在DVD上的M8固件库与IAR编译器一起会发现错误。但其怪的是他的版本号与我所用的(在IAR上正常编译)的一样!
请大家分析!
* @file stm8s.h
* @brief This file contains all HW registers definitions and memory mapping.
* @author STMicroelectronics - MCD Application Team
* @version V1.1.1
* @date 06/05/2009
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM8S_H
#define __STM8S_H
/* Library configuration section */
/* Check the used compiler */
#if defined(__CSMC__)
#undef _RAISONANCE_
#define _COSMIC_
#elif defined(__RCST7__)
#undef _COSMIC_
#define _RAISONANCE_
#else
#error "Unsupported Compiler!" /* Compiler defines not found */
#endif(这是碟上的文件)
* @file stm8s.h
* @version V1.1.1
* @date 06/05/2009
#ifndef __STM8S_H
#define __STM8S_H
#undef _RAISONANCE_
#undef _IAR_SYSTEMS_
#define _COSMIC_
#undef _COSMIC_
#elif defined(__IAR_SYSTEMS_ICC__)
#undef _COSMIC_
#undef _RAISONANCE_
#define _IAR_SYSTEMS_
#else
#endif
很明显多一了段 #define _IAR_SYSTEMS_语句,才能在IAR上编译通过。 |
