我正在使用 Modbus 主从通信,Modbus 主机工作正常,但从机存在通信问题。
使用`HAL_UARTEx_ReceiveToIdle_IT()`接收 Modbus 帧,使用`HAL_UART_Transmit_IT()`发送应答。当前测试仅做读操作。
LPUART 在接收中断上无法唤醒 MCU。
相关信息如下:
初始化阶段
#define LPUART1_EXTI_ENABLE_IT() (EXTI->IMR1 |= EXTI_IMR1_IM28)
LPUART1_EXTI_ENABLE_IT();
__HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI);
__HAL_RCC_HSI_ENABLE();
当没有收发操作时,MCU 进入休眠。收发处理完成前会维持忙状态;处理完成后进入休眠。休眠逻辑如下:
//Preparation for next receive data
RS485_RX_ENABLE();//Its macro to receive RX data on line.
__HAL_UART_FLUSH_DRREGISTER(&hlpuart1);
HAL_UART_AbortReceive(&hlpuart1)
HAL_UARTEx_ReceiveToIdle_IT(&hlpuart1, &gRxBuf[0], UART_RX_BUF_SIZE);
//Below code is to go stop2 mode
__HAL_UART_CLEAR_FLAG(&hlpuart1, UART_CLEAR_PEF | UART_CLEAR_NEF | UART_CLEAR_OREF);
uint32_t dummy = hlpuart1.Instance->RDR; // flush RDR
(void)dummy;
WakeUpSelection.WakeUpEvent = UART_WAKEUP_ON_STARTBIT;
if (HAL_UARTEx_StopModeWakeUpSourceConfig(&hlpuart1, WakeUpSelection) != HAL_OK)
Error_Handler();
while (__HAL_UART_GET_FLAG(&hlpuart1, USART_ISR_BUSY) == SET);
/* make sure that LPUART is ready to receive
* (test carried out again later in HAL_UARTEx_StopModeWakeUpSourceConfig) */
while (__HAL_UART_GET_FLAG(&hlpuart1, USART_ISR_REACK) == RESET);
/* Enable the LPUART Wake UP from STOP mode Interrupt */
__HAL_UART_DISABLE_IT(&hlpuart1, UART_IT_WUF);
__HAL_UART_ENABLE_IT(&hlpuart1, UART_IT_WUF);
/* enter STOP mode */
HAL_UARTEx_EnableStopMode(&hlpuart1);
HAL_SuspendTick();
HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);
HAL_ResumeTick();
Reset_SystemClock();
HAL_UARTEx_DisableStopMode(&hlpuart1);
(void)dummy;
Error_Handler();
HAL_SuspendTick();
HAL_ResumeTick();
测试中使用 LPTIMER 唤醒功能正常,但 LPUART 接收无法唤醒。
