一个system verilog的问题,求行家解决
6005|17
 楼主| sahh 发表于 2012-8-20 17:29 | 显示全部楼层 |阅读模式
代码用modelsim仿真,vlog已经过了,但是vsim报错。
** Fatal: (vsim-3695) ../src/ram_256x40/block_ram_256x40_wrap.sv(0): The interface port 'port_a' must be passed an actual interface.
代码如下:
interface block_ram_IF;
      logic [7:0]     block_addr_wr;
      logic             block_wren;
      logic [39:0]   block_data_wr;
      wire             clk_block_wr;
      logic [7:0]     block_addr_rd;
      logic [39:0]   block_data_rd;
      wire              clk_block_rd;
modport to_block_ram (
  output  clk_block_wr,
  output  clk_block_rd,
  output  block_wren,
  output  block_addr_wr,
  output  block_data_wr,
  output  block_addr_rd,
  input  block_data_rd
modport block_ram (
  input  clk_block_wr,
  input  clk_block_rd,
  input  block_wren,
  input  block_addr_wr,
  input  block_data_wr,
  input  block_addr_rd,
  output  block_data_rd
endinterface
module block_ram_256x40_wrap (
input   mode,
input   a_b,
block_ram_IF.block_ram port_a,
block_ram_IF.block_ram port_b,
block_ram_IF.block_ram port_c
wire [7:0] wraddress;
wire   wrclock;
wire   wren;
wire [39:0] data;
wire   rdaddress;
wire   rdclock;
wire [39:0] q;
assign wraddress = (a_b) ? port_a.block_addr_wr : port_b.block_addr_wr;
assign wrclock   = (a_b) ? port_a.clk_block_wr : port_b.clk_block_wr;
assign wren   = (mode) ? ((plot_a_b) ? port_a.block_wren : port_b.block_wren) : 1'b0;
assign data   = (a_b) ? port_a.block_data_wr : port_b.block_data_wr;
assign rdaddress = (mode) ? ((a_b) ? port_a.block_addr_rd : port_b.block_addr_rd) : port_c.block_addr_rd;
assign rdclock   = (mode) ? ((a_b) ? port_a.clk_block_rd : port_b.clk_block_rd) : port_c.clk_block_rd;
assign port_a.block_data_rd = q;
assign port_b.block_data_rd = q;
assign port_c.block_data_rd = q;
ram_256x40 u_block_ram (
// write
.wraddress ( wraddress ), // input [7:0]
.wrclock ( wrclock ), // input
.wren  ( wren ),  // input
.data  ( data ),  // input [39:0]
// read
.rdaddress ( rdaddress ), // input [7:0]
.rdclock ( rdclock ), // input
.q   ( q )   // output [39:0]
endmodule
 楼主| sahh 发表于 2012-8-20 17:36 | 显示全部楼层
我反复对照过system verilog的语法书,应该没有语法错误。
而且,用vlog编译也能过了。
但是仿真的时候就报错。郁闷ing....
搞不下去了,请老大、前辈指点指点,
谢谢了
GoldSunMonkey 发表于 2012-8-20 21:54 | 显示全部楼层
是不是使用到库,库没有编译呢?
 楼主| sahh 发表于 2012-8-21 18:42 | 显示全部楼层
自己解决了。
通常一个模块,它的端口不接东西,midelsim是允许的,仿真的时候不会报错。
但是如果端口是interface类型的,modelsim不允许interface类型的接口悬空不接。
所以,把接口接好,不要悬空,就好了。
评分
参与人数 1威望 +2 收起 理由
GoldSunMonkey + 2 解决就好。
查看全部评分
GoldSunMonkey 发表于 2012-8-21 20:22 | 显示全部楼层
喜欢解决后,恢复解决方案的兄弟。
mcu8031 发表于 2012-8-24 11:24 | 显示全部楼层
请问ise支持system erilog了吗
abcsmile 发表于 2012-8-24 16:58 | 显示全部楼层
我是来学习的,哈哈
liugp25 发表于 2012-8-24 17:05 | 显示全部楼层
学习了
gool 发表于 2012-8-24 17:13 | 显示全部楼层
学习一下
GoldSunMonkey 发表于 2012-8-24 19:05 | 显示全部楼层
nju044 发表于 2012-10-24 15:57 | 显示全部楼层
sahh,你好:我错误和你一样:Fatal: (vsim-3695) E:/kn/src_questasim100c/SV4Veri_2nd/chap4/4.4.2/test.sv(0): The interface port 'arbif' must be passed an actual interface.不过没明白你怎么解决的。。。我初学SV,希望能帮忙一下,谢谢!附件是程序,非常简单。
loansat 发表于 2012-10-24 17:49 | 显示全部楼层
学习一下
xjsxjtu 发表于 2012-10-24 23:45 | 显示全部楼层
:)对system verilog,完全不懂。
jakfens 发表于 2012-10-25 14:00 | 显示全部楼层
GoldSunMonkey 发表于 2012-10-25 17:05 | 显示全部楼层
怎么了?
tuqiaozi 发表于 2014-5-26 07:20 | 显示全部楼层
自己解决了。
你好,我也遇到了一模一样的问题,按照你说的,在所有module中都连接了interface中定义的信号,但是该问题依然存在啊,我的程序如下,请帮忙看看吧,谢啦。
interface alu_if(input bit clk);
  logic a,b,rst;
  logic f1,f2;
  modport ALU (output f1,
               output f2,
               input clk,
               input rst,
               input a,
               input b);
  modport ALU_TEST (input clk,
                    output rst,
                    output a,
                    output b);
endinterface
`timescale 1ns/100ps
module alu_test(alu_if.ALU_TEST aluif);
  initial begin
    @(posedge aluif.clk);
    aluif.rst <= 1'b1;
    repeat(2)@(posedge aluif.clk);
    aluif.rst <= 1'b0;
    aluif.rst <= 1'b1;
    aluif.a <= 1'b0;
    aluif.b <= 1'b0;
    repeat(100)@(posedge aluif.clk);
    $finish;
  end
  always #10 aluif.a <= aluif.a + 1;
  always #20 aluif.b <= aluif.b + 1;
endmodule : alu_test
module alu(alu_if.ALU aluif);
  always@(posedge aluif.clk or negedge aluif.rst)
  begin
    if(!aluif.rst)
      begin
        aluif.f1 <= 1'b0;
        aluif.f2 <= 1'b0;
      end
    else
      begin
        aluif.f1 <= aluif.a + aluif.b;
        aluif.f2 <= aluif.a - aluif.b;
      end
  end
endmodule
module alu_top;
  bit clk;
  always #5 clk=~clk;
  alu_if aluif(clk);
  alu al(aluif);
  alu_test at(aluif);
endmodule : alu_top
andous 发表于 2014-5-26 18:47 | 显示全部楼层
恭喜恭喜
雄飞 发表于 2019-10-24 07:14 来自手机 | 显示全部楼层
你好,我也遇到了一模一样的问题,按照你说的,在所有module中都连接了interface中定义的信号,但是该问 ...
你好,我也遇到这样的问题,我的代码结构和你的一模一样,我想请教一下,你是怎么解决的
