TM4C129什么时候出来?
5757|7
 楼主| 二月寒风 发表于 2013-6-27 10:35 | 显示全部楼层 |阅读模式
TM4C129什么时候出来?IAR KEIL已经提供支持,TI网上还没有资料。跳票太久了
houjiakai 发表于 2013-6-28 00:50 | 显示全部楼层
这个得问厂家的。
1988020566 发表于 2013-6-28 23:55 | 显示全部楼层
有这个型号么?
 楼主| 二月寒风 发表于 2013-7-11 12:32 | 显示全部楼层
www-keil_
com-dd-chip-7099.htm[/url]
Texas Instruments TM4C1290NCPDT
The Texas Instruments TM4C1290NCPDT is an ARM Cortex-M4F Processor Core - 120-MHz operation; 150 DMIPS performance - ARM Cortex SysTick Timer - Nested Vectored Interrupt Controller (NVIC) - IEEE754-compliant single-precision floating-point unit - Memory Protection Unit (MPU) On-Chip Memory - 1024 KB Flash - 256 KB SRAM - 6 KB EEPROM - Internal ROM loaded with TivaWare for C Series software External Peripheral Interface (EPI) - 8-/16-/32- bit dedicated interface for peripherals and memory Cyclical Redundancy Check (CRC) Hardware - 16-/32-bit Hash function that supports 4 CRC forms Tamper - Support for 4 tamper inputs and configurable tamper event response Communication Interfaces - 8 UARTs - 4 SSI modules with Bi-, Quad- and advanced SSI support - 10 I2C modules with 4 transmission speeds including high-speed mode - 2 CAN 2.0 A/B controllers - USB 2.0 OTG/Host/Device with ULPI interface option and Link Power Management (LPM) support System Integration - ARM PrimeCell 32-chn configurable uDMA controller - 8 16/32-bit GPTM blocks - 2 watchdog timers - Low-power battery-backed Hibernation module - 15 physical GPIO blocks Advanced Motion Control - 1 PWM module with 4 PWM generator blocks and a control block, for a total of 8 PWM outputs - 1 QEI module Analog Support - 2 12-bit ADC modules with a maximum sample rate of 2 million samples/sec - 3 independent integrated analog comparators - 16 digital comparators JTAG and ARM Serial Wire Debug (SWD) 128-pin TQFP package.
原野牧歌 发表于 2013-7-14 08:59 | 显示全部楼层
这个是带以太网支持的吧,现在不知道啥时候出来了,好像说是下半年,邮件去TI问,没有回复。
 楼主| 二月寒风 发表于 2013-11-1 15:50 | 显示全部楼层
www ti com/product/tm4c129encpdt  终于出来了,不容易啊.
dirtwillfly 发表于 2013-11-1 17:24 | 显示全部楼层
不容易啊,半年都过去了
pmp 发表于 2013-11-1 17:38 | 显示全部楼层
关于TI最新产品可以去德州仪器在线支持社区去看看的,里面的资料多,就是网页刷新太慢了 ,
希望TI能够把自己服务器也升级一下,每次去都得等好长时间才能出现页面的。
