MSP430f149+mlx90614 测温求帮助!!!
1640|3
 楼主| kumasuzuki 发表于 2015-3-24 14:07 | 显示全部楼层 |阅读模式
本人毕设用msp430f149+mlx90614想做个测温度的装置
但不知为何 在实验板上测试了两周也无法得到mlx90614的ack
还请各位大神帮助 本人算430半小白
情况 供电无问题 90614 SCL SDA引脚均接了上拉电阻 然后
直接连到430引脚上 本人想用SMbus通信
还请各位大神帮助!!!
下面是程序:#include  <msp430x14x.h>
void Delay(unsigned int n);
void start_bit();
void stop_bit();
void send_bit(unsigned char bit_out);
unsigned char receive_bit();
unsigned char slave_ack();
void TX_byte(unsigned char TX_buffer);
unsigned char RX_byte(unsigned char ack_nack);
unsigned char PEC_cal(unsigned char pec[],int n);
unsigned long int MEM_READ( unsigned char slave_addR, unsigned char cmdR );
void CALTEMP(unsigned long int TEMP);
void mlx90614_SCL_0() { P1OUT &= ~0x02;}  // define P1.1 ---> SCL
void mlx90614_SCL_1() { P1OUT |= 0x02;}
void mlx90614_SDA_0() { P1OUT &= ~0x04;}  // define P1.2 ---> SDA
void mlx90614_SDA_1() { P1OUT |= 0x04;}
#define _SDA_OUTPUT P1DIR |=0x04; //Set SDA as Output
#define _SDA_INPUT P1DIR &=~0x04; //Set SDA as Input
#define SDA ((P1IN & BIT2)>>1) //define input pin
void main(void)
  WDTCTL = WDTPW + WDTHOLD;         // Stop Watch dog timer
   BCSCTL1 = RSEL0 + RSEL1 + RSEL2;          // XT2on, max RSEL
    DCOCTL = DCO0 + DCO1 + DCO2;              // Max DCO
   P1DIR = 0xFF;     // All P1.x outputs
  P1OUT = 0;        // All P1.x reset
while(1)                          // While 1 is equal to 1 (forever)
   unsigned long int DATA;
   DATA=MEM_READ(0x5a,0x07);
   CALTEMP(DATA);
  unsigned int i;
  for(i=0;i<n;i++)
  _NOP();
//Name: start_bit
void start_bit()
  _SDA_OUTPUT; //Set SDA as output
  Delay(5);
  mlx90614_SDA_1();
  //Delay(30);
  mlx90614_SCL_1();
  Delay(30);
  mlx90614_SDA_0();
  Delay(30);
  mlx90614_SCL_0();
  Delay(30);
//Name: stop_bit
void stop_bit()
  Delay(5);
  //mlx90614_SCL_0();
  mlx90614_SDA_0();
  Delay(30);
  mlx90614_SCL_1();
  Delay(30);
  mlx90614_SDA_1();
//Name: send_bit
  Delay(5);
  if(bit_out==0) {mlx90614_SDA_0();}else{mlx90614_SDA_1();}
  Delay(5);
  mlx90614_SCL_1();
  Delay(30);
  mlx90614_SCL_0();
  Delay(30);
//Name: receive_bit
  unsigned char bit_in;
  _SDA_INPUT; //Set SDA as input
  Delay(5);
  mlx90614_SCL_1();
  Delay(5);
  if(SDA==1){bit_in=1;}else{bit_in=0;}
  Delay(10);
  mlx90614_SCL_0();
  Delay(30);
  return bit_in;
//Name: slave_ack
//1 - ACK
//0 -NACK
  unsigned char ack;
  ack=0;
  Delay(5);
  mlx90614_SCL_1();
  Delay(10);
  if(SDA==0){ack=0;}else{ack=1;}
  Delay(10);
  mlx90614_SCL_0();
  Delay(30);
  return ack;
//Name: TX_byte
  unsigned char Bit_counter;
  unsigned char bit_out;
  for(Bit_counter=8;Bit_counter;Bit_counter--)
    if(TX_buffer&0x80){bit_out=1;}else{bit_out=0;}
    send_bit(bit_out); //Send the current bit on SMBus
    TX_buffer<<=1; //Get next bit to check
//Name: RX_byte
//Parameters: unsigned char ack_nack (acknowledgment bit)
//0 - Master device sends ACK
//1 - Master device sends NACK
        unsigned char RX_buffer;
         if(receive_bit()==1) //Read a bit from the SDA line
           RX_buffer<<=1; //If the bit is HIGH save 1 in RX_buffer
           RX_buffer|=0x01;
         else //If the bit is LOW save 0 in RX_buffer
           RX_buffer<<=1;
           RX_buffer&=0xfe;
        send_bit(ack_nack); //Sends acknowledgment bit
        return RX_buffer;
//CALCULATE THE PEC PACKET
    unsigned char crc[6];
    unsigned char Bitposition=47;
    unsigned char shift;
    unsigned char i;
    unsigned char j;
    unsigned char temp;
  do{
    crc[5]=0; //Load CRC value 0x000000000107
    crc[4]=0;
    crc[3]=0;
    crc[2]=0;
    crc[1]=0x01;
    crc[0]=0x07;
    Bitposition=47; //Set maximum bit position at 47
    shift=0;        //Find first 1 in the transmitted bytes
    i=5; //Set highest index (package byte index)
    j=0; //Byte bit index, from lowest
    while((pec[i]&(0x80>>j))==0 && (i>0))
     Bitposition--;
     if(j<7){ j++;}
     else {j=0x00;i--;}
    }//the position of highest "1" bit in Bitposition is calculated
    shift=Bitposition-8; //Get shift value for CRC value
    while(shift)
      for(i=5;i<0xFF;i--)
       if((crc[i-1]&0x80) && (i>0)) //Check if the MSB of the byte lower is "1"
        { //Yes - current byte + 1
         temp=1; //No - current byte + 0
        } //So that "1" can shift between bytes
       else { temp=0;}
      crc[i]<<=1;
      crc[i]+=temp;
    shift--;
    //Exclusive OR between pec and crc
    for(i=0;i<=5;i++) { pec[i]^=crc[i]; }
    while(Bitposition>8);
    return pec[0];
//READ DATA FROM RAM/EEPROM
unsigned long int MEM_READ(unsigned char slave_addR, unsigned char cmdR)
  unsigned char DataL; //
  unsigned char DataH; //Data packets from MLX90614
  unsigned char PEC; //
  unsigned long int Data; //Register value returned from MLX90614
  unsigned char Pecreg; //Calculated PEC byte storage
  unsigned char arr[6]; //Buffer for the sent bytes
  unsigned char ack_nack;
  unsigned char SLA;
  SLA=(slave_addR<<1);
begin:
  start_bit(); //Send start bit
  TX_byte(SLA); //Send slave address, write
  if(slave_ack()==0){stop_bit();goto begin;} //Send command
  TX_byte(cmdR);
  if(slave_ack()==0){stop_bit();goto begin;}//Send Repeated start bit
  start_bit(); //Send slave address, read
  TX_byte(SLA+1);
  DataL=RX_byte(0); //
  //Read two bytes data
  DataH=RX_byte(0); //
  PEC=RX_byte(ack_nack); //Read PEC from MLX90614
  if(ack_nack==1) //Master sends ack or nack
  //This depends on the pec calculation,
  //if the PEC is not correct, send nack and goto begin
  {stop_bit();goto begin;} //Send stop bit
  stop_bit();
  arr[5]=(SLA);
  arr[4]=cmdR;
  arr[3]=(SLA+1);
  arr[2]=DataL;
  arr[1]=DataH;
  arr[0]=0;
  Pecreg=PEC_cal(arr,6); //Calculate CRC
  if(PEC==Pecreg){ ack_nack=0;}
  else{ ack_nack=1;}
  Data=(DataH*256)+DataL;
  return Data;
//Name: CALTEMP
//Temperature data is T=(Data)*0.02-273.15
   unsigned long int T;
   unsigned int a,b;
   T=TEMP*2;
   if(T>=27315)
     T=T-27315;
     a=T/100;
     b=T-a*100;
     if(a>=100){A4=a/100;a=a%100;A5=a/10;a=a%10;A6=a;}
     else if(a>=10){A4=0;A5=a/10;a=a%10;A6=a;}
     else {A4=0;A5=0;A6=a;}
     if(b>=10){A7=b/10;b=b%10;A8=b;}
     else{A7=0;A8=b;}
   else
     T=27315-T;
     a=T/100;
     b=T-a*100;
     A4=9;
     if(a>=10){A5=a/10;a=a%10;A6=a;}
     else{A5=0;A6=a;}
     if(b>=10){ A7=b/10;b=b%10;A8=b;}
     else{A7=0;A8=b;}
显示等程序被我剪掉了 现在接收不到ack Data一直等于0
我自己怀疑是延时和时钟设置问题 但不知如何修改
还请各位前辈帮帮我 我先提前谢谢各位了。。。
dirtwillfly 发表于 2015-3-24 22:47 来自手机 | 显示全部楼层
用示波器或者逻辑分析仪看过时序么?
yuluabc 发表于 2015-8-6 17:25 | 显示全部楼层
你能把显示程序发给我吗,我也在做,万分感谢!1152637976@qq.com
liutingn 发表于 2015-9-17 11:05 | 显示全部楼层
你好,正在做cc430与Mlx90614温度计,看了你的帖子,我也调试遇到问题,想问问你,你的源码方便给我吗,我的邮箱liuting807@live.cn,谢谢
