GD32F130的PA6,PA7作PWM的问题
2480|1
 楼主| GreatBlueLine 发表于 2014-8-29 14:34 | 显示全部楼层 |阅读模式
程序设置如下
void PWM_Init(void)
        GPIO_InitTypeDef         GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef        TIM_OCInitStructure;
        // TIM3参数设置
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
        // 配置GPIO管脚参数设置
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_1); // GPIO管脚复用设置
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_1);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_1);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_1);
        TIM_TimeBaseStructure.TIM_Period = 2250;                    //自动重装载值,取值必须在0x0000~0xFFFF之间
        TIM_TimeBaseStructure.TIM_Prescaler =0;                     //预分频值,取值必须在0x0000~0xFFFF之间,+1为分频系数
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;                                 //时钟分割
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;        //向上计数模式
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);                         //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;             //TIM脉冲宽度调制模式1
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
        TIM_OCInitStructure.TIM_Pulse =0;                           //设置待装入捕获比较寄存器的脉冲值,取值必须在0x0000~0xFFFF之间,占空比101/1001
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;     //输出极性:TIM输出比较极性高
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OC1Init(TIM3, &TIM_OCInitStructure);          //根据TIM_OCInitStruct中指定的参数初始化外设TIMx
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);
        TIM_OC4Init(TIM3, &TIM_OCInitStructure);
        TIM_Cmd(TIM3, ENABLE);
        TIM_CtrlPWMOutputs(TIM3, ENABLE);
PB0,PB1的PWM输出没有问题,但是PA6,PA7却不行,是哪儿出了问题?
1398117027 发表于 2014-8-29 20:55 | 显示全部楼层
是不是库里没有包含呢,你读寄存器看看
