('parent',h0,...
- 'position',[220 40 80 30],...
- 'string','关闭',...
- 'callback','close');
