我公司的5.7"tft ,产品全部台湾产,性能价格比非常非常好!!!!!!<br /><br />目前系列5.7"系列款式如下:<br /><br />产品描述:<br /><br />1)5.7 inch 320240 tft (ccfl背光)跟sharp 5.7"tft完全兼容<br />Dot Matrix 320 x RGB x 240<br />Module Size (W x H x T) 144.0 x 104.6 x 13.0<br />Viewing Area (W x H) 121.0 x 92.2<br />Active Area (W x H) 115.2 x 86.4<br /><br />2)5.7inch 320240 tft ( led backlight背光)<br />(1) Construction: 5.7” a-Si color TFT-LCD, White LED Backlight and PCB.<br />(2) Resolution (pixel): 320(R.G.B) X240<br />(3) Number of the Colors : 262K colors ( R , G , B 6 bit digital each)<br />(4) LCD type : Transmissive Color TFT LCD ( normally White)<br />(5) Interface: 40 pin<br />(6) Power Supply Voltage: 3.3V single power input. Built-in power supply circuit.<br />(7) Viewing Direction: 6 O’clock ( The direction it’s hard to be discolored )<br />Module Size :131.0(W)x102.2(H)x10.9(D)<br />Active area :115.2 (W) x 86.4 (H)<br /><br />3)5.7 inch TFT 320240(CCFL backlight 背光)<br />Module Size :131.0(W)x102.2(H)x10.9(D)<br />Active area :115.2 (W) x 86.4 (H)<br />(1) Construction: 5.7” a-Si color TFT-LCD, White CCFL Backlight and PCB.<br />(2) Resolution (pixel): 320(R.G.B) X240<br />(3) Number of the Colors : 262K colors ( R , G , B 6 bit digital each)<br />(4) LCD type : Transmissive Color TFT LCD ( normally White)<br />(5) Interface: 40 pin<br />(6) Power Supply Voltage: 3.3V single power input. Built-in power supply circuit.<br />(7) Viewing Direction: 6 O’clock ( The direction it’s hard to be discolored )<br /><br />4)5.7"TFT 320240<br />(1)Number of Dots 320 x RGB x 240 dot<br />(2 )Display Size(Diagonal) 5.7 inch Inch<br />(3) Dot Size 120 x 360 μm<br />(4) Active Area 115.2 x 86.4 mm<br />(5) Viewing Angle 6 O’clock with SWV polarizer -<br />(6) Color arrangement RGB stripe -<br />(7) Dimension (W x H x D) *1 126.0 x 101.55 x 5.7 mm<br />(8) Back-light LED Back-light / White<br /><br />5)5.7"TFT 320240 (跟业界流行的5.7cstn 320240 lcm 结构兼容)<br />(1)Dot Matrix 320*RGB*240<br />(2)Module Size (W x H x T) 154.6 x 114.8 x 8.5 (MM)<br />(3) Viewing Area (W x H) 116.2 x 87.4 (MM)<br />(4)Active Area (W x H) 115.2 x 86.4 (MM)<br />(5) Backlight Type CCFL <br /><br /><br />6)5.7英寸tft 640480 (led backlight背光)<br />Panel Size 5.7 inch(panel diagonal)<br />Display Area (mm) 116.16(W)×87.12(H)<br />Number of Pixels 640×3(H)×480(V)<br />Pixel Pitch (mm) 0.1815(H)×0.1815(V)<br />Color Pixel Arrangement RGB vertical stripe<br />Display Mode Normally white<br />Number of colors 262,144<br />Viewing Direction 6 o´clock<br />Response Time (Tr+Tf) 30ms<br />Brightness(cd/m2) 220nit(typ)<br />NTSC ratio 50%<br />Viewing Angle(BL on,CR≧10) 140 degree(H),100degree(V)<br />Electrical Interface(data) TTL<br />Power consumption(W) TBD<br />Outline Dimension(in mm) 127(W)×100(H)×7(D)<br />Weight(g) TBD<br />BL unit LED<br />Surface Treament Anti-Glare,Hardness:3H<br /><br /><br /><br /><br />谢谢!<br />0755-81536676 深圳市金阳雷英科技有限公司<br />www.gssz.com.cn<br /><br /><br /> |
