关于AVR,怎能不说点废话
17238|109
hqhuq 发表于 2007-7-14 23:08 | 显示全部楼层
AVR低档的MCU很差
M48抗干扰太差.
以前用Tiny13, RC偏差大, 只有写程序用频率逐个调, 90K啊.
judge 发表于 2007-7-15 09:25 | 显示全部楼层
顶一下.这个我也没有注意.
会不会是个BUG, 还听AVR反馈. 希望有结果.回来贴一下.
但我从来没有出现过EEPROM出现问题情况.
 楼主| yewuyi 发表于 2007-7-15 18:19 | 显示全部楼层
回LS兄弟,即使出问题了,你也不好鉴定
因为RC OSC原因导致EE问题的……
zhaoyu2005 发表于 2007-7-15 20:04 | 显示全部楼层
最近本来打算用AVR,大家说的让我都不敢用了
gtw 发表于 2007-7-16 21:25 | 显示全部楼层
回复的结果似乎不沾边,继续问
gtw 发表于 2007-7-17 07:45 | 显示全部楼层
看看回复的结果
Dear Customer
If you look at figure 28-40 and 28-41 on page 336-337, you can see the common frequency of the oscillator vs. Vcc and temperature. At the Atmel factory every MCU is calibrated to be within 8 MHz +- 10 %, this is done in the most common voltage and temperature range, 3V and 25C. This is the range we can guarantee you that the oscillator frequency is within. If you are gonna use the MCU for very high temperatures, we recommend you to do a user calibration.
For the eeprom/flash failure. There is very little chance that this will cause a problem, but if you find a MCU that does that, we will replace it with a new one, or you can just calibrate it.
There are possible to get better accuracy from the factory, but please note that this is only available for customer with 200k + volumes.
Best Regards
Andreas Holm
Atmel AVR Technical Support
gtw 发表于 2007-7-17 07:51 | 显示全部楼层
200k
也不过是20w,atmel在中国一年还卖不了20W吗?如果卖到的话,就请从atmel进货时就要求校准到3%吧。因为如果因为这个出了岔子的话,不知道还能不能卖到2个。
 楼主| yewuyi 发表于 2007-7-17 08:52 | 显示全部楼层
大家再发……
aihe 发表于 2007-7-17 10:07 | 显示全部楼层
赛扬系列
xhdzwzj 发表于 2008-3-18 20:28 | 显示全部楼层
简直就是欺诈行为
随意修改数据手册,还不如改改型号。建议把atmel也改个名字吧,大家看改个什么名字合适。。。
