ti提供的触摸板的程序
2598|0
 楼主| gaochy1126 发表于 2012-6-4 10:46 | 显示全部楼层 |阅读模式
#include  "msp430g2231.h"
#define     LED1                  BIT0
#define     LED2                  BIT6
#define     LED_DIR               P1DIR
#define     LED_OUT               P1OUT
#define     BUTTON                BIT3
#define     BUTTON_OUT            P1OUT
#define     BUTTON_DIR            P1DIR
#define     BUTTON_IN             P1IN
#define     BUTTON_IE             P1IE
#define     BUTTON_IES            P1IES
#define     BUTTON_IFG            P1IFG
#define     BUTTON_REN            P1REN
#define     TXD                   BIT1                      // TXD on P1.1
#define     RXD                   BIT2                      // RXD on P1.2
#define     APP_STANDBY_MODE      0
#define     APP_APPLICATION_MODE  1
#define     TIMER_PWM_MODE        0
#define     TIMER_UART_MODE       1
#define     TIMER_PWM_PERIOD      2000
#define     TIMER_PWM_OFFSET      20
#define     TEMP_SAME             0
#define     TEMP_HOT              1
#define     TEMP_COLD             2
#define     TEMP_THRESHOLD        5
//   Conditions for 9600/4=2400 Baud SW UART, SMCLK = 1MHz
#define     Bitime_5              0x05*4                      // ~ 0.5 bit length + small adjustment
#define     Bitime                13*4//0x0D
#define     UART_UPDATE_INTERVAL  1000
unsigned char BitCnt;
unsigned char applicationMode = APP_STANDBY_MODE;
unsigned char timerMode = TIMER_PWM_MODE;
unsigned char tempMode;
unsigned char calibrateUpdate = 0;
unsigned char tempPolarity = TEMP_SAME;
unsigned int TXByte;
/* Using an 8-value moving average filter on sampled ADC values */
long tempMeasured[8];
unsigned char tempMeasuredPosition=0;
long tempAverage;
long tempCalibrated, tempDifference;
void InitializeLeds(void);
void InitializeButton(void);
void PreApplicationMode(void);                     // Blinks LED, waits for button press
void ConfigureAdcTempSensor(void);
void ConfigureTimerPwm(void);
void ConfigureTimerUart(void);
void Transmit(void);
void InitializeClocks(void);
void main(void)
  unsigned int uartUpdateTimer = UART_UPDATE_INTERVAL;
  unsigned char i;
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  InitializeClocks();
  InitializeButton();
  InitializeLeds();
  PreApplicationMode();                     // Blinks LEDs, waits for button press
  /* Application Mode begins */
  applicationMode = APP_APPLICATION_MODE;
  ConfigureAdcTempSensor();
  ConfigureTimerPwm();
  __enable_interrupt();                     // Enable interrupts.
  /* Main Application Loop */
  while(1)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0 with interrupts enabled
    /* Moving average filter out of 8 values to somewhat stabilize sampled ADC */
    tempMeasured[tempMeasuredPosition++] = ADC10MEM;
    if (tempMeasuredPosition == 8)
      tempMeasuredPosition = 0;
    tempAverage = 0;
    for (i = 0; i < 8; i++)
      tempAverage += tempMeasured[i];
    tempAverage >>= 3;                      // Divide by 8 to get average
    if ((--uartUpdateTimer == 0) || calibrateUpdate )
      ConfigureTimerUart();
      if (calibrateUpdate)
        TXByte = 248;                       // A character with high value, outside of temp range
        Transmit();
      TXByte = (unsigned char)( ((tempAverage - 630) * 761) / 1024 );
      Transmit();
    tempDifference = tempAverage - tempCalibrated;
    if (tempDifference < -TEMP_THRESHOLD)
      tempDifference = -tempDifference;
      tempPolarity = TEMP_COLD;
      LED_OUT &= ~ LED1;
    else
    if (tempDifference > TEMP_THRESHOLD)
      tempPolarity = TEMP_HOT;
      LED_OUT &= ~ LED2;
    else
      TACCTL0 &= ~CCIE;
      TACCTL1 &= ~CCIE;
      LED_OUT &= ~(LED1 + LED2);
    if (tempPolarity != TEMP_SAME)
      tempDifference <<= 3;
      tempDifference += TIMER_PWM_OFFSET;
      TACCR1 = ( (tempDifference) < (TIMER_PWM_PERIOD-1) ? (tempDifference) : (TIMER_PWM_PERIOD-1) );
      TACCTL0 |= CCIE;
      TACCTL1 |= CCIE;
  LED_DIR |= LED1 + LED2;
  LED_OUT |= LED1;                          // To enable the LED toggling effect
  LED_OUT &= ~LED2;
  BCSCTL1 |= DIVA_1;                        // ACLK/2
  BCSCTL3 |= LFXT1S_2;                      // ACLK = VLO
  TACCR0 = 1200;                             //
  TACTL = TASSEL_1 | MC_1;                  // TACLK = SMCLK, Up mode.
  TACCTL1 = CCIE + OUTMOD_3;                // TACCTL1 Capture Compare
  TACCR1 = 600;
  __bis_SR_register(LPM3_bits + GIE);          // LPM0 with interrupts enabled
  unsigned char i;
  /* Configure ADC Temp Sensor Channel */
  ADC10CTL1 = INCH_10 + ADC10DIV_3;         // Temp Sensor ADC10CLK/4
  ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
  __delay_cycles(1000);                     // Wait for ADC Ref to settle
  tempCalibrated = ADC10MEM;
  for (i=0; i < 8; i++)
    tempMeasured[i] = tempCalibrated;
  tempAverage = tempCalibrated;
  TACCR0 = TIMER_PWM_PERIOD;                              //
  TACTL = TASSEL_2 | MC_1;                  // TACLK = SMCLK, Up mode.
  TACCTL0 = CCIE;
  TACCR1 = 1;
  timerMode = TIMER_UART_MODE;              // Configure TimerA0 UART TX
  CCTL0 = OUT;                              // TXD Idle as Mark
  TACTL = TASSEL_2 + MC_2 + ID_3;           // SMCLK/8, continuous mode
  P1SEL |= TXD + RXD;                       //
  P1DIR |= TXD;                             //
// Function Transmits Character from TXByte
void Transmit()
  BitCnt = 0xA;                             // Load Bit counter, 8data + ST/SP
  while (CCR0 != TAR)                       // Prevent async capture
    CCR0 = TAR;                             // Current state of TA counter
  CCR0 += Bitime;                           // Some time till first bit
  TXByte |= 0x100;                          // Add mark stop bit to TXByte
  TXByte = TXByte << 1;                     // Add space start bit
  CCTL0 =  CCIS0 + OUTMOD0 + CCIE;          // TXD = mark = idle
  while ( CCTL0 & CCIE );                   // Wait for TX completion
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  if (timerMode == TIMER_UART_MODE)
    CCR0 += Bitime;                         // Add Offset to CCR0
    if (CCTL0 & CCIS0)                      // TX on CCI0B?
      if ( BitCnt == 0)
        P1SEL &= ~(TXD+RXD);
        CCTL0 &= ~ CCIE ;                   // All bits TXed, disable interrupt
      else
        CCTL0 |=  OUTMOD2;                  // TX Space
        if (TXByte & 0x01)
        CCTL0 &= ~ OUTMOD2;                 // TX Mark
        TXByte = TXByte >> 1;
        BitCnt --;
  else
    if (tempPolarity == TEMP_HOT)
      LED_OUT |= LED1;
    if (tempPolarity == TEMP_COLD)
      LED_OUT |= LED2;
    TACCTL0 &= ~CCIFG;
#pragma vector=TIMERA1_VECTOR
__interrupt void ta1_isr(void)
  TACCTL1 &= ~CCIFG;
  if (applicationMode == APP_APPLICATION_MODE)
  else
    LED_OUT ^= (LED1 + LED2);
  BCSCTL1 = CALBC1_1MHZ;                    // Set range
  DCOCTL = CALDCO_1MHZ;
  BCSCTL2 &= ~(DIVS_3);                     // SMCLK = DCO = 1MHz
void InitializeButton(void)                 // Configure Push Button
  BUTTON_DIR &= ~BUTTON;
  BUTTON_OUT |= BUTTON;
  BUTTON_REN |= BUTTON;
  BUTTON_IES |= BUTTON;
  BUTTON_IFG &= ~BUTTON;
  BUTTON_IE |= BUTTON;
* Port Interrupt for Button Press
* 1. During standby mode: to exit and enter application mode
* 2. During application mode: to recalibrate temp sensor
#pragma vector=PORT1_VECTOR
__interrupt void PORT1_ISR(void)
  BUTTON_IFG = 0;
  BUTTON_IE &= ~BUTTON;            /* Debounce */
  WDTCTL = WDT_ADLY_250;
  IFG1 &= ~WDTIFG;                 /* clear interrupt flag */
  IE1 |= WDTIE;
    tempCalibrated = tempAverage;
    calibrateUpdate  = 1;
  else
    applicationMode = APP_APPLICATION_MODE; // Switch from STANDBY to APPLICATION MODE
    __bic_SR_register_on_exit(LPM3_bits);
#pragma vector=WDT_VECTOR
__interrupt void WDT_ISR(void)
    IE1 &= ~WDTIE;                   /* disable interrupt */
    WDTCTL = WDTPW + WDTHOLD;        /* put WDT back in hold state */
    BUTTON_IE |= BUTTON;             /* Debouncing complete */
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR (void)
  __bic_SR_register_on_exit(CPUOFF);        // Return to active mode
